SLK Seat Covers Replacement - Mercedes Benz SLK Forum
 22Likes
  • 3 Post By efair
  • 4 Post By efair
  • 2 Post By Alschief
  • 1 Post By Alschief
  • 5 Post By Alschief
  • 3 Post By Alschief
  • 2 Post By Rofa
  • 1 Post By Bartiny
#1 Old 01-29-2018
Vehicle: SLK 230 1999
Other Toys: Honda Goldwing
Purchased new replacement seat covers on EBay. Received them last week very good quality. We chose the simulated leather MB-2 material.
Ran into two issues :
1. How do you remove the headrest retainers?
2. How do you remove the plastic seat back?
1999 SLK
Alschief is offline
#2 Old 01-29-2018
Quoted: 882 Post(s)
There is a small button on one of the two fittings on the seat back - push that button, then lift the headrest.
You don't remove the seat-back from the seat, you remove the leather from the seat-back. It's much easier with the seat out and on a bench. You pry up around the edge to remove the leather.
I'd love to see some pictures of your replacements.
jbanks15, Idiot101 and Avel Du like this.
efair is online now
#3 Old 01-29-2018
We know how to remove the head rest itself. We wanted to know how to remove the headrest receptacle. We heard you need to insert a needle of wire to release them. Pictures to follow.
Alschief is offline
#4 Old 01-29-2018
Quoted: 882 Post(s)
That is correct. This is hard to explain without a picture... there is a "tang" (like on a phone cable) that is part of the plastic piece and which locks the plastic piece in place. Look down the bore and you can see the tang, it's maybe 1/8" wide and maybe 1/2" long, and it has a small hole in the end. It doesn't protrude into the bore, it is on the wall of the bore. Use a straight pick and stick the tip into the small hole, bend the tang inwards (towards the center of the bore), and then give the plastic bit a stout pull up. It takes some coordination to do all three at once, but it is the only way
jbanks15, M4rCu5, Idiot101 and 1 others like this.
efair is online now
#5 Old 02-01-2018
Smile Headrest retainers
Found the hole to realese the headrest retainers Thanks for the instructions
M4rCu5 and Avel Du like this.
Alschief is offline
#6 Old 02-02-2018
Got both seats recovered today.
It was a little tricky but my wife and I we accomplished it. Many thanks for the info on removing the Headrest retainers. Will post installed pictures tomorrow.
M4rCu5 likes this.
Alschief is offline
#7 Old 02-02-2018
Here is a picture of one on the bench
File Type: jpg A37D8627-4904-49E2-9276-142922EACF9D_1517630189958.jpg (26.6 KB, 68 views)
nimbusgb, M4rCu5, Pictor and 2 others like this.
Alschief is offline
#8 Old 02-03-2018
Just finished the new seat cover install. Very pleased with the seat cover.
2SLKs_for fun likes this.
Alschief is offline
#9 Old 02-03-2018
Quoted: 882 Post(s)
Looks fantastic
efair is online now
#10 Old 4 Weeks Ago
Vehicle: 1997 230 Kompressor
Other Toys: Saab 9-5 V6 , Various Jags and Europa aircraft in the past
Quoted: 18 Post(s)
@Alschief did you reinstall the little black clips round the leather trim when you reassembled? These are the ones that push down into the channel round the back. I can see that they are meant to hold the cover to the back, but the cover is such a tight fit I wondered if they were necessary?
Rofa is offline
#11 Old 4 Weeks Ago
LeonardoDaBenz's Avatar
Quoted: 1019 Post(s)
As this is an old thread, he has not been on since Oct 2018 and may not answer.
https://www.slkworld.com/new-members...d-how-fix.html
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#12 Old 4 Weeks Ago
We did replace them. I’m really unsure if needed
Australian, M4rCu5 and Avel Du like this.
Alschief is offline
#13 Old 4 Weeks Ago
Quoted: 18 Post(s)
Thank you very much!
Rofa is offline
#14 Old 1 Week Ago
Quoted: 18 Post(s)
Well i got around to doing the job. The answer re the retaining clips is that i need to use 2 or 3. The cover locks fairly well into the panelling groove most of the way around. On the curves there were a couple of places where I had to re use the clips. I think the reason that there were so many originally is that the leather would have been very taut when they were first assembled. In fact I found re assembling much easier than stripping it down. Necessary tools are plastic pries, a narrow bladed screwdriver and long nosed pliers for extracting the clips and an F clamp to squeeze the base down on its springs so that the bottom edge of the seat cover can be pulled through.
M4rCu5 and Bartiny like this.
Rofa is offline
#15 Old 1 Week Ago
Bartiny's Avatar
Vehicle: 1996 SLK 230 R170
Quoted: 13 Post(s)
I like your seat covers and a great job fitting them, they look smart, and will protect the original leather do you have the link for the supplier please?
M4rCu5 likes this.
My pre production R170 test/demonstrator built August 19th 1996 saved from almost certain to be broken up for spares. Potentially the oldest surviving RHD by VIN?
Bartiny is offline
West Coast SLK Meet S. Lake Tahoe May 16th, 17th &. 18th LIL DON SLK U.S. Southwest Region 4 01-20-2015 05:29 PM
