Please can you Help!! R170 Alarm Siren making high pitched noise. - Mercedes Benz SLK Forum
#1 Old 05-11-2013
Vehicle: SLK 230 1997
Please help, my SLK 230 1997 alarm siren near the main battery is making a constant high pitched sound. If i drive the car for half an hour it stops. If I do not drive the car for 24 hours it starts making the noise again.
Is there anything else that could be causing this other than the alarm siren needs replacing?
ebslk1997 is offline
#2 Old 05-11-2013
Not sure but is there a back up battery thats on the way out and its telling you ?
JonB is offline
#3 Old 05-11-2013
Hi JonB, is there a battery inside the alarm siren?
#4 Old 05-11-2013
I dont know but I think so. Keep watching someone will know and tell us
JonB is offline
#5 Old 05-11-2013
Quoted: 6551 Post(s)
you can try a search top right for your issue
go search
advanced
put alarm in search field
choose r170 general discussion from list
here is my search which might time out
https://www.slkworld.com/search.php?searchid=1454049
#6 Old 05-11-2013
leapyfish's Avatar
Check the pse, it controls the alarm, door locks..... http://www.benzworld.org/forums/r170...fit-check.html
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#7 Old 05-11-2013
go search
advanced
Thanks, but couldn't find any information on this high pitched noise.
#8 Old 05-11-2013
leapy says pse so search for pse
or see his post:
#9 Old 05-11-2013
Hi, The door locks are working as they should. If it were the pse wouldn't it cause other problems? Will still check the pse though, Thanks.
#10 Old 05-11-2013
Looks like there is a back up battery. Lots of alarms sound off if the back up is dying Maybe thats why it stops after you have drive as its getting some charge but not holding it
https://www.slkworld.com/slk-r170-gen...larm-horn.html
JonB is offline
The Following User Says Thank You to JonB For This Useful Post:
#11 Old 05-11-2013
Yes, the alarm has its own backup battery. Pop the hood open. Lock the car with the key fob. Wait 1 minute for alarm to activate. Then try disconnecting negative terminal =) The alarm will immediately go off. Connect the terminal back and disarm the alarm with the key fob. The sound without the battery will be a little lower. If you don't have any angry neighbors around you can try this experiment and see how long your alarm will last without the car battery =)
Also, many blame the PSE. I think it's because it operates all the vacuum in your car and e.g. you lock your car and something won't lock since there's a vacuum leak (doors, gas lock door, trunk, etc.) it doesn't activate the trigger and system thinks someone broke in =)
#12 Old 05-12-2013
Rechargeable battery in alarm module will eventually fail. It has happened in other cars I have owned. If that is the case you can try to replace the battery on the module or get a new module for ~ $200.
CarolinaBluetec is offline
#13 Old 05-19-2013
SLicKer's Avatar
Vehicle: 2003 SLK320
Other Toys: 89' Waggy - 77' 280z - 68' TR250 - 66' 1600 Roadster
I removed the no 9 fuse from the fuse box on the driver's side corner of yhe engine bay and got a medium volumn high pitch sound. I plugged it back in and my alarm (very loud cycling schrill)went off. I silenced it by holding down the key fob panic button. I think it's a means to make the alarm tamper proof. Could it be that your system is in that tamper alarm mode. Replace or check the no 9 fuse.
Mine's a left hand drive.
SLicKer is offline
#14 Old 05-19-2013
Thanks, I have checked the no 9 fuse. It looks fine and tested it had resistance. I will buy a new fuse and replace though just in case. The roof dome light comes on could this mean no 9 fuse is ok?
#15 Old 05-20-2013
SLicKer's Avatar
I don't know the answer to the dome light question but I'm not thinking it's the fuse especially since you've checked continuity. If you'll notice JasonM's comment above... he states the two different alarm sounds I'm referring to; #9 fuse installed that connects the alarm(very loud with my head under the bonnet) to the main battery and #9 fuse removed that forces the backup battery to power the alarm(not nearly as load). You may want to rule-out the main alarm that most on your thread are commenting about by removing #9 and determining whether you still here it or not. Be aware that my car's layout may be different from yours. You can check my profile but I have a 2003 SLK320. It should be close. The other thing that comes to mind is for you to purposely set the alarm so that you may determine if its the same sound. I hope ye graft(work) it out!
SLicKer is offline
The Following User Says Thank You to SLicKer For This Useful Post:
R170 (SLK 230 2003) SmartTop alarm issues =( JaysonM General Modifications R170 9 03-10-2013 06:53 PM
High pitch noise when braking in slow speed li174 SLK R171 General Discussion 3 10-11-2012 02:19 AM
wind noise on R170 murat orhan SLK R170 General Discussion 2 03-21-2012 08:32 AM
Wheel Lug Locks for 2006 SLK55 AMG w/ factory 18 inch wheels netmiami AMGs 27 11-21-2009 11:57 PM
New Tires and Rims making noise tdashmike SLK R171 General Discussion 9 04-20-2009 12:31 PM
