On Board Diagnostics - Mercedes Benz SLK Forum
 11Likes
#1 Old 11-27-2017
Vehicle: SLC 180 2018 White
I hope someone in and around the Manchester UK area (I live in Tameside) can help me. I want to make contact with someone who has equipment to scan a pre-2000 SLK 230 Kompressor (38 pin type found under the bonnet). I want to buy some equipment to do the same and seen so many types online, that I am totally confused as well as being a novice. Im really looking for a hand held unit sub 60 or software to run on a PC. Hope someone can help. Thanks.
trebor80b is offline
#2 Old 11-27-2017
Quoted: 2303 Post(s)
@nimbusgb is this something your system will do?
He could either join us on Sunday, or arrange a trip out.
#3 Old 11-27-2017
nimbusgb's Avatar
Quoted: 253 Post(s)
Yes my Star system has the multiplexer for the 38 pin header so it should be OK.
jbanks15, Avel Du and ps33fount like this.
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
#4 Old 11-27-2017
@trebor80b
@nimbusgb is kindly bringing his kit to Sunday's event:
https://www.slkworld.com/united-kingd...xmas-meet.html
Let us know if you want to join us there, or want to make arrangements to meet at another time.
Ian is in North Wales.
#5 Old 11-27-2017
Thank you for the offer, it is appreciated. Is the Star system expensive only I was looking for something that I can see working and within my budget (sub 60)? I dont have any issues at the moment, just wanted to look around the system to familiarise myself with whats what.
#6 Old 11-27-2017
Quoted: 6580 Post(s)
It ain't cheap
check ebay
Mercedes Star Diagnosis: Automotive Tools & Supplies | eBay
you might just want to get a mbii scanner or something similar
iCarsoft MB II for Mercedes-Benz / Sprinter / Smart_Benz Scan Tools
#7 Old 11-27-2017
Thanks Jeff. Ill check these out.
#8 Old 11-27-2017
Just looked at the suggested types. Star Diagnostics is way out of my budget, so thanks nimbusgb for the offer, but not what I was after. I was looking at something like this hand held unit https://www.ebay.co.uk/itm/Autel-Aut...gAAOSwPK1ZVwyU
#9 Old 11-27-2017
don't confuse a scanner with a code reader
There is a difference
If both, that is good
#10 Old 11-27-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
For a 171 or 172, Carly Pro for Mercedes does nearly everthing with in-depth reports. Unfortunately it does not handle R170s. So far the best thing I've found is Torque Pro for Android but dongles require 16 pin OBD connector. For 38 pin connector I do not know what is needed.
Padgett is offline
The Following User Says Thank You to Padgett For This Useful Post:
#11 Old 11-27-2017
Please enlighten me of the Jeff.
#12 Old 11-27-2017
? of the Jeff?
a code reader reads the codes
a scanner can read codes and then can diagnose and clear codes
https://www.lifewire.com/code-reader...an-tool-534865
https://www.yourmechanic.com/article...a-code-scanner
#13 Old 11-27-2017
Sorry for the typo Jeff, Im getting tired, nearly my bedtime! Thanks again for the help, it is appreciated.
#14 Old 11-28-2017
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
Hi trebor
i am trying to do the same and have been asking here for weeks. Its very confusing and nobody can give a straight answer. If you do find the right scanner please let me know, I will do the same for you of course.
bryn is offline
The Following User Says Thank You to bryn For This Useful Post:
#15 Old 11-28-2017
Quoted: 1138 Post(s)
Carly pro is no good for your req ! and does not do much any way to basic .
I car soft although is quite good again no good as does not come with 38pin connector unless its available seperatley but may not support your car ?
Star is the way to go but Expensive
60.00 will prob buy you rubbish
Autel one again it req the lead with 38 pin
And you may have to up your 60.00 the more you pay the better .
Make sure it supports the 170 with 38 pin not odbII port as such .
Delucas is offline
The Following 2 Users Say Thank You to Delucas For This Useful Post:
#16 Old 11-28-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Anyone have experience with 38 to 16 pin OBD adapters like this ? If works then the most cost effective scanner I've found for a R170 (said CP did not work here) is Torque Pro. Any issues they have a good forum.
Padgett is offline
#17 Old 11-28-2017
Saw this on YouTube, any thoughts?
#18 Old 11-28-2017
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
I have the Icarsoft MB II. It works super good, but I don't know about your car. If you check:
www.icarsoft.us_Professional Auto Diagnostic Scan Tool
You can determine if and what will work for your ride.
SilverSLK2010 is offline
The Following User Says Thank You to SilverSLK2010 For This Useful Post:
#19 Old 11-28-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Am still looking for the One True Answer for my OBD cars but if I had one with a 38 pin connector, I'd buy the $9 adapter cable & connect a BT dongle and see what happens.. The OBD-II standard took effect in the US in 1996.
Padgett is offline
#20 Old 12-03-2017
nimbusgb's Avatar
Quoted: 253 Post(s)
I bought one of those adaptors when I had my first 170. The problem is that it only picks up one of the several busses that are routed to the 38 pin connector. Iirc I could only pick up basic info and I never managed to reset any codes with other Carly or torque pro. ( why I ended up buying a star system )
I'm into electronics and I spent a considerable time looking in to wiring different busses in the 38 way in an attempt to reproduce the multiplex function of the MB box. Life was too short!
trebor80b likes this.
nimbusgb is offline
The Following 2 Users Say Thank You to nimbusgb For This Useful Post:
slk230 dash board and center console Seoulcitydan SLK R170 General Discussion 1 05-24-2016 12:33 PM
Century-Old Cyclone Board Track Racer Owned by Steve McQueen Sold for $775,000 Berliner Heckflosse Off Topic 0 03-26-2015 04:48 PM
Moving new posts to introductions board richard_leeds New Members Introduce Yourself Here 28 12-03-2013 07:42 PM
On Board Diagnostics Australian SLK R170 General Discussion 2 01-03-2013 03:26 AM
Slk 200 roof control circuit board position? seansslk200 New Members Introduce Yourself Here 5 08-27-2010 03:28 AM
