Problem with side flaps staying up with roof closed - Mercedes Benz SLK Forum
 9Likes
  • 1 Post By Lincsboy
  • 1 Post By jbanks15
  • 1 Post By Redleader
  • 1 Post By savcom
  • 1 Post By savcom
  • 1 Post By Avel Du
  • 2 Post By Turdo2
#1 Old 12-28-2017
Vehicle: 2003 slk 230 kompresser
Other Toys: Cars
As per the title when the roof is closed the side flaps stay up.
I have had a look around and cannot see why it is doing this and it seems that the microswitches merely identify when the flaps are down.
Has anyone else had this problem and if so what was the cure?
Lincsboy is offline
#2 Old 12-28-2017
Quoted: 6558 Post(s)
I stand corrected
this video is NOT my 55 but one can clearly see the side flaps are flat like the parcel shelf
so both flaps stay vertical?
Let's get the experts and send up the bat signal
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
#3 Old 12-28-2017
Vehicle: 2008 R171 280 in Thulite Red
Other Toys: Holiday home in France
Quoted: 104 Post(s)
Well, just checked mine (R171) and they do not. What could be termed the rear parcel shelf is flat from one side to the other including the end flaps. In Lincsboys 170 the flap at either end is in the vertical position with the roof up as opposed to horizontal
Redleader is offline
#4 Old 12-28-2017
Other Toys: Cars
thanks for your help over the query about the the side flaps on my slk170.
After a bit of research I can confirm that the side flaps are in the vertical position when the roof is closed, my confusion arose after seeing other SLKs with flaps that slide under the parcel shelf when the roof is closed.
Bit of info that might be helpful, we have had frosts in the UK lately and I find the grease on the end locking latches freezes, stopping the roof from operating.
Lincsboy is offline
#5 Old 12-28-2017
I was going to suggest some lithium grease spray on it
also see my edited post 2 above
https://www.slkworld.com/general-disc...ts-hinges.html
#6 Old 12-28-2017
also from the gummi thread above
Benzworld.org - Mercedes-Benz Discussion Forum - View Single Post - Lubing vario roof - pics (1)Krytox (2)grease
and this from Muzu in German:
http://www.wusblum.de/fotos/slk/pfle...hmierblatt.pdf
#7 Old 12-28-2017
savcom's Avatar
Quoted: 610 Post(s)
I've just been up to check (and it's f-f-f-freezing up there!!). Both my flaps are 'up' with the roof closed. I don't think there's room for these to close as they cover the roof supports when the roof is in the boot.
Also
Previous :
savcom is offline
#8 Old 12-28-2017
savcom's Avatar
Quoted: 610 Post(s)
Still looking for an SLK or Mercedes symbol to put in a searchlight, Sarge...
Also
Previous :
savcom is offline
#9 Old 12-28-2017
Thanks!
So now we know
R170, flaps up when closed
R171 and probably R172 flaps down when closed
#10 Old 12-28-2017
Quoted: 2293 Post(s)
Remember this coming up when I first joined.
The 230 flaps definitely don't go flat.
But for the sake of Jeff's sanity,
never, ever refer to them as speakers
Avel Du is online now
#11 Old 12-28-2017
Turdo2's Avatar
Quoted: 361 Post(s)
2nd and 3rd everyone... flaps stay up. lately it's been bugging me because I can see how dirty the flaps are on the bottom!!
savcom and RLander like this.
Turdo2 is offline
Roof Problem #2 MadHungarian SLK R172 General Discussion 10 07-18-2016 11:10 AM
