Issues with new purchase-1999 SLK 230 Sport pkg - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By SUPERHEAT585
  • 1 Post By jbanks15
  • 1 Post By T-Bears
#1 Old 02-13-2018
Vehicle: 1999 Mercedes SLK 230 Sport 5 speed
Other Toys: Cessna Cardinal
Recently I purchased a 1999 SLK 230 sport pkg with 5 speed and drove it from CT to AZ. No issues during the 3 k mile drive home. Soon thereafter I did oil change with Mobile 1, changed the spark plugs and replaced all filters and fluids.
That's when things started to go south. The engine started to blow oil out of the filler cap and also into the air filter box.
I suspected excessive engine blow by so I did compression/leak down test and each cyl held 115 psi min for 10 min each.
The new OEM plugs were spotless so I think it is not a worn or stuck rings.
Next I removed the high side breather system and cleaned. No blockage or issues. Yesterday I removed the fuel rail, intake, and removed the low side -PVC- system and cleaned the two air injectors. Just waiting on parts to put together.
I am hoping this will fix my issue. The engine has 134,000 miles which I was hoping for a Mercedes it would not be an issue.
I have read the forms on this issue and would like to know if anyone else has been dealing with an issue like this.
Andrew
Flagstaff, AZ
Idiot101 likes this.
SUPERHEAT585 is offline
The Following User Says Thank You to SUPERHEAT585 For This Useful Post:
#2 Old 02-13-2018
Quoted: 6544 Post(s)
Let's notify some experts
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
WoZ53 likes this.
#3 Old 02-13-2018
nimbusgb's Avatar
Quoted: 253 Post(s)
Stupid question but was the oil filler cap properly seated?
I got one tang of the filler cap outside the bayonet fitting on my first 230 once, drove the car 50 miles before I discovered the cloud of oil smoke and smell emanating from up front. ( It was very dark! )
Opened the bonnet to find everything coated in oil, it had blown out everywhere!
nimbusgb is offline
#4 Old 02-13-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 978 Post(s)
Is not only the oil cap, oil is going in to the air filter as well.
How many litres of oil did you put in?
230 takes 5.5l
i860 is online now
#5 Old 02-13-2018
It was and I also flipped it over. A new one was ordered and on its way as well.
#6 Old 02-13-2018
I put in just under 6 US quarts. It is in the top of full mark on dip stick.
#7 Old 02-13-2018
Quoted: 2282 Post(s)
Was the oil frothy?
Despite the dipstick marks it could still be overfilled.
Easy to draw some out with one of these:
https://www.amazon.co.uk/engine-oil-...il%20extractor
Whilst your fixing, it's worth renewing the rubber seal under the filler cap.
One other thought.
It was engine oil for a petrol engine and not one for a diesel engine?
#8 Old 02-13-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 265 Post(s)
Welcome from North Carolina!
The Toy
Idiot101 is offline
#9 Old 02-13-2018
#10 Old 02-15-2018
T-Bears's Avatar
Vehicle: 2001 SLK 230 Kompressor AMG Sport Package
Other Toys: Kawasaki Ninja, 07 VW Rabbit 2.5
Maybe check your PCV valve and the nipple it connects to under the intake manifold...it can get plugged up or missing. I would check the air and oil separator as well for the same thing.
Does the oil reach to your MAF sensor and contaminate it?
T-Bears is offline
West Coast SLK Meet S. Lake Tahoe May 16th, 17th &. 18th LIL DON SLK U.S. Southwest Region 4 01-20-2015 05:29 PM
New Owner 1999 SLK 230 Sport, 5 Speed Manual MBDiagMan New Members Introduce Yourself Here 26 06-25-2013 11:10 PM
1999 SLK 230, Kompressor bmeninja87 New Members Introduce Yourself Here 16 01-12-2013 07:35 AM
