manual gearbox removal SLK 200 2003 - Mercedes Benz SLK Forum
  • 1 Post By i860
  • 1 Post By Mn car guy
#1 Old 01-31-2018
Vehicle: merc slk 200 2003 Red. AMG wheels; cream leather interior. Aluminium scroled dash.
Other Toys: S mini
Hello. I am having difficulty with selecting 1st/2nd gear. I have changed oil to MTL, still no improvement, so I want to remove the gearbox to check any binding on input shaft/clutch plate. Is there a write up on removing the gearbox in detail, and any adjustments to check for in the process. SLK 200 2003. compressor 2 ltr. 4 cyl. Thank you. Patrick.
patrick houston is offline
#2 Old 01-31-2018
Quoted: 2284 Post(s)
Some vids: https://www.bing.com/videos/search?q...oval&FORM=VDRE
Try a search of the site: https://www.slkworld.com/new-members-...searching.html
Maybe someone with WIS access could help.
And possibly these members:
@Mn car guy
@efair
@stu32
@savcom
@Padgett @Turdo2
#3 Old 01-31-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 982 Post(s)
Install transmission.pdf
http://docdro.id/iMiUtgG
i860 is offline
#4 Old 01-31-2018
Quoted: 133 Post(s)
I had to do a little research to see if it would be easier to pull the engine and trans together but apparently you don't have to on an slk. Here's a really good write up on a crossfire. It's basically the same though it's a six banger so the exhaust would be different. Before you go through all this, is it possible you are low on clutch fluid? Might be worth it to bleed the system and refill. If you think you need to pull the trans, here's the link. https://www.crossfireforum.org/forum...-04-coupe.html
Mn car guy is offline
Hi, New member with 2003 SLK 200 58000 miles Robthedog New Members Introduce Yourself Here 15 05-06-2017 02:13 PM
2003 SLK 200, New MAS/Fuel mix too thick Thomson94 SLK R170 General Discussion 2 02-11-2016 10:44 AM
Digital owners manual for the 2005 or 2006 SLK 200 Beppi SLK R171 General Discussion 2 03-29-2015 09:19 AM
