Self leveling sensor SLK32 AMG - Mercedes Benz SLK Forum
  • 1 Post By rossiniere.vaud
#1 Old 12-11-2017
Vehicle: 2002 SLK32 AMG
Other Toys: E55 AMG
Hi
I have a 2002 SLK32AMG, I've been having problems with the HID headlamps. When you first switch them on they do a kind of "nod" before settling in place. Recently they've stopped doing that, so I had my mechanic take a look. Turns out that the sensor which attaches to the suspension has rotted away and needs replacing, problem is according to MB UK the sensor is no longer available. Do any of you know if a sensor from another Mercedes model might be adapted to fit?
Tony
icarus51 is offline
#2 Old 12-11-2017
Quoted: 2282 Post(s)
@stu32 might know a source.
#3 Old 12-11-2017
Quoted: 133 Post(s)
Mn car guy is offline
#4 Old 12-11-2017
Other Toys: Ginetta G32
Quoted: 92 Post(s)
I think it is the same as a C class W203 etc. Available on ebay as an aftermarket part.
https://www.ebay.co.uk/itm/SWAG-Xeno...sAAOSwn5RZjAmn
or Febi Bilstein part No. 34586
stu32 is offline
#5 Old 12-11-2017
Vehicle: R170 SLK320 6-speed man 2000
Quoted: 9 Post(s)
Or OE No. A0105427717
Important thing - after replace sender, you must use Star Diagnosis system, enter to HRA module and set zero position of range adjustment. After that, you should check and correct lights range.
Without that, HRA system can incorrectly adjusting headlamps range depending of ride heigh.
rossiniere.vaud is offline
#6 Old 12-12-2017
murat orhan's Avatar
Quoted: 26 Post(s)
rossiniere.vaud, any idea about the need for Star Diagnosis adjustment if new headlight units (oem with xenon) are fitted?
After switching to a new set of oem headlight units, bulb out warning comes on a few seconds after low beams (xenons) are turned on. (up-down movement is okay at start-up and both level sensors read some voltage on my obd scanner, but I do not have the Star for further diagnosis.)
murat orhan is offline
#7 Old 12-12-2017
Other Toys: E55 AMG
Thanks for all your replies. I didn't realise that the part was available on the bay of plenty. I I'll look into getting one asap. My mechanic does have star so he can setup the headlight range correctly.
Tony
icarus51 is offline
#8 Old 12-12-2017
Quoted: 9 Post(s)
Hm, that's strange. You don't need SD after retrofitting, because there is no coding options for xenon headlamps in any module. I also have retrofitted OE Bosch headlights with self-leveling and cleaning system and don't have bulb out warning. Can you check OE number on headlamp switch? We can compare it with what I have.
There was no problem with it with normal headlamps (before retrofitting)?
(and sorry for my languages and grammar mistakes).
#9 Old 12-12-2017
Quoted: 26 Post(s)
No problems before. Actually, I did not retrofit. Just bought new units as both reflectors and all cable insulations inside were gone. The car has oem xenons from the factory with washers and leveling sensors. But after installing the new units I cannot get rid of the warning light just after xenons are fired. Some times takes upto 15-20 seconds to error. (But lights and leveling works perfect, and no errors on until xenons are on, including pos 1 for parking lights. Turn the switch from II to I and the warning is off) I use standard Osram D2R for winter and CBI for summer but no changei in situation.
Can I pull codes or see any details for bulb warning light, on Star?
#10 Old 12-12-2017
Quoted: 9 Post(s)
No, this system does not offer diagnostics.
Have you tried to mount old xenon control units to new headlamps and check what will happen? They are mounted under the lamps.
murat orhan likes this.
Mercedes Celebrates 50 Years Of AMG With Special GT3 Edition 50 Berliner Heckflosse Off Topic 0 05-27-2017 01:48 PM
2016 Mercedes-Benz GLE450 AMG Sport Coupe: First Drive Berliner Heckflosse Off Topic 0 10-14-2015 01:00 PM
Mercedes will task dealers to step it up for AMG Berliner Heckflosse Off Topic 0 10-12-2015 01:33 AM
Mercedes to unveil new AMG Sport line in Detroit at 2015 auto show Berliner Heckflosse Off Topic 0 11-27-2014 07:13 PM
Recognizing cars: Mercedes-Benz SLK55 AMG jameslk55 SLK R171 General Discussion 3 05-08-2014 03:58 PM
