R170 Tune Up and Code Diagnosis Question - Mercedes Benz SLK Forum
 5Likes
  • 3 Post By savcom
  • 2 Post By savcom
#1 Old 01-28-2018
preacheranav's Avatar
Vehicle: 2000 SLK 230 kompressor 5-speed
Other Toys: 1996 Jeep Cherokee Sport, 1969 BSA Firebird Scrambler 650
All,
2000 SLK 230, 5 speed. Just got it and had only driven it a few times before having to hit the road for two weeks. Home first week in February and will be going through it. I'm new to the car and am dangerous with a wrench! I can get anything apart but will be working on diagnosis and then getting it back together correctly.
I've changed the oil and replaced the oil cap and run the engine codes for the CEL. I replaced the K40 relay initially and am still getting the P1235 code. According to my reader (Blue Driver) it says it could be an issue with recirculation flap motor M16/7 wiring or to replace the supercharger. Before I go any further I have no idea when the plugs, coils, or wires were changed so can someone fill me in on what constitutes a tune up? I saw another thread recommending doing that first before anything else gets done.
What are the recommended plugs, coils, wires, and anything else I should change before I take it on the road? Air filters? Clean the MAF? Belts? Give me anything you think I should replace right up front and I'll get that done first before doing anything big.
Also, how do I check and see if the supercharger clutch is engaging?
Really looking forward to getting to know this car and fixing everything on it. If anyone wants to sound off on how to fix the ASR/BAS light I'm all ears on that as well. Thanks!
v/r
Kevin
preacheranav is offline
#2 Old 01-28-2018
savcom's Avatar
Quoted: 613 Post(s)
Originally Posted by preacheranav View Post
All,
v/r
Kevin
Looks like you've raised two points here:
A problem with the supercharger (others are wiser than I on this aspect as I have no supercharger...)
A 'full service' enquiry.
The 'full service' bit depends on how many miles the car has done. Look up in the manual what a 'Service B' entails and this will give you an excellent starting point for what has to be done.
If you've done more than (say) 50,000 miles then look to change the auto transmission fluid, gasket and pilot bush connector as this can improve gear changing and save you from problems later on. Look also at the CAM magnet sensor as the seal can fail with the result that oil wicks up the loom and takes out an ECU in the process.
Clean and clear each of the drain holes around the car - these have a habit of blocking up of you park the car under trees
Gummi-pfledge your seals and check your hinges for the roof mechanism
There are plenty of DIY threads for these - use the search tool for these and you'll see lots of instructions on how to carry these out.
But most of all - ENJOY the car (once you're happy all the things you want are sorted).
Avel Du, Alschief and preacheranav like this.
Also
Previous :
savcom is offline
#3 Old 01-28-2018
savcom's Avatar
Quoted: 613 Post(s)
The ASR/BAS light can simply be on because you've disconnected the battery (maybe when you changed the K40). There's a standard Mercedes procedure you should perform in order to reset it.
Procedure:
  • Start your car like you would normally do.
  • Turn the steering wheel all the way to the left and hold for about 2 seconds in this position.
  • Turn the steering wheel all the way to the right and hold for about 2 seconds in this position.
  • Bring the steering wheel back to the centre position.
The light should now go out.
Avel Du and preacheranav like this.
Also
Previous :
savcom is offline
