Upper oil pan Bolts - Mercedes Benz SLK Forum
 14Likes
  • 3 Post By Dallas
  • 2 Post By Dallas
  • 1 Post By mchild
  • 1 Post By Turdo2
  • 1 Post By Dallas
  • 1 Post By Avel Du
  • 3 Post By i860
  • 2 Post By Dallas
#1 Old 01-18-2018
Vehicle: 2004 SLK 320LE
Other Toys: 1929 Tudor Sedan Streetrod
Upper oil pan Bolts
So I made a newbie mistake and didn't keep track of where each bolt came from. Does anyone have a diagram of which bolt goes where on the upper oil pan for a 2004 slk? There are 3 different lengths of bolts minus the larger ones that connect to the transmission. Any help would be appreciated
LIL DON SLK, Idiot101 and Avel Du like this.
Dallas is offline
#2 Old 01-18-2018
New to the group and glad to see that everyone is helpful. About the car, I bought a 2004 SLK 320LE that the previous owner ran over a parking block and trashed both oil pans. First time MB owner but my prize is my 1929 Tudor street rod.
LIL DON SLK and Avel Du like this.
Dallas is offline
#3 Old 01-18-2018
Quoted: 508 Post(s)
If no one chimes in with specifics you can always measure the depth on each hole that receives a bolt and use that as your guide as to which bolt for which location. If the hole is not blind (bolt can come out the other end) then the measure would be to the point where the bolt would start to come out of the hole.
You may already have this, but there appears to be three lengths 20, 40, and 90mm. Shouldn't be that hard to figure out which goes where. Good luck and welcome to the forum.
Dallas likes this.
mchild is online now
#4 Old 01-18-2018
Turdo2's Avatar
Quoted: 361 Post(s)
You'll just have to run them up individually and if they bottom out, then try a shorter one. based on a few pictures I have of one of these engines removed, it appears all the side bolts are the same length, and the longer ones go in the front (timing cover) and most likely the back near the flywheel.
Dallas likes this.
Turdo2 is offline
#5 Old 01-18-2018
Didn't think of a depth gauge , I already have most of the bolts back in and was hoping to not have to revisit each one. But thank you , I will first check the ones by the timing cover. I will say that I was rather shocked at how many bolts are in that upper pan. Thank you both again.
LIL DON SLK likes this.
Dallas is offline
#6 Old 01-18-2018
Quoted: 2303 Post(s)
Let's call the gang:
@Mn car guy
@efair
@stu32
@savcom
@Padgett
Dallas likes this.
#7 Old 01-18-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 990 Post(s)
Hope this help
Oil pan bolt diagram.pdf
http://docdro.id/Sce15ir
Idiot101, stu32 and Dallas like this.
i860 is offline
#8 Old 01-18-2018
I860 You sir are a rockstar.. Just what I was hoping to find. Thank you.
LIL DON SLK and i860 like this.
Dallas is offline
DIY Oil Change and Lessons Learned geophysicist SLK R170 class DIY 37 10-29-2017 12:52 PM
DIY Oil Change Coolant/Antifreeze Flush Power Steering Fluid Change Swoley2k SLK R171 Class DIY 5 04-17-2017 05:27 PM
2000 SLK230 with an oil pan leak bigdumbdane SLK R170 General Discussion 2 05-04-2015 07:58 PM
