turn signals and parking lights aren't working! - Mercedes Benz SLK Forum
 33Likes
#1 Old 01-14-2018
Turdo2's Avatar
Quoted: 361 Post(s)
they just stopped working today while on a drive. anyone have this happen?
the flashers work, but the parking lights (far two left positions on headlight switch) do not.
please advise a fix
thanks!
ps33fount likes this.
Turdo2 is online now
#2 Old 01-14-2018
Quoted: 6544 Post(s)
fuses checked?
#3 Old 01-14-2018
Turdo2's Avatar
Quoted: 361 Post(s)
fuses checked?
yes, although I couldn't find one for the turn signals.
#4 Old 01-14-2018
fuse 4? dashboard
https://www.slkworld.com/slk-r170-cla...x-diagram.html
#5 Old 01-14-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Mr Banks, thank you for keeping me in check!
who would of thought to check the fuse box in the dash??????
(p.s. I found the blown fuse!)
jbanks15, Avel Du and ps33fount like this.
#6 Old 01-14-2018
Turdo2's Avatar
Quoted: 361 Post(s)
see, I dont know EVERYTHING!
you can close this thread if you wish.
jbanks15, Elmer Fudd and ps33fount like this.
#7 Old 01-14-2018
nah....newbies might find it in a 'search'
#8 Old 01-14-2018
Quoted: 133 Post(s)
Dude, You've got crazy mechanical skills jamming a v8 into an slk and you can't find the turn signal fuse? Time for concussion protocol.
Mn car guy is offline
#9 Old 01-14-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Most likely a bit of carbon monoxide poisoning from my leaky exhaust...
In my defense, every single search that came up online said nothing about an interior fuse panel. Most of them were talking about a "comand module", or I assume the K40 relay module. some even said one of the SAM's is bad or to replace the hazard relay (which these don't have as a separate entity)
In all honesty, after doing all the electrical stuff that I did, I just assumed it was something serious..... I'm going to go lay in the fetal position now.
#10 Old 01-15-2018
I had to take 5 points off the above for the misspelling
of
Comand. you spelt/spelled it command
I fixed it for you so the masses would not laugh
Mercedes' Comand — short for Cockpit Management and Data
#11 Old 01-15-2018
Elmer Fudd's Avatar
Quoted: 190 Post(s)
come on Sarge
surely a spell of KP beckons for mis-spelling " foetal ". However I plead his relative youth as a mitigating circumstance.
Elmer Fudd is offline
#12 Old 01-15-2018
Turdo2's Avatar
Quoted: 361 Post(s)
When using them as words that are understood to me by definition, and not someone else's understanding or in relation to a manufacturers trademark, I am not wrong.
#13 Old 01-15-2018
Comand manual says so:
#14 Old 01-15-2018
Turdo2's Avatar
Quoted: 361 Post(s)
There must have been a problem with the translation when they went to English
#15 Old 01-15-2018
ps33fount's Avatar
Vehicle: 2005 SLK55 AMG
Other Toys: too many things to take care of and use properly
Quoted: 83 Post(s)
It must be all caps as well, just to be sure.
ps33fount is offline
#16 Old 01-22-2018
Turdo2's Avatar
Quoted: 361 Post(s)
UPDATE.
the datgum fuse is out again... possible short somewhere?
#17 Old 01-22-2018
Elmer Fudd's Avatar
Quoted: 190 Post(s)
back to basics
probably easiest to whip the bulbs out and check the holders and the bulbs themselves. then get on to the really wiggy stuff.
#18 Old 01-22-2018
Turdo2's Avatar
Quoted: 361 Post(s)
The 2 times it has happened now, it has been when I've had my headlights on.
perhaps those 2 front corner lamps are at fault.
#19 Old 01-24-2018
Elmer Fudd's Avatar
Quoted: 190 Post(s)
wierder and wierder
and you have one of those funny US models that lights up like a christmas tree, so comparisons with my UK model might be limited. Do your front indicators light up as market lights, and then flash brighter as indicators?
#20 Old 01-24-2018
Vehicle: 2003 SLK 200K
Quoted: 75 Post(s)
If we’re being pedantic, I think you meant marker lights
Neil
Elmer Fudd likes this.
neileg is offline
SPYDER Headlights Durkatlon General Modifications R171 374 08-27-2018 08:33 PM
How to fix turn signal hyperflashing if you have LEDs JaysonM SLK R170 class DIY 4 03-03-2015 12:47 PM
