Autel Maxidiag Elite MD802 - Mercedes Benz SLK Forum
  • 1 Post By bryn
#1 Old 01-16-2018
tich65a's Avatar
Vehicle: 2002 SLK 230
Other Toys: 2002 Mercedes CLK 320 - Guitars - several 100's of vinyl records ...
Quoted: 25 Post(s)
So, been thinking about getting a new scanner. last one I had was Jaguar specific .. so wanted a multi marque one.
after reading and searching plenty of people like this Autel one, so I tried to see what it might do or my two Mercedes. A 2002 SLK 230 and 2003 CLK 320
Anyway I found this download showing exactly what it will, and will not do, so I thought I'd share it with everyone ...
here's the link..
https://pro.auteltech.com/measurecar-1-2.html?m=4
David
tich65a is offline
#2 Old 01-16-2018
Quoted: 1138 Post(s)
here's the link..
http://download908bak.auteltech.net:...20FUNCLIST.pdf
David
It depends if your cars have a 38 pin connection ?
Delucas is online now
#3 Old 01-16-2018
tich65a's Avatar
Quoted: 25 Post(s)
No, OBD11 but you can get a 38/16 adapter of EBay... don't know if would then read as much..
tich65a is offline
#4 Old 01-16-2018
Are you sure no 38pin under bonnet ?
#5 Old 01-16-2018
tich65a's Avatar
Quoted: 25 Post(s)
I can't answer that sorry. I thought that pre 2001 cars had a 38 socket located in the engine compartment, inside a box on the lhs for UK vehicles but I might be wrong.
My SLK 230 has a standard socket under the steering wheel
Found this thread .. may help you
https://www.slkworld.com/slk-r170-gen...170-cheap.html
tich65a is offline
#6 Old 01-16-2018
Some Mercedes still had an obd port under steering but also 38 pin under bonnet
If yours has not one under bonnet then fine .
It was a time period when odb II was crossing over about the 2000 period
#7 Old 01-16-2018
tich65a's Avatar
Quoted: 25 Post(s)
like I said in the OP, my SLK is 2002
tich65a is offline
#8 Old 01-16-2018
Still can have that port !
#9 Old 01-17-2018
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
Hi David Did you actually buy it and try it? I have been on this search for a long time and been in touch with Autel who told me that they did not have a scanner for the R170 with 38 pin socket. I did buy one from a company called Vident an iLink400 that was supposed to work, Im not convinced it does the full range yet because Ive sent it back to check it out. Nice unit but has a boot up issue. I also bought the adaptor cable from 38 pin to OBD2 Keep me posted if you dont mind. Thanks
bryn is offline
#10 Old 01-17-2018
tich65a's Avatar
Quoted: 25 Post(s)
tich65a is offline
#11 Old 01-17-2018
tich65a's Avatar
Quoted: 25 Post(s)
Hi bryn,
Like I said in my op, My SLK is a 2002 so has a 16 pin socket so is OBD 11 compatible. I am not sure if it will fully work with Pre 2001 car with 38 pin... Got a feeling a number of functions are missing, something to do with earlier OBD system...
I'm ordering this weekend so will update...
David
tich65a is offline
#12 Old 01-17-2018
tich65a's Avatar
Quoted: 25 Post(s)
Seems I did not get the link correct..
if you look at this link
https://pro.auteltech.com/measurecar-1-1.html?m=4
you will need to
a) select Maxidiag Elite MD802
b) find Benz All Systems
c) click the download link.
From what I can read this will do for both 16 and 38 pin SLK 170.s - but not all systems can be checked. So please read the pdf file with care...
tich65a is offline
#13 Old 01-17-2018
Quoted: 913 Post(s)
I would really like to do a side-by-side comparison with my Carsoft MI-6.
efair is online now
#14 Old 01-18-2018
Quoted: 16 Post(s)
Thanks, this is the information I was getting from Autel. and you could be right when you say some functions will be missing. I heard from Vident today and they are sending me a replacement scanner, so I will also keep you posted. You should be OK with OBD2 at that age car
tich65a likes this.
bryn is offline
#15 Old 01-18-2018
tich65a's Avatar
Quoted: 25 Post(s)
well, its on the way, so will report back when tested....
one of the things i like over the icarsoft is it can be used for most marques... not that I am thinking of leaving the MB family anytime soon
tich65a is offline
#16 Old 01-26-2018
tich65a's Avatar
Quoted: 25 Post(s)
So, I got it - sadly it only worked on 4 systems, not the whole vehicle, so it went back..
in replacement I bought the iCarsoft MBV1 - the new replacement for the iCarsoft 980...
This stunningly good - does all I will ever want - including the roof mech..
here's the link to the one I bought ..
https://www.ebay.co.uk/itm/TOP-OBD2-...72.m2749.l2649
tich65a is offline
#17 Old 01-26-2018
LeonardoDaBenz's Avatar
Quoted: 1063 Post(s)
Just a note: only for MB.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Best Diagnostic Tool Robrowdy SLK R172 General Discussion 26 11-11-2018 10:45 PM
'97 R170 OBDII app question wayflash SLK R170 General Discussion 20 01-28-2017 04:41 AM
Auto Elite Hull john hannon United Kingdom 2 08-06-2015 02:56 PM
Code Reader MaxiDiag Elite MD702 macman General Discussion 2 06-20-2013 06:26 AM
