Alarm Question - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Avel Du
  • 1 Post By Delucas
  • 1 Post By BlanPrivate
  • 2 Post By rossiniere.vaud
#1 Old 12-09-2017
unclet's Avatar
Vehicle: 2000 SLK230
Other Toys: '95 Corvette
Alarm Question
I have a couple of questions about our 2000 SLK230 's alarm. First should there be any audible sound when locking? Also how can I check the alarm? I rolled the window down and locked the car and reached in and opened the door from the inside. Nothing. Shouldn't the alarm have gone off ?
unclet is offline
#2 Old 12-09-2017
LeonardoDaBenz's Avatar
Quoted: 1069 Post(s)
Don't know your car but: you have keyless entry? Key in your pocket when you manually unlocked? Yes = no alarm.
If not: disregard
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#3 Old 12-10-2017
Quoted: 2303 Post(s)
If not: disregard
Key entry back then, Len.
Sounds like it is not working.
The only sound I heard on my 230 was the lock actuating, no beeps.
Do a search.
From memory it's likely the PSE, or K40 you need to check first.
PSE can get wet, K40 may just need resoldering due to micro cracks in the original solder (age).
R170 diy section
#4 Old 12-10-2017
Vehicle: 2000 SLK 320
Other Toys: Triumph Tiger 955i, Honda CB1 (CB400f)
Quoted: 18 Post(s)
There's no beep on locking & mine takes a short time to arm. Here's how I checked mine.
Lock car using remote. Wait until the red light on the tow button starts to flash ( on my 2000 320 it's the one below the radio on the right) then unlock the car using the key. Open the door & if it's working, cover your ears.
Lee337 is offline
#5 Old 12-10-2017
Quoted: 1138 Post(s)
Do a search.
R170 diy section
Keyless entry was about back then but on the High end Mercs
More than likely key alarm box faulty
Do the flashes flash when putting hand in car but no alarm sound ?
Id lean towards alarm box first .
Delucas is offline
#6 Old 12-10-2017
Vehicle: 280 2008 facelift
Hi
Sounds like u have the old leaky battery in your alarm box . Which happens anytime after 10 years.
My alarm wasn't making any noise just hazards where flashing when opened . I elected to buy new alarm from Mercedes and was Ł96 I think. problem was solved and with new alarms they make audible bleeps when turning on and off. But the other thing I found was the interior sensors where turned off by star diagnostics and had to get that turned back on. By the way I think interior sensors only work when roof is up!!.
Hope this helps
Keith
savcom likes this.
BlanPrivate is offline
#7 Old 12-10-2017
unclet's Avatar
Strange Thing... I just went out and tried again and the alarm works. Thanks for all the replies . Remote seems to work good. Everything works when locked the console fuel door and such. Just can't get the alarm to sound. Did I miss something in the earlier posts?
unclet is offline
#8 Old 12-11-2017
murat orhan's Avatar
Quoted: 29 Post(s)
Mine beeps one time when I unlock with the remote. And 3 times upon locking. But beeps 2 times or less if you left the hood or any door open.
murat orhan is online now
#9 Old 12-11-2017
Vehicle: 2003 SLK 200K
Quoted: 75 Post(s)
I can’t lock my car at work because it usually won’t unlock.
I suspect the phone mast 25m away is the culprit.
Cheers Neil
neileg is offline
#10 Old 12-11-2017
Vehicle: R170 SLK320 6-speed man 2000
Quoted: 9 Post(s)
If you have factory alarm, you can enable audible notification when arm and disarm alarm using remote control. To do that, you must use Star Diagnosis system, enter to EDW module, control unit programming and change country to Netherlands. In the next step you can also select the volume of notifications.
murat orhan and Naja like this.
rossiniere.vaud is offline
Yet another R170 alarm question tsberkey SLK R170 General Discussion 34 12-04-2017 01:27 PM
Can the Alarm go off due to leaking roof? PaulXLE SLK R170 General Discussion 18 04-02-2017 04:21 PM
The dumbest question ever. (alarm) Charlie350 SLK R172 General Discussion 9 01-24-2017 02:30 PM
Strange alarm issue Slk200Tr SLK R170 General Discussion 0 11-19-2013 11:16 AM
Mbrace alarm activation zich6 General Discussion 41 06-10-2010 10:49 PM
