Terraclean - Mercedes Benz SLK Forum
 7Likes
#1 Old 05-06-2013
Jamin101's Avatar
Vehicle: Slk R170 230
Terraclean
Found a place just down the road doing a Terraclean service, anybody have any experiences good or bad to share about the process?
Jamin101 is offline
The Following User Says Thank You to Jamin101 For This Useful Post:
#2 Old 05-06-2013
Quoted: 6540 Post(s)
if that is the same as 'fuel system service' for $159, i had that done by mb
#3 Old 05-06-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Basically, they remove all the old snake oil, and replace with fresh. (Seriously though, if you use good fuel, there is no need, save your money - unless you like the idea of 'molecular injectors'!!! ).
jbanks15 and CSMLET like this.
Woolly is offline
#4 Old 05-06-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Wouldn't this be the same as a fluid flush?
slk320chick is offline
#5 Old 05-06-2013
here it is:
fuel injection service - consisting of:
carbon removal/vacuflush
fuel-injector cleaner/fuel-injector flush/pressure flush
throttle-body and intake cleaner
fuel-system cleaner (also known as Techron concentrate which I do anyway every 3000 miles).
#6 Old 05-06-2013
Found it!!!!
https://www.slkworld.com/482065-post15.html
#7 Old 05-06-2013
Jamin101's Avatar
Terraclean
http://www.columbusautos.org.uk/Terraclean
http://www.terraclean.co.uk/
Seems very similar to the above post and seems to get some really positive feedback from other forums, my car has done 82k I don't have a huge of history so it just seemed an interesting option for not a huge amount of
Jamin101 is offline
#8 Old 05-06-2013
well, it was only $159 here in the states which was not a lot of $ even for MB service
#9 Old 05-06-2013
Jamin101's Avatar
and what is your opinion on it Jeff? worth it or snake oil?
Jamin101 is offline
#10 Old 05-06-2013
i noticed the difference when mb did mine. i think i had it done at 60k.
if it was mb i would say, ok. anyone else, no matter how impressive a website or consumer comments are, i am leery. why don't you try the techron treatment yourself (one bottle couldn't hurt) and see how it performs?
#11 Old 05-06-2013
https://www.slkworld.com/general-disc...esitation.html
#12 Old 05-06-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
An interesting point about Terraclean:-
As a part of the Terraclean service they also apparently clean the idle speed controller and the throttle body, which may explain why some people report a smoother idle after the service is done rather then the Terraclean itself. They also disconnected the battery I think which resets the ECU so if your car has a mild idle issue due to your ECU compensating for a learned problem, it won't show up right away after this service is performed I imagine, it'd take a bit for the ECU to relearn the problem which may make it seem like it's fixed your issue at first.
The actual Terraclean fluid is mostly petrol with a few standard petrol additives in it (data sheet attached). If you use a premium petrol in your car (as per MB spec (e.g. Shell V-Power Nitro)) you will get the advantage of these additives all the time, and not just for two 20 minute sessions (standard Terraclean procedure).
One of the biggest 'media' exponents of the system 'Ed China' actually works for them - a fact he tends to keep a little bit quiet about - I wonder why?!!!
Woolly is offline
#13 Old 05-06-2013
Minion
Quoted: 148 Post(s)
Walmart was out of it, but auto depot had it, as well as autozone here in IL. The slk has a full tank so it has to wait until the next fill up but the Jeep was on E, a perfect time to use it.
thanks JB
#14 Old 05-22-2013
Minion
Quoted: 148 Post(s)
Last nights dinner part 3
I had a date with a mechanic. He asked for a ride in Bella, of course I would never say no to anyone for that. At the end of the ride, I dropped him at his car and we sat there idle for about 15 minutes. As he was about to leave he said "you know there is a slight hum coming from the engine when was the last time you had this serviced". Then I went through the check list and told him I have only owned it a month. He then said "your pistons probably need cleaning this is what you do, wait until you're down to 1/4 of a tank and"
I cut him off and said "put in a fuel additive?"
he replied "yes, you should use"
I cut him off again and said "techron"
his eyes got big and he laughed and said "yeah how do you know.."
I cut him off for the final time "did it yesterday morning, now im going to drive it like I stole it to see if it works..I got this"
Hand to god.. I could not make this stuff up. GO ON JB WITH YOUR BAD SELF!!!
#15 Old 05-22-2013
Supercharged591's Avatar
Vehicle: 2013 SLK 250 CDI AMG Sport
Other Toys: Team GB Shooter , Range Rover Sport & 911 Carrera S
Jist taking off here in the UK..............Its very good !!
Supercharged591 is offline
#16 Old 05-22-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
What for? .
Woolly is offline
#17 Old 05-22-2013
.................To clean your engine ????????????????????????????
#18 Old 05-22-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Hmm - not convinced. If you use the recommended fuel, you shouldn't need it
Woolly is offline
#19 Old 05-22-2013
Phil.UK's Avatar
Vehicle: SLK 350
Other Toys: C250 CDi AMG Sport Coupe
slightly confused
what would you guys recommend, is this something I should consider doing ?
My SLK got something like 82k on the clock
Thanks for your thoughts
Phil
Phil.UK is offline
#20 Old 05-22-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If you run your car on a good fuel - such as Shell V Power Nitro +, you shouldn't need any additives.
Phil.UK likes this.
Woolly is offline
