Cruise Control failed - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By ixion
  • 1 Post By Hui Sweetcheong
  • 1 Post By ixion
  • 2 Post By PaPa Bear
  • 1 Post By ixion
  • 1 Post By kapitand
#1 Old 02-19-2018
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
Question Cruise Control failed
Went out for a drive in my SLK yesterday for the first time in 2 weeks.
Discovered that the Cruise Control was not working although the orange light on the stalk comes on when pushed in.
Checked - -
Tyre Pressures - ok
Fuses (2) [ Under Hood & Side of Dashboard ] ok
No fault lights on instrument panel
No codes thrown when checked with my Magic box.
Brake Lights working normally
Can anyone think of anything else easy to check or am I off for a visit to my Indy .
Mike
ps33fount likes this.
ixion is offline
#2 Old 02-19-2018
Quoted: 2282 Post(s)
Not a brains, as you know.
But doesn't the speed sensor come into play here?
Avel Du is online now
#3 Old 02-19-2018
I'm no expert, but I bet at least one of these guys will drop by with the relevant info:
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
#4 Old 02-19-2018
Other Toys: Areobatic Biplane (20+years and I'm still alive)
Check if the roof works.(.lets see...bonnet in the front...boot in the back...drop head??? above?). Like the cruise control, the top function needs to know the wheel speed. This will help rule in/out sped sensors and reluctor rings.
kapitand is offline
#5 Old 02-19-2018
Vehicle: '99 SLK 230 R170
Please check battery voltage with engine off for at least 2 hours. I've seen low voltage cause CD to stop working with battery voltage below 12.1 volts. Even with engine running and alt output close to 14.2, CC measures only battery output voltage. You need 12.6-13.2 on egg me off voltage.
mitchkranes is offline
#6 Old 02-20-2018
Hui Sweetcheong's Avatar
Vehicle: Merc SLK 200 (171) 2008. Right hand drive - Japanese spec
Other Toys: Self balancing personal transporter, elec bike, etc
Quoted: 74 Post(s)
Hi
Good day.
I had this problem before.
And the cause of it was the steering angle sensor malfunction.
There was no repair but to change the angle sensor.
When the angle sensor malfunction, the ESP also doesn't work.
I costed me about USD 400.00
Thank you & have a nice day
Hui Sweetcheong is offline
#7 Old 02-20-2018
ixion's Avatar
Quoted: 41 Post(s)
Thanks to all who gave suggestions -
Check if the roof works - I had the roof down when I found the problem. Just checked it again - Works OK
Check battery voltage - I Just fitted (3 weeks ago ) a New Varta AGM battery. Just in case I put a DMM across the terminals. Result - 12.4v. Then I remembered to take a terminal off (Open Circuit Test) - Result 12.9v
Steering angle sensor malfunction - This should give me an EPS fault light + code. Neither present.
Have just rung the Indy & have an appointment on Thursday.
Will let you know the Cause & Cure then.
Mike
ixion is offline
#8 Old 02-20-2018
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Wasn't pressing the stalk in for the speed limiter, not the cruise control, or was the orange light comment just to say there was life there?
When was it last working? Have you changed tyres since then?
curro101 is offline
#9 Old 02-21-2018
PaPa Bear's Avatar
Vehicle: 1999 SLK230
Other Toys: What ever i have in my hand at the time
Quoted: 35 Post(s)
I use cruse on my 99 230 all the time, if you push the stalk in it turns on speed limiting, and turns the light on and cruse off
If your is the same as mine you dont need to turn it on like a lot of vehicles, it is on by default.
If the light is on press the stalk in again to go back from speed limit to cruse, and the light should go off.
Then once at the speed you what just lift up the stalk and you are done, to manualy disingage pess stalk backwards (towards front of car )
Hope that makes sence, but as i said not sure your's is the same but that is how the 99 version works.
By the way i have found a nice feature in the slk cruse control is that it will drop down a gear when going down a hill to stop you going overspeed, how that is a nice touch
Cheers from down under
Australian and devilman9050 like this.
PaPa Bear is offline
#10 Old 02-21-2018
devilman9050's Avatar
Vehicle: 2003 SLK230
Other Toys: ML280, CBR600
Quoted: 137 Post(s)
Hi Ixion,
I'll second what PaPaBear said:
Pull towards: Activate at a previously set speed
Push up: set speed or increase current speed in 1mph increments
push down: decrease speed in 1mph increments
push away: turn off
push stalk in: set speed limiter
https://www.manualslib.com/manual/10...age=137#manual
I'm pretty sure the 320 would be the same as the 230, I can't see why they'd make it any different?
Dez
Fancy seeing what your SLK can do on the track, and getting a bit of hazardous driving training?
Come along to the track day at Rockingham on the 9th September 2018:
devilman9050 is offline
#11 Old 02-23-2018
ixion's Avatar
Quoted: 41 Post(s)
Getting back to you about my problem.
Car delivered back with Cruise Control still not working.
The Indy found no Codes with his Star - DAS unit.
After discussion we decided to replace the Switch Unit on the Steering Column. Has to come from Germany (5 days) so fitting end of next week.
If that does not work ???.
Does anyone know if a Problem in the Front SAM could cause this problem ??
Mike
ixion is offline
#12 Old 02-24-2018
My cruise control failed while at highway speed. It just fell out of cruise.
Cause: A toothed sensor ring on the left rear axle cv shaft had failed. A section of the ring fell out. Even though the other three wheels were sending speed data, it was enough to kill the cruise control.
While you are waiting for the switch, pull the rear wheels. A speed ring is located on the wheel end of each CV axle. You can see it just enough to inspect it as you turn the axle.
The rings are pressed on, and develop rust underneath, cracking the ring. New rings are not available in the US. Get one or two from a UK ebay source. Around $14 US. They can be tapped in place with a light hammer.
kapitand is offline
#13 Old 03-25-2018
ixion's Avatar
Quoted: 41 Post(s)
Unhappy UPDATE on Cruise Control Problem
My Cruise Control Saga Continues -
SO FAR - My Indy Mechanic has
1/Checked all the fuses and and Relevant Wiring.
2/ Replaced the Cruise Control Switch Assy.
3/ Changed the K40 for a new one (He happened to have one waiting to co on another SLK) He Then put mine back on the my Car.
4/I am now waiting for Control Module Combo Relay No - 170 545 02 05 (170 545 02 32) Which i've bought second hand and will arrive Wednesday
Indy has said "Very unusual to have Cruise Control Fail & no Fault Codes Seen"
I am not going to let this beat me. But I dread to think of the Hours racked up so far.
Anyone else had a Flash of inspiration about my Problem ??
Regards
Mike
ixion is offline
#14 Old 05-01-2018
ixion's Avatar
Quoted: 41 Post(s)
Unhappy My cruise control failure
Re MY CRUISE CONTROL FAILURE
Does anyone with a STAR System know what you can CODE with it in respect of the CRUISE CONTROL
My Chassis No is - WDB1704492F217411
I am still trying to sort this problem and already have spent half a fortune on Labour Costs.
Mike
ixion is offline
#15 Old 05-27-2018
ixion's Avatar
Quoted: 41 Post(s)
Cruise Control finally working again.
Fourth visit to Indy who found it was the wire in the main Fuse Box (Fuse 10) was not making a connection.
Not something normally expected.
ixion is offline
#16 Old 05-27-2018
Vehicle: 2009 SLK 2Look
Other Toys: Ford Fiesta Titanium 3Dr, Porsche 944S2
Quoted: 100 Post(s)
I have cruise control but only checked it the once - it works. I have voice control - that also works. My GPS Navigation also works. My steering wheel buttons work also - All Work! My problem is finding a place to go for the nav, operating the cruise control and voice control for the CD shuttle. And finding some one to phone via my hands free - any ideas?
Thanks - !
Gimme Shelter is offline
#17 Old 05-27-2018
Quoted: 100 Post(s)
Originally Posted by devilman9050 View Post
Hi Ixion,
push away: turn off
Dez
Did some one spot an elephant?
#18 Old 05-27-2018
Quoted: 137 Post(s)
An elephant?
Sent from my SM-G950F using Tapatalk
Common and easy to do DAS 'tweaks' Seanhump DAS/STAR Coding 103 08-25-2019 04:55 AM
Adding cruise control to a manual '99 never2late99 SLK R170 General Discussion 7 09-21-2018 04:49 PM
Cruise control r170 200k '98 astarjack SLK R170 General Discussion 1 09-24-2017 07:49 PM
Acronyms, TLA's and other abbreviations Seanhump General Discussion 3 11-20-2014 06:06 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
