Does the DIY heated seat repair last? - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By S/RConcepts
#1 Old 12-03-2017
Vehicle: SLK32 '03
Other Toys: 2002 SV650S
Quoted: 7 Post(s)
Hey Folks,
I'm curious if the people that have chosen to repair their own seats by re-soldering broken elements ultimately have to repeat the work or choose to instead install a carbon-fiber aftermarket element. There's plenty of good write-ups for both, and I'm leaning towards a repair instead of an aftermarket replacement. I currently only have a working passenger back heat.
What specs do you have to match when buying the aftermarket pieces?
Thanks!
mistergoodpepper is offline
#2 Old 12-04-2017
Quoted: 2293 Post(s)
You've obviously been reading the right threads.
There is little sign of folks coming back on and saying "here we go again, seat failure".
I guess that says that the repair is good.
Avel Du is online now
#3 Old 12-04-2017
Vehicle: '02 SLK32 AMG
Quoted: 52 Post(s)
Man, this just reminded me that my driver's side ones are out! With it being a bit chilly out, it would be nice to fix them. I found these, which are 27 cm X 48 cm (or 10.5" x 19"), which seems like a good size. For $16, I'm going to take the chance! https://www.ebay.com/itm/Universal-2...paAu16&vxp=mtr
S/RConcepts is offline
#4 Old 12-09-2017
Quoted: 52 Post(s)
Just an update on this- I received the heater pads I listed above today. I slid them inside the seat (they fit perfectly), soldered them into the factory wiring, and put everything back together. Turned the key on ACC, pressed the button, and waited... success! Time will tell how long they last, but at only $16/pair, I'm happy with how it turned out!
#5 Old 12-15-2017
Vehicle: SLK32 AMG (2002)
Other Toys: Yamaha FZ1 (gen1) and DRZ400E
Quoted: 43 Post(s)
I don't suppose you took any photos on how you done this and how easy it was to gain access into the seat and what wires exactly you needed to connect to? Did you need to remove the seat etc?
Yes, from my question, you can guess my heated seats have gone also but both backs work fine.
Steve
steve pring is offline
#6 Old 12-15-2017
Trev5's Avatar
Quoted: 316 Post(s)
My Chief Navigator (& any random passengers that threaten to do so) are under strict instructions to NEVER kneel on the SLK seats.....
...and I've never been tempted to kneel on the seats to clean the inside of the rear windows & also
put My hand on the centre console, when leaning in to retrieve stuff from the car:
So luckily, mine are still both working
But My (2001) 406 Coupe heated drivers seat stopped working & I soldered the heater element lead
back together with a bit of heat shrink tubing, about 60,000 miles & many years ago & still working
The Peugeot heater seat element are covered in a cotton type coating and could see one of the brakes
due to a burn mark..!!
But the second brake was found using needle work type pins, on the end of My Fluke Meter leads,
to prick through the insulation, to find the 2nd location....!!
Trev5 is offline
#7 Old 12-15-2017
Quoted: 52 Post(s)
Steve
Sadly, I did not take any photos of this, as there was a nice writeup already in post #8 of the second link in the OP's post- Mercedes-Benz Forum - View Single Post - Inexpensive seat heater replacements
I did remove the seat from the vehicle, and the proper wires to connect to are the ones that are in the center of the seat cushion- you'll see them right away. It wasn't a terribly difficult job, but I made certain to take my time so I didn't damage anything.
Also, they're still working wonderfully!
The Following User Says Thank You to S/RConcepts For This Useful Post:
#8 Old 12-16-2017
Quoted: 43 Post(s)
Did the connectors on the Carbon Fiber Auto Car SUV Seat Heated Heater Heating Pad you purchased in that link, just connect straight into the original Mercedes one or did you need to wire it in . I ask because I'm not too good with electrics . For that read hopeless
If they do just connect in, I think I will have a go at this
Thanks again
Steve
#9 Old 12-16-2017
Quoted: 52 Post(s)
Thanks again
Steve
Unfortunately, they don't... however, there's only 2 wires that you need to connect, so it's very easy! Just cut, strip, twist them together, and tape them. I soldered mine together and heat-shrunk them, but if you cannot do this it really won't affect anything. I don't believe even polarity matters here. To put it this way- if you can get the seat out of the vehicle by yourself, you're more than capable of doing the rest of the job.
How to guide: Remove and repair heated seats mrrossi SLK R171 Class DIY 51 12-12-2018 05:14 PM
DIY: R171 Seat Heater Repair efair SLK R171 Class DIY 12 02-21-2016 08:39 AM
Seat base removal - and are they swappable? mrrossi SLK R171 General Discussion 26 12-12-2014 10:31 AM
