Mercedes Slk320 2001 missfire - Mercedes Benz SLK Forum
  • 1 Post By TURNERDV10
  • 1 Post By Nupe
#1 Old 05-07-2013
Vehicle: Mercedes SLK320 2000
Hi again I ve got a slight miss fire only at idle I have tried the following so far:
Ive changed the plugs
Ive changed the Air flow meter
Ive changed ALL the mounts
Ive smoked all the vacuum hoses for air leaks
Ive also put the coils etc on a scope and the only thing I can find is a slight variation on the negative side of the low voltage coil. Basically I believe it should be smooth and im getting a spike every so often.....
Any more ideas please
TURNERDV10 is offline
#2 Old 05-07-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
I don't know if you'll find this thread helpful or not but it couldn't hurt:
https://www.slkworld.com/slk-r170-gen...ed-lights.html
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#3 Old 05-08-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
I've had a very, very slight surge and some unevenness at low power and low load on my 2002 320 slk. Played around with a few things, replaced air filters and I'm waiting on a fuel pump but in the past couple of weeks I've had 4 or 5 instances of bad misfiring on 1 and 2 and the last time on 3 as well, requiring the engine check light to be reset with my torque setup.
Today the latest misfiring was accompanied by an error log of a suspect 02 sensor on the same side of the engine so I have ordered a replacement ( 35 on eBay as opposed to 235 from Merc! )
I'll replace it when it arrives and let you know if it fixes my problem.
With the removed item I can plug it in to the other bank and see if the fault follows the sensor.
nimbusgb is offline
#4 Old 05-08-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Good luck!
Margie and Terry
tcrankwa is offline
#5 Old 05-09-2013
Vehicle: 2000 SLK 320
I had the same thing new plug leads fixed it.
Roy
Roy S is offline
#6 Old 05-10-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Replaced lambda sensor this afternoon, off sailing for two weeks in Greece so really won't get to test it until month end but it does seem smoother in the short test drive I did.
Here's hoping!
nimbusgb is offline
#7 Old 05-28-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Hmm problem still not fixed. Suspect fuel pump is on the way out.
nimbusgb is offline
#8 Old 05-28-2013
Done a engine compression test all fine. Spoke to mercsed they said def fit a geniune Mercedes Air flow meter I said I had fitted a Bosch one and they were trying to tell me thats not geniune. Hmmmm I give up on Mercedes as they said fitting a geniune one will solve it. I tried to tell them the one they sell is Bosch they said no it isnt. I let them ordewr the part in and I said if its Bosch I dont want it. Got a phone call to say its not bosch its a geniune mercedes and this will def solve the problem. I opened up the mercedes box.............Guess what Its got Bosch stamped on it. A few arguments later them trying to tell me its a geniune mercedes Bosch one which is different. I phoned up Bosch in harefield and they told me they supply to Mercedes and Mercedes re package them into there own brand. I rest my case....So they wanted to sell me a part for 279 which I can purchase in Bosch for 96+vat.
M4rCu5 likes this.
#9 Old 05-30-2013
Vehicle: 2001 SLK320. Silver/black (Manual Trans)
Other Toys: 2011 Ducati Streetfighter
I had the Bosch air flow meter and it didn't improve things. I switched to the Mercedes branded one (stamped with Bosch) and ran smoothly from that point forward. From what was explained to me, Bosch manufactures one based specifically on Mercedes specifications and can not duplicate the exact part outside of that. Bosch does make others that appear to be the same but does not meet the technical specs and doesn't perform the same.
M4rCu5 likes this.
Nupe is offline
2001 SLK320 For Sale $8650 slk8907 SLK Cars For Sale 12 07-03-2013 06:05 PM
Lots of Codes- 2001 SLK320 scholaejuris SLK R170 General Discussion 8 08-31-2010 05:06 PM
First Time owner of a mercedes - 2001 SLK230 Kompressor W/sport Pkg Buxieda New Members Introduce Yourself Here 27 04-24-2010 08:39 PM
New 2001 SLK320 Owner Jerminator New Members Introduce Yourself Here 13 04-03-2010 02:13 AM
