'03 Supercharger and Chain Tensioner Questions - Mercedes Benz SLK Forum
  • 1 Post By bobinyelm
#1 Old 01-16-2018
Vehicle: '03 SLK230
Other Toys: Backdraft Cobra
My supercharger has been making diesel sounds (at idle) for some time (despite my SLK having only 40,000mi since brand new), and I am finally wanting to pull it and inspect it.
I have been assured (we'll see) that it's most likely the coupling disk, and have one ready to install.
My question is on removal.
Is it easily removed with the car on a flat surface, or is there any need to have it on a lift?
I have a shop w/ a 2-Post lift, but it's always tied up with friends' cars, so if I could just do it in the bay next to my lift bay (and not tying up the lift while my SLK is apart) it would be preferable.
After removal, I've been told that if I mount it vertically in a vise, I can remove the nose for disk replacement without draining the oil inside (which everyone has told me should be OK at 40k miles). Beside replacing the disk, what inspections or tests should I do, or replacement undertake while the S/C is off the car? How much supercharger oil (GM S/C is what I've been told to use) should I get in preparation should I drain/refill my unit while out of the vehicle?
I also want to change the hydraulic chain tensioner as the first few seconds after start after the car has been sitting a long time always start quiet until the tensioner piston is pushed back, then I hear chain rattle for a second or seconds and a half, then it is utterly silent from then on.
I've been told that the tensioner is supposed to have a one-way ratcheting function specifically so once extended, it will not retract and be noisy while awaiting oil pressure. I purchased a new tensioner, and plan to install it when the supercharger is removed for inspection and whatever else it needs.
Any comments on ANYTHING I've said or proposed would be most welcome!
Bob
bobinyelm is offline
#2 Old 01-16-2018
Quoted: 2282 Post(s)
https://www.slkworld.com/slk-r170-cla...il-change.html
& search gave: Mercedes Benz SLK Forum - Search Results for slk r170 supercharger
Although most of these are not 230 owners, they may still know.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
#3 Old 01-16-2018
Quoted: 133 Post(s)
Pelican is a good tutorial source and here is a link to what you're looking for. https://www.pelicanparts.com/techart...er_Removal.htm
Though you have a low mile vehicle, I'd change the s/c oil anyway. It's cheap. To be warned, the stuff smells terrible.
Mn car guy is offline
#4 Old 01-16-2018
Turdo2's Avatar
Quoted: 361 Post(s)
I have a 230 engine in my shop that I can snap some more pictures of. I don't believe that you need to get under it, as the 4 main supercharger bolts can be accessed from the top, it's really tight though!
You cant get underneath the supercharger anyways because the alternator is there.
Turdo2 is offline
#5 Old 01-16-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 265 Post(s)
Simplify....kick the friends off the lift!
The Toy
Idiot101 is offline
#6 Old 01-16-2018
Vehicle: '03 SLK230
Originally Posted by Turdo2 View Post
The 4 main supercharger bolts can be accessed from the top, it's really tight though!
Attachment 473697
That looks BIG out of the car!
I guess if it's not possible to assist from below, I'm pretty much stuck with the topside.
Thanks,
Bob
#7 Old 01-16-2018
Vehicle: '03 SLK230
I have seen some of the Pelican how-tos but I never saw this one.
Thanks,
Bob
Mn car guy likes this.
'03 SLK230 Supercharger Noise bobinyelm SLK R170 General Discussion 14 01-16-2018 11:22 PM
Oil Leak nstevens27 SLK R170 General Discussion 13 02-26-2017 05:35 PM
230SLK Cam & Supercharger drives... SLK230Auto SLK R170 General Discussion 1 01-30-2014 10:02 AM
Lower Chain Tensioner (How to replace) ricksmol SLK R170 General Discussion 1 09-19-2009 11:35 PM
