Is There Easy Access To The Fuel Float Sender - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By efair
  • 1 Post By i860
#1 Old 02-13-2018
Vehicle: 2002 Black SLK320
Other Toys: 1995 Chrysler Lebaron Convertible
Quoted: 58 Post(s)
2002 SLK320 my fuel gauge doesn't work and the Techron didn't help. I've seen a picture of the gas tank and know the sender is on the top. Before I start ripping out the trunk carpet, I'm wondering if there is some easy way to get at the top of the tank through the trunk without dropping the tank?
RobertP is offline
#2 Old 02-13-2018
Quoted: 2282 Post(s)
I'll ask the specialists:
@Mn car guy
@efair
@stu32
@Turdo2
@Padgett
#3 Old 02-13-2018
Quoted: 912 Post(s)
You can't "drop the tank", it's simply not possible. There is an access hole you can reach once you've got the trunk lining and magnesium cover removed. Be sure your fuel is below 1/4 full and be sure to work in a well ventilated area!
efair is online now
#4 Old 02-14-2018
Quoted: 58 Post(s)
Thanks for the tip on getting below a quarter tank, figure I'd better disconnect the battery as well. Wonder if the old one is repairable as in the float having a hole. I find used ones for around $75 but the gasket new sells for $30. There is also a NOEM for around $89, but I'd hate to have to adjust it or something, have to see if it comes with the gasket. That magnesium cover should make a nice addition to the fire ball. ;-)
RobertP is offline
#5 Old 02-14-2018
Quoted: 912 Post(s)
I've never had to repair one but from what I've read here the rheostat is the usual culprit, and repairs are short-lived. I'd try a few used ones from the yard first (if you can find them).
efair is online now
#6 Old 02-14-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 978 Post(s)
Removing and installing fuel level gauge sensor.pdf
http://docdro.id/JrobKpt
Hope this help, looks like you need a special tool.
i860 is online now
#7 Old 02-14-2018
Quoted: 912 Post(s)
The special tool does make it easy, but it's also possible to do without: insert two small screwdrivers into the holes (top and bottom in your picture) and then a third large screwdriver between them to turn the fitting.
efair is online now
#8 Old 02-14-2018
LeonardoDaBenz's Avatar
Quoted: 1062 Post(s)
Could make one out of a scrap of bar aluminum with 3 bolts (?) . Might be a little bit steadier than trying to be three handed
____________________
Len
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 252 2 Weeks Ago 01:31 PM
Wont start no fuel pressure giossoj SLK R170 General Discussion 21 12-23-2015 07:02 PM
Supermarket fuel (UK) True Romance General Discussion 17 04-02-2010 11:38 AM
Fuel economy perception Tslick General Discussion 7 12-28-2008 03:07 AM
