Help on MAF abd Roof - Mercedes Benz SLK Forum
  • 1 Post By lauroasn
  • 1 Post By Avel Du
#1 Old 02-14-2018
Vehicle: 1998 / 1999 SLK 230
Other Toys: Camry v6 2010, Mustang V6 1995
Dear All,
I have just bought a 1999 SLK 230 and it is great!! So far I had the engine and gear mount changed, all fluids changed.
The car was failing at higher revs and after I cleaned the MAF, the problem was gone. I was surprised with the amount of oil stuck to the MAF.
Any clue on what is causing oil contamination on the MAF?
When I bought the car the roof was working fine. The roof fluid was leveled at the minimum. I asked my mechanic to top it up. Which he did. Now it is leveled at max. The first time I opened the roof I spotted a leak on the left cylinder that goes inside the trunk. Never tried it again afraid of damaging it.
I read almost all posts on the thread about vario roof at r170. Lots of great info there. Thank you very much. I even posted some questions there but as it is such a long thread I believe my question was lost there and I decided to post a new thread. Sorry bout that but I am anxious to fix it.
The questions I have are:
1- Thud57 mentioned he had a step by step instruction on how to change the rings. I contacted him with no luck. Does anyone have the instructions for me?
2- As far as I understood I need 5 o rings and 5 u rings. On ebay I see mostly o rings on sale. It seems the good ones are sold by meedee88pandora, and they replace the U rings. Is that correct? Do I also need the O rings that are placed on the tip of the piston?
3- Found all replacement seals at MJ Produkte GmbH for 55 euros. they are Viton. Apparently, the brown Viton u ring is not good is that correct? Should I go with the O ring instead?
Thank you very much for the great info and help
regards
lauroasn is offline
#2 Old 02-14-2018
Quoted: 2293 Post(s)
One of these fine members will know:
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
WoZ53 likes this.
Avel Du is online now
Tags
maf, maf cleaning, roof leak
Intermittent Roof jcjefferies SLK R170 General Discussion 4 08-08-2017 12:30 PM
Roof not stey up poni SLK R170 General Discussion 4 07-25-2015 03:41 PM
Problem when I open the roof poni SLK R170 General Discussion 2 07-24-2015 09:19 AM
The retractable roof pioneer's for 3,500 euros Berliner Heckflosse SLK R170 General Discussion 0 04-27-2015 09:26 PM
05 SLK55 Roof Jammed AMG 055 SLK R171 General Discussion 141 04-10-2014 01:01 PM
