OK to fit Battery Isolator - Mercedes Benz SLK Forum
  • 1 Post By Padgett
#1 Old 12-15-2017
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
Question OK to fit Battery Isolator
Coming up to the time of year that I will lay the car up for about 4 Months.
Are there any Pros/Cons to fitting a battery isolator, to stop it running down, as the Electronics System on a R170 Slk seems fragile from all I have read.
They are on Ebay at about Ł6.00.
Thoughts please ??
ixion is offline
#2 Old 12-15-2017
Quoted: 52 Post(s)
Thoughts please ??
Do you plan to use the battery isolator often? The thing is that simply lifting off the positive battery connector is free, and give the same functionality. As for "using it often", that means that your clock need to be reset, your radio will forget it's codes and the like. This is something that may be tolerated once a year, but perhaps not every week or day.
I have one of these: ( https://www.ebay.com/itm/Car-Motorcy...8AAOSwuzRXcjwN ). I also have a 5A fuse that overrides it. This means that if I use the isolator, everything needing current to memories work, but no one can start the motor or even turn on the ignition (that will blow the fuse).
But really, just remove the connector if you think that the car and battery need to be isolated.
Also, keep in mind that any standard car battery, left to itself will discharge and deteriorate if left for four months. Charging overnight at least every four weeks is good for the battery. If you are super careful, you may remove the battery and put it in a convenient place for charging it (like, at home).
Anders S SLK02 is offline
#3 Old 12-15-2017
Quoted: 2293 Post(s)
Have a read of the threads about using a battery tender (if that's practical for you).
Connecting/Disconnecting the battery gives the system a kick in the pants.
Occasionally, this causes some glitches with various electronics.
Avel Du is online now
#4 Old 12-15-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Just pulled the codes on a Merc and as usual there were no warning lights but a whole slew (over 30) codes mostly for "Low Voltage" from a battery change. This will happen each time you pull the battery (why I use a clamp on ammeter to check quiescent battery draw).
I use float chargers and most of my batteries are AGMs. Am into the seventh year on at least one. Used to have to change a battery once a year.
ps Sam's Club has a sale on Duracell AGMs during the holiday season.
Anders S SLK02 likes this.
Padgett is offline
Battery charger oldmercman SLK R172 General Discussion 33 11-07-2016 11:08 AM
Battery / Alternator low voltage problems nmslk SLK R171 General Discussion 24 05-08-2016 01:06 PM
Swiss Scientists Develop Cheap Battery Made of Materials That Are Abundant Berliner Heckflosse Off Topic 1 11-16-2015 01:10 PM
battery Dimension vvergara General Discussion 8 07-24-2013 06:40 PM
