Mystery line? - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By AndyW
  • 1 Post By Anders S SLK02
  • 1 Post By AndyW
#1 Old 01-08-2018
AndyW's Avatar
Other Toys: 2008 335i
Mystery line?
So, I am doing the UCA and LCA job. I removed the battery and battery tray an noticed a severed line (appears to be a gray plastic vacuum hose that attaches to the intake manifold from a stuffing box on the firewall). This was damage done last year when a mouse/rat lived in the engine bay for a bit while the car was parked and turned stuff into nest material. But the car has been running fine. The only thing I can think it is is a vent line from the fuel tank. Any thoughts on what this might be? Pics below.
This is the stuffing box with gray line protruding. The red arrow points to where the other end is.
This is the other (chewed) end under the ECU box.
This is where it connects to the intake manifold.
AndyW is offline
#2 Old 01-09-2018
AndyW's Avatar
Did some internet sleuthing...I believe this is a line for controlling ventilation settings but have never noticed an issue, honestly. I am going to connect it back up with a section of vacuum hose and see what happens.
Idiot101 and RNVSLK like this.
AndyW is offline
#3 Old 01-09-2018
Quoted: 912 Post(s)
I'll guess a vacuum line to operate the flaps in the heater/air conditioner unit.
The ECU can probably compensate for this leakage. I bet if you watch your LTFT and STFT before and after you plug the leak, you'll see them change.
efair is offline
#4 Old 01-09-2018
Quoted: 52 Post(s)
Another possibility is the vacuum line that goes between a headlamp regulating control and he headlamps vacuum bell (adjustment servo).
Most SLK:s with standard halogens doesn't need this device as we seldom load the boot with heavy stuff - therefore, it might go unnoticed for years if it's broken.
So, is there a adjustment wheel for the headlights near headlamp switch, go from there.
nimbusgb likes this.
Anders S SLK02 is offline
#5 Old 01-10-2018
AndyW's Avatar
No headlight adjuster. So it must just be ventilation.
AndyW is offline
#6 Old 01-11-2018
nimbusgb's Avatar
Quoted: 253 Post(s)
If that's a light lilac coloured hose ( faded ) then that's the headlight level adjuster vacuum hose. Under the headlights there is a little diaphragm controlled leveller. It's automagic so you may not have a control knob for it. If your car really does not have a levelling system you will find the hoses blanked off at the headlight. ( No point in having different engine hoses for car with/without so as with a lot of wiring harnesses there's 'optional' stuff that just ends nowhere )
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
#7 Old 01-12-2018
AndyW's Avatar
Well, the only difference after hooking it up was the intake manifold had a knocking sound (PCV valve?) for a bit when I started the car but it appeared to quiet down once the car was warm. Maybe I haven't had a crankcase vacuum for a while? Honestly it almost sounded like a stuck valve lifter at first. I need to research where the PCV valve is on this car...
AndyW is offline
#8 Old 01-13-2018
AndyW's Avatar
More data: The sound is cyclic as the engine idles but am almost 100% certain coming from inside the intake manifold. And i cannot find where there is a PCV valve on this car...230, yes, 320, no.
AndyW is offline
#9 Old 01-13-2018
Quoted: 507 Post(s)
I believe this is your PCV: https://drive.google.com/file/d/1QV3...ew?usp=sharing
mchild is offline
#10 Old 01-13-2018
AndyW's Avatar
Originally Posted by mchild View Post
Thx! I'll look when i get back from travel. That is at the back of the engine, not the front....hmm. makes me wonder if this is something more serious.
AndyW is offline
#11 Old 01-13-2018
AndyW's Avatar
I did record it in a video last night.
https://youtu.be/UoklAgo0ujc
AndyW is offline
Woman Driving Scooby-Doo Mystery Machine Leads Police on Pursuit in California Berliner Heckflosse Off Topic 0 03-09-2016 11:58 AM
My brake line lesson acguy SLK R170 General Discussion 1 02-01-2016 12:52 PM
Mercedes-Benz V-Class AMG Line is a Reality, Will Take a Bow in Frankfurt Berliner Heckflosse Off Topic 0 08-26-2015 02:00 PM
Mercedes-AMG to add entry line to help double sales Berliner Heckflosse Off Topic 0 11-27-2014 07:26 PM
Mercedes to unveil new AMG Sport line in Detroit at 2015 auto show Berliner Heckflosse Off Topic 0 11-27-2014 07:13 PM
