Manual transmission stiff - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Padgett
  • 2 Post By rossiniere.vaud
  • 1 Post By Mark999
  • 1 Post By Paulwirral
  • 1 Post By neileg
  • 1 Post By dbgrn
  • 1 Post By jet_fl
#1 Old 01-18-2018
Vehicle: SLK 230K, 6 speed manual, 2001
Quoted: 11 Post(s)
Anyone got the 6 speed manual transmission? Mines very stiff moving up from 1st to 2nd, and down from 3rd to 2nd.
Have read changing gearbox oil might help? Going to be about Ł60 to do that at the local MB indy, thought i'd check before potentially throwing money in the wrong direction
oldmanhouse is offline
#2 Old 01-18-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Mine is a little balky when cold but very good once warmed up a bit. Have you checked the oil level ?
1. Raise and support the vehicle.
2. Remove the transmission fill plug.
3. The full fluid level should be at the base of the fill plug threaded hole. If the fluid is low, check for visible transmission fluid leaks and top off the fluid level.
4. Install and tighten the fill plug (1) to 50 N·m (37 ft.lbs.).
5. Lower the vehicle.
Padgett is offline
#3 Old 01-18-2018
Vehicle: R170 SLK320 6-speed man 2000
Quoted: 9 Post(s)
dbgrn and Avel Du like this.
rossiniere.vaud is offline
The Following User Says Thank You to rossiniere.vaud For This Useful Post:
#4 Old 01-18-2018
Quoted: 37 Post(s)
I found a change to redline MTL helped. IIRC Mercedes recommend a reduced fill volume of 1.2L rather than 1.5L to help with this.
I also found bleeding the clutch helps.
Mark
Mark999 is offline
#5 Old 01-18-2018
Vehicle: slc 43 2016
Quoted: 83 Post(s)
I short filled mine with redline , when I had a 230 6 speed , and to be completely honest it didn't make a great deal of difference .
Paulwirral is offline
#6 Old 01-18-2018
Vehicle: 2003 SLK 200K
Quoted: 75 Post(s)
You’re not alone with a second gear problem. Mine is very crunchy 1-2 though 3-2 is ok. I changed the oil for Fuchs Titan fully synth. Every gear change was improved but 1-2 still crunchy unless you ‘ease’ it in. Unless I’m on a hill I usually start in 2. This avoids the issue for me.
I think MB manual boxes are a punishment for not buying an auto!
Cheers Neil
neileg is offline
#7 Old 01-18-2018
Quoted: 2291 Post(s)
Cheers Neil
Did you try the fix in post 3?
Avel Du is online now
#8 Old 01-19-2018
Quoted: 75 Post(s)
Yes Myk. My mechanic measured the oil drained out and that was 1.2l too
Neil
neileg is offline
#9 Old 01-23-2018
Quoted: 11 Post(s)
Originally Posted by rossiniere.vaud View Post
Thanks for this. Is this something sent out from MB head office to dealers? I had read about the 300ml reduction 'unofficially', but this is the first I've seen of some sort of official documentation.
I will look into what the current oil level is. Could well have been done already as the previous owner always had the MB dealership look after it.
#10 Old 01-23-2018
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
That looks like a screengrab from the Mercedes-Benz WIS (Workshop Information System)... available to UK MB-Club members, along with access to EPC (Electronic parts catalogue) - also available elsewhere in the world, but different commercial arrangements may apply.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#11 Old 01-23-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Note: original poster has a 230 and probably needs first. Since I have a 3.2 I usually start in second (2.62:1). For me first gear has few uses:
- going up the side of a wall
- in malls or parades
- stating on a hill
- being antisocial (however a really fast 1-2 near redline is ga-run-teed to trigger the traction control even on a Florida shell road (fractal). OTOH I consider the TC to be essential when it rains.
- teaching someone how to use a clutch (almost impossible to stall).
Padgett is offline
#12 Old 01-23-2018
Quoted: 75 Post(s)
I’ve got a 200k and 1st isn’t very useful.
One possible use you missed out is checking that the traction control is working
Neil
neileg is offline
#13 Old 01-23-2018
Quoted: 214 Post(s)
On my previous car everyone used RedLine also and it is quite good. One of the guys had tried Neo RHD and liked it well, so I tried it also. It is really great stuff, much better than even the RedLine. If you are going to change fluid, I would use that. It isn't cheap, but much cheaper than a trans. The real issue is probably that your synchronizers in your trans are worn.
Gimme Shelter likes this.
jet_fl is offline
R170 Manual Transmission Mount Confusion TrooperSlick SLK R170 class DIY 3 02-02-2019 07:23 PM
DIY manual transmission and diff oil change SeanB SLK R171 Class DIY 33 08-02-2018 03:52 PM
SLK 250 MANUAL TRANSMISSION on a TRACK??? SLKTwoFifty Motorsports 4 10-24-2014 11:08 AM
Manual transmissions getting rarer in the US jbanks15 Off Topic 8 09-16-2014 12:37 PM
Manual transmission? cah1708 SLK R172 General Discussion 21 08-23-2012 03:26 AM
