Radio for Bose sound system - Mercedes Benz SLK Forum
 5Likes
#1 Old 01-08-2018
Vehicle: 1996 SLK 200 aut.
Other Toys: Autobianchi Y10 (23), Lancia Dedra (1), VW Golf MK4 (1), Alfa Spider 1750 '71, Alfa GTV '80
Quoted: 7 Post(s)
Hi all.
My car has (i.e. should have) a Bose soundsystem installed. AFAIK, it's based on a booster and six loudspeakers working at two ohms: two 6,5" woofers, two tweeters and a couple of rear 6,5" woofers. The head unit was replaced by a more recent Blaupunkt, which I would like to replace with a Becker.
Googling on the Web (my car is a MY 1996) I realized that the car should have a MB Special radio; unfortunately I found at least three different models - BE2210, BE1350 and BE1650. My goal is to place a Yatour (or similar) hidden module for USB/Aux/Bluetooth - fortunately the CD pinout is common to all the radios above.
I'd like to know the main differences between those radios and which one is "the right one" for my puroposes.
TIA,
Guido
sintoni is offline
#2 Old 01-08-2018
savcom's Avatar
Quoted: 613 Post(s)
Hi @sintoni
A quick response to you. I tried the Yatour unit with a Becker Indianapolis head unit and was not impressed. This may have been because my older Indianapolis was not fully compatible with the Yatour. I'll go back through my notes and see what is or is not compatible with this Bluetooth adapter. Would you mind telling me which Yatour unit you intend to buy?
Oh - and welcome to the forum, by the way.
Also
Previous :
savcom is offline
#3 Old 01-09-2018
Quoted: 7 Post(s)
TY, I have already some Yatour boxes for Alpine M-Bus radios, and sometimes they don't work properly. I have to be very careful to files' names, because sometimes they are not correctly read and the device hangs. BTW, they're the best solution for 20 years old radios like the one I need for my car. Yatour's work is better done by USD50 or something more radios, I'm sure about it.
Cheers,
Guido
sintoni is offline
#4 Old 01-09-2018
savcom's Avatar
Quoted: 613 Post(s)
Here's what I would do.
I'd first get hold of your free datacard. This will give you as much info as is available about what was originally fitted to your car. You may be able to work out which model radio was fitted from that information.
Secondly have a look on this site - there is more information about the various Becker models fitted to SLKs.
Thirdly I'd make sure the Becker you choose works with the Bose system you have installed.
Finally I'd make sure that the Becker you choose has a compatible set of input pins and the right level of firmware to use your Yatour adapter. Check here on Yatour's web site. Also there was a post from someone in the same situation as you here.
Good luck!
Also
Previous :
savcom is offline
#5 Old 01-10-2018
Quoted: 7 Post(s)
TY savcom. From the datacard I can see the car had a MB Special (option 512). I already know that website: they have some very good stuff. Unfortunately, it seems there are three radios which are possible to install: they are Becker BE BE2210, BE1350 and BE1650. Each of them are Bose-compatible (to be fair, most radios are, since the Bose amplifier is a booster which needs a 4V output or similar). Each of them has a 10 pinout output for the CD changer (the link refers to a Yatour module with 8 pinouts: it works on another type of radio, I must guess even with some VW radios such as Golf MK4's Gamma V). I only would like to know if the option code 512 refers to a particular model or the three Beckers are good for my purpose
Thank you,
Guido
sintoni is offline
#6 Old 01-10-2018
savcom's Avatar
Quoted: 613 Post(s)
Have you tried this site? It looks to be a sister site to the link I sent you:
Mercedes Audio 10 CD Alpine Becker Car Radio Player A C CLK E M ML S SL SLK Class
Also
Previous :
savcom is offline
#7 Old 01-13-2018
Quoted: 7 Post(s)
TY. sure, it's a sister site since a lot of internal links are a redirect to car-radio.de. As soon as I get the car, I'm gonna buy a BE1350 from them: the price is a bit higher than the average auctions on Ebay, but the product is refurbished and the cosmetics look great.
Cheers,
Guido
sintoni is offline
#8 Old 01-13-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Am a little confused: why would you replace the stock radio with something else that does not have Bluetooth ?
Padgett is offline
#9 Old 01-14-2018
Quoted: 7 Post(s)
Hi, I'm afraid I made up a little mess. The car I bought comes with a stock Blaupunkt instead of the Mercedes Special (i.e. Becker BE 1350, 1650 or 2210) that should have. Thus, I mainly asked the difference between those three models: my goal is to buy one and retrofit it with a Bluetooth/Aux/USB module.
Below you can see the pics of the car right now, and the data card.
Thank you,
Guido
sintoni is offline
#10 Old 01-15-2018
Vehicle: Slk R170 200K Evo (registration year: 2001)
Re Sintoni
Hello Sintoni, as we are on an international forum, I answer you humbly, giving you some advice in a language understandable to all (rightly).
I have personally tested all the Units you have highlighted, but I have to say that the best ones I have tried are the Becker Indianapolis and Becker Cascade Pro that I still have, but it is very rare to find, at least at affordable prices.
The above units, in my opinion, moreover, are also those that are more suited to the interior design of our SLK R170.
No problem to interface with Bose Audio Sistem (all plug-in).
stormat is offline
#11 Old 01-15-2018
Re Sintoni
I would add that, if you were lucky enough to find a Becker Indianapois PRO, this would have built-in navigator and bluetooth system.
I also add that Becker Cascade PRO already has bluetooth, integrated navigator and can manage a useful memory card up to 2GB.
Good Luck!!
stormat is offline
The Following User Says Thank You to stormat For This Useful Post:
#12 Old 01-15-2018
Quoted: 7 Post(s)
TY stormat. I must admit English is a better way to communicate here than our native language
sintoni is offline
#13 Old 01-15-2018
Vehicle: R170 SLK320 6-speed man 2000
Quoted: 9 Post(s)
Little off topic - I have standard speakers and Becker Indianapolis in my SLK and i have option to buy complete Bose sound system. Is there a very big difference in sound quality? It is worth to buy? It costs about 300$.
rossiniere.vaud is offline
#14 Old 01-15-2018
Quoted: 133 Post(s)
In my opinion, I wouldn't spend the money. It's adequate at best and you could build a pretty nice system for the same money that would sound much better. The bose system is under powered and the subs are terrible. I want to get rid of mine but I'm too lazy.
Mn car guy is offline
#15 Old 01-16-2018
Re
The aspects to be evaluated could be multiple:
1) respect for car integrity and "adherence" to originality
2) pure performance
3) possibility to amplify
I have the Bose Sound System, which is not bad, but I've come to a decent result only by soundproofing the front doors and the rear baffle.
Many people underestimate this aspect, but this aspect is INCREDIBLY effective and makes any audio system much more efficient, it is also universally recognized as the first and indispensable step for all subsequent improvements. Not neglecting the fact that it respects the original appearance of the car and is invisible (very important).
At this point you can allow yourself to develop your audio system project as you wish.
Our SLK have a cockpit that does not reach one cubic meter, so they sound "good" with relatively "little".
Personally, with that buget, I started with a good two-way system piloted by the car radio.
$ 150 for soundproofing + $ 250 for a good two-way system.
Naja likes this.
stormat is offline
#16 Old 01-17-2018
Quoted: 7 Post(s)
At last, I bought those, a Becker BE2215 and a Yatour module: the best way to keep the car the most original possible (@stormat: as all of my cars 'over 20', I want to get a Targa Oro) and to listen to some music. I didn't choose the Bluetooth version of the Yatour, because I don't like drilling holes close to the steering wheel.
Cheers,
Guido
File Type: jpg WhatsApp Image 2018-01-17 at 08.33.20(1).jpg (27.8 KB, 5 views)
File Type: jpg WhatsApp Image 2018-01-17 at 08.33.20.jpg (27.1 KB, 4 views)
sintoni is offline
#17 Old 01-17-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
I have replaced the OEM radio in most of my cars with a BT/hands free head unit. Since I use my cell phone for almost everything just need an amp, speakers, and mag mount. Both of my 170s have the external amp so look more to matching the interior than other things.
Have the original radio for all in big baggies and used adapter cables rather than any cutting/splicing of original harnesses so easy to put back if needful. For me it comes under the heading of "safety" so like properly sized wheels, radial tires, platinum plugs, comfortable seating, and AGM batteries I have no problem swapping the head unit on any car for something more modern.
Padgett is offline
#18 Old 01-17-2018
wozzlegummich's Avatar
Vehicle: R170 SLK230 (not yet)
Quoted: 7 Post(s)
Have a look at the Continental range. But you may have to bypass the Bose amp. I believe there are plug-n-play harnesses available on flea-bay for this.
wozzlegummich is offline
#19 Old 01-17-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Continental TR7412UB-OR looks good but appears to not be for sale in the US. Must come from Germany "at slight additional charge".
Padgett is offline
#20 Old 01-18-2018
DesignoSLK's Avatar
Chats: 2051
Quoted: 55 Post(s)
Man...I have to respectfully disagree with your assessment of the factory Bose amp/speaker setup. I'm running it with the Pioneer AVH-3300NEX (low level outs) and it sounds awesome. No distortion all the way to max volume, and that can be too loud when just sitting at a stoplight.
'Course, if your goal is to compete in an audio rodeo, sure, no comparison. But, for listening with crisp highs and felt lows while motoring about with the top down, Bose did an excellent job of balancing this thing out, IMHO.
Kevin ><>
DesignoSLK is offline
New Sound System for My SLK 280 - Questions digidan SLK R171 General Discussion 13 06-18-2012 09:45 PM
esinmann exausht system sound round tip mrl0n3ly714 Performance MODS for the R171 9 06-12-2011 12:00 PM
Who will pay almost $5,000.00 for a Sound System with a 6 Disc CD player pisani SLK R172 General Discussion 34 03-18-2011 10:37 PM
sound system wolfe slk280 General Discussion 1 06-29-2010 07:25 AM
Poll: Do you have the upgraded sound system? Sid SLK R171 General Discussion 54 08-23-2008 02:18 AM
