Which Microswitch? - Mercedes Benz SLK Forum
#1 Old 05-07-2013
Vehicle: 1999 SLK 230, 2001 ML55 AMG
Which Microswitch?
So This weekend i had a dreaded top problem. My top went down fine, we drove to a drive in, it started to drizzle and so I went to put the top up, and the trunk opened but the top did not go up. when i went to put the trunk back down the button started to blink and the trunk stayed up. The hydraulics are working fine with no leaks, so i know that this is not the problem. That leads to the lock cyclendar in the roof not working correctly(?) or a microswitch. I have the top up manually, but I need to get it fixed an am willing to go to in Indy shop to have it fixed right, i just want to give them something to start with.
first of all could it be a problem with the roof lock actuator getting stuck in the locked position when the top os down?
which Microswitch would give me this problem?
any help would be great so I can cut down on the labor rate of diagnosing the problem with the top. If its something easy I wouldnt mind doing it myself.
Also how would you go about getting the roof to work again automaticly?
As always your help is wonderful.
pemsland is offline
#2 Old 05-07-2013
MrG
Vehicle: Black '02 SLK320
I'd start with the 'trunk open' switch. It's fairly easy to get to on the right hand side by the tail light.
MrG is offline
#3 Old 05-07-2013
Yea but if that one didnt work, then the top wouldnt go down also right?
pemsland is offline
#4 Old 05-07-2013
MrG
It would have if the switch failed on that cycle. I assume all was working fine until you put the top down?
MrG is offline
#5 Old 05-07-2013
Well sparadocically it had issues going down, but I attributed those to the microswitches in the roof and greased those and seemed to work..
How do I test that switch now with the top manually up?
Thanks for the good insight.
pemsland is offline
#6 Old 05-07-2013
becuase at first the top just had some sparodic issues going down, and never going up, then i lubed the roof microswitches, and then twice it had the issue of not coming back up, the second being the time that i had to do it manually.
pemsland is offline
#7 Old 05-07-2013
MrG
Sorry. I assumed this was the first problem you had
MrG is offline
#8 Old 05-08-2013
so anyone have an idea of where to start?
pemsland is offline
#9 Old 05-08-2013
Quoted: 919 Post(s)
I'd start by cleaning all the microswitches.
efair is offline
#10 Old 05-08-2013
leapyfish's Avatar
Check the wiring for things like this https://www.slkworld.com/slk-r170-cla...d-my-roof.html
leapyfish is offline
#11 Old 05-16-2013
Took it in to my Indy guy, and he hooked it up to the computer. There was just a simple fauly code for low voltage. He said ti was caused by the top using to much power with the engine not running, which causes random fault to keep the top from working. i never got the exact code number, but I have used it now for a week and no problems since then. It was a lot cheaper than replacing all microswitches and still having problem.
pemsland is offline
r170 roof troubleshooting question: hydraulic pump silent silver99slk230 SLK R170 General Discussion 10 02-14-2019 10:43 PM
Partition MicroSwitch Problem error "close trunk partition" Th3120ck SLK R171 General Discussion 23 07-02-2013 07:45 PM
boot closure microswitch Pucklephil SLK R171 General Discussion 2 06-29-2010 06:04 PM
