bas esp/ abs/speedo - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By jbanks15
  • 1 Post By Turdo2
#1 Old 12-21-2017
Vehicle: 2001 320 slk
bas esp/ abs/speedo
well guys the bas esp and abs light is on , the speedo quit working, cleaned the speedo sending ring , and it worked for a bloock and quit, just changed the left and right sensors, no change..also have the po500 light on , it did not change either...pulled the brake switch...brake lights work and the other plug seems to operate when the sensor is pressed...pressing it opens one set, and closes the other....ideas?what else would give a 500 code plus bas esp and abs light?....thanks...
#2 Old 12-21-2017
Quoted: 6545 Post(s)
Send up the bat signal!
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
Avel Du and RLander like this.
#3 Old 12-21-2017
Turdo2's Avatar
Quoted: 361 Post(s)
Sounds straight forward to me - speed sensor issue.
there are a couple of finicky little parts inside the assembly that bolts to the transmission - alignment of that little cog is also pretty critical. did you pull enough of the assembly out to look at the condition of the gear?
Turdo2 is offline
#4 Old 12-21-2017
manual 6 speed..does it have a sensor too?
#5 Old 12-21-2017
Send up the bat signal!....?
#6 Old 12-21-2017
savcom's Avatar
Quoted: 609 Post(s)
Nearest I could find to a Mercedes-shaped searchlight....
There isn't a direct signal to measure on the instrument cluster when the BAS/ASR light illuminates - that's done as a signal over the CAN bus. I have a copy of the wiring diagram and diagnostic info for the BAS/ESP module which should help you piece together what's happening and what has failed. PM me your email address and I'll drop the details to you right away. Please be quick - I'm not near my computer from Saturday for a week. (Happy Holidays by the way)
Savcom
Also
Previous :
savcom is offline
#7 Old 01-10-2018
wheel speed sensor, speddometer, po500
Guys, still have a p0500 a code on the 2001 320...any more ideas, changed the the two front ones checked both back ones..they had about 19 ohms each and were the same...any other connectors before they go where ever? do they have a relay or what else would make the vss on the md 808 show vss equals zero?....
#8 Old 01-10-2018
TFP
TFP's Avatar
Vehicle: 02 SLK32 AMG
Quoted: 151 Post(s)
Assuming you've gone through the suggestions in your other thread ................
Have you you gone through a drive cycle after clearing all the codes with your scanner ?
Firstly check that all the connections at the vehicle speed sensors are solid, clear all the codes, and then take her out for some mixed driving.
Gently at first, and if the CEL hasn't come back on and she's properly warmed up, give her some beans.
Oh, and a fully charged battery is a must on the R170
TFP is offline
#9 Old 01-11-2018
battery fully charged, trying to clear the code so i can attempt a drive cycle..without speed, i dont think it can do a drive cycle....id like to find where the speed sensors lead so i can furthur trouble shoot it....
#10 Old 01-12-2018
Vehicle: 1999 SLK 230 Bahama Blue
I had the exact same thing with the same code and it turned out to be the K40 after trying everything under the sun including inspecting and re-soldering (looked perfect) the old K40 ... I went to an indie for the diagnostic after replacing abs sensors pump etc.
Naja is offline
#11 Old 01-13-2018
well, i can shotgun it by buying another k 40,,,any one know what functions the other two ecu s next to the k 40 perform, i understand at least one cannot be just changed with out programing..is that true?
Is it the ESP Module? 2nd Opinion Appreciated Waiheke Tires, Wheels, Brakes & Suspension 8 04-02-2019 06:17 PM
3 malfunctions: ABS, BAS and ESP with power steering getting unserviceable benlapi SLK R171 General Discussion 24 08-18-2017 04:54 PM
BAS ESP Light ian320 SLK R170 General Discussion 8 11-05-2014 11:19 AM
ESP Defective, BAS Defective fleep SLK R171 General Discussion 12 04-20-2010 06:12 PM
