misfire and running problems - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Adrian Whareham
  • 1 Post By Bahdabing
  • 1 Post By T-Bears
#1 Old 01-18-2018
Adrian Whareham's Avatar
Vehicle: SLK 230 1997
Other Toys: Old MG TD And 80s motorcycles
Hi all my slk 230 1997 ran just fine they started to run really lumpy it felt as though I had lost a plug , so I fitted new plugs and new coils new air filter , had look maf senior which looked clean and dry no oil , started all good I thought , did a test drive a couple of splutters then all good did a good 10 mile run , no lack of power and ran fine , set in the car for a while I did notice that it seemed to have a very slight misfire , so today had another run , it's now running like pig , higher revs and lumpy , I had no engine check light and all though my ob2 showed 3 codes when I go to read them it said no codes stored , if you have any ideas as what to do now I would be grateful .
I have ordered new plug leads .
Adrian .
LIL DON SLK likes this.
Adrian Whareham is offline
#2 Old 01-18-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Mine had an ever so slight misfire, more when it was warmer out. ended being a leaky head gasket.
how are the cold starts? smooth?
Next time it feels like it's misfiring, try pulling an individual injector wire and find which cylinder has gone "lumpy"
Turdo2 is offline
#3 Old 01-18-2018
Quoted: 2301 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Padgett
#4 Old 01-18-2018
hi thanks for the replay I think the problem was on one cylinder as the plug was black I don't think the head gasket is gone as I not lost power or fluid , when driving it like a bad connection or sensor , thinking of cleaning the maf sensor or replacing it .
#5 Old 01-18-2018
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
I'd bet money on a fuel injector. They are simple to check out:
BTW, my BMW was experiencing a misfire on cylinder Two. My scanner reported a misfire on two and a bad injector. Fortunately, I have an extended warranty, so I didn't have to shell out $500 for a repair bill.
SilverSLK2010 is offline
#6 Old 01-19-2018
Hi all update tested the injectors today all have tested as good , removed maf and cleaned the car now has on power and no boost and running lumpy , I disconnected the maf and it ran better but still no power I have ordered a new maf be with me next week , may have another go at cleaning maf .
till next time have a one .
#7 Old 01-23-2018
Update
Hi all today's update , fitted new plug leads and a new maf sensor did a quick spin around the block , ran ok power was back pulled in to the drive back to running lumpy and more unnerving it smelt as though some thing was burning , turned it off opened the hood nothing but there was a bit of a petrol smell , I think I may have cooked the catalytic converter maybe but don't know .
If any one has any good ideas please let me know it's looking like it going to have to go to the garage for some diagnostic work .
#8 Old 01-23-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Sounds like you need to pull some codes and monitor a few things like Throttle angle, MAF flow, timing advance, short term fuel trim, long term fuel trim and O2 sensors readings.
Padgett is offline
#9 Old 01-23-2018
Vehicle: 2000 SLK 230 Electric Green Designo Signature series
Quoted: 15 Post(s)
Is the MAF sensor OEM? What about the coil packs? I had a similar issue. My brother put in an aftermarket MAF and coil pack. I put in OEM stuff and it was right as rain after. A lot of the aftermarket stuff is crap.
Delucas likes this.
Bahdabing is offline
#10 Old 01-23-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Running rich?
can we get a video?
Turdo2 is offline
#11 Old 01-23-2018
Quoted: 1138 Post(s)
You need a Quality Diagnostic machine to pull off the codes and fitting cheap Electrical items are not the best choice on these cars .
Always best to fit original parts especially sensors - Electrical items etc
Pattern parts dont seem to last long .
Delucas is offline
#12 Old 01-23-2018
codes I have from the car now
P0100 mass or volume air flow A circuit malfunction
P0201 cylinder 1 injector circuit malfunction
P0301 cylinder 1 misfire
P0110 IAT sensor 1 circuit malfuntion
It looks as if the injector on number 1 cylinder is giving me the problem although they all sound the same as in youtube video , I am going to remove the injectors and test them , will let you know what I find
#13 Old 01-23-2018
Quoted: 217 Post(s)
You could always swap 2 injectors and see if the code follows it. If it does, then you have found a problem. MAF and AIT code should have nothing to do with the injector, so you may have multiple issues going on. The AIT sensor could potentially throw the P0100 code. I would look at getting a new AIT sensor right away or checking the wires to it.
jet_fl is offline
#14 Old 01-23-2018
dandywarhol's Avatar
Vehicle: 1999 SLK 230, 2009 SLK200,
Other Toys: 1967 Yamaha TD1C, 1996 Yamaha TRX850, '08 Renault Lunar Telstar motorhome
Quoted: 24 Post(s)
I've never been successful cleaning MAFs - always seems to leave a deposit on the sensor. I chased a misfire for long enough and found the MAF had been changed previously for a non OEM one. I fitted a MAF insert made by Pierburg (don't see any point in paying more for a plastic tube!) and the problem was sorted. Pierburg part number 7.22684.09.0
dandywarhol is offline
#15 Old 01-25-2018
Thumbs up another update
update for today removed the injectors and ohms tested them all exactly the same not what I was expected , reinstalled them started the car and it run just fine , when it was up to temperature and still running fine turn it off and scanned the car for codes nothing , ok short trip around the block still running fine , scanned again still on codes , ok longer run did about 10 miles or so and still running fine , rescanned still no codes so it was a bad connection at the injectors or I have the worlds first self repairing car only time with tell , will need to give it a few more runs to see , thanks for your posts will do an update in few days .
#16 Old 01-25-2018
Quoted: 108 Post(s)
Unhappy Your Injector(s) is Kaput!
The gas you smelled is the injector leaking down into the cylinder. You might have also experienced a backfire? Have you seen any black smoke?
Misfires and bad injectors go together. In a car this old, I'd replace all. BTW, you'll have to code them after installation.
#17 Old 01-25-2018
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
Hi Adrian I thought I would clean my MAF the other day as a routine service. When I put it back the fan was running at slow speed and the car did not feel right. I had two of your codes P0110 and P0100 I think it was, air intake temp and a MAF fault. Upon checking again I had put the 'O' ring in the MAF housing in the wrong place, i,e on the MAF housing instead of inside the correct location position in the air trunking and I had the sensor itself 180deg out of position on the outside instead of toward the centre of the car, I had it towards the outside of the car. I refitted the O ring correctly and position the sensor correctly and now the car is good again.
bryn is offline
#18 Old 01-25-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Jus checked on the Pierburg and at least here it costs twice as much the whole Bosch MAF.
Padgett is offline
#19 Old 01-28-2018
T-Bears's Avatar
Vehicle: 2001 SLK 230 Kompressor AMG Sport Package
Other Toys: Kawasaki Ninja, 07 VW Rabbit 2.5
I had the same problem not to long ago, and it ended up being a clogged cat. I replaced the coil and plug because it's cheap and easy to removed. I could have reused the #1 plug, but again it's cheap. I even cleaned the Maf, but after a few days the same codes comes back. At the time, mine only comes back at a certain rpm under full load, then the ECM would need to be reset to be able to drive the car smooth again.
I know my car has good compression due to previous (headwork) and I'm getting adequate spark, so my #1 injector is what is left to replace and so I did. Same codes came back after triggering it again under full [email protected] about 4500rpm.
You can check if the maf is still ok, with a Digital Muti meter. However, in my case I have a fresh Maf so cross that off the list. I also recently replaced my fuel filter and my F. pump was still running good.
I even replaced my cam & crank sensor, just because it was cheap and it was one of the many things that could cause this. Same codes triggered again. Finally, I tapped my cat converter and noticed that the honeycomb inside was broken in pieces. I could have drilled through my exhaust and whipped out my camera to view the condition of the honey comb , but no need.
Long story short, got a replacement from Magnaflow and never looked back.
T-Bears is offline
#20 Old 02-28-2018
Update
Its been some time and I have driven the a good number of times and everything is still working fine , next is the mot in march , thanks to all for your posts .
Misfire cylinder 1 Rhys Willson SLK R170 General Discussion 13 04-25-2019 02:34 PM
Engine Problems - need some direction going forward chevvy SLK R170 General Discussion 12 10-12-2017 10:59 AM
1998 SLK Misfire RichardPrann SLK R170 General Discussion 0 01-12-2017 10:16 AM
Poor Running / Intake manifold AZ_JC SLK R172 General Discussion 1 08-09-2015 04:05 PM
Running Issues and more... roachdoggslk SLK R170 General Discussion 6 09-02-2012 09:29 PM
