R170 fuel pipes - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By dchantry007
  • 2 Post By mchild
  • 1 Post By kapitand
#1 Old 11-26-2017
Vehicle: Silver R170 230 98R
Quoted: 8 Post(s)
R170 fuel pipes
Ive just found out the reason why my car is not holding petrol. Apparently the fuel pipes need replacing.
Not sure if Ill be able to get any replacements in the UK but have found a place that does stainless steel braided replacements 12.50 per meter.
Can anyone help me with the diameter of the pipes. Are they 5/16? I thought the return was a smaller pipe.
Alternatively does anyone know the cost of the OEM parts from Merc?
Any help appreciated.
dchantry007 is offline
#2 Old 11-26-2017
Quoted: 508 Post(s)
The fuel lines do seem to be available from MB. If you provide you VIN I can confirm these part numbers are correct, but here is what I found without it.
Supply line 170 460 16 64 $46US Retail
Return Line 170 476 17 01 $30US Retail
The parts catalog does not state the pipe size. If no one can advise then you can pull off the rubber hose (simple hose clamp hold the rubber hose to the metal line) that is attached to each line back near the tank and measure the pipe size.
mchild is offline
#3 Old 11-26-2017
Quoted: 8 Post(s)
Thank you. Will dig the vin out
#4 Old 11-26-2017
Quoted: 133 Post(s)
Is that the only section that's rotted out? If so, you could just splice a section in.
Mn car guy is offline
The Following User Says Thank You to Mn car guy For This Useful Post:
#5 Old 11-26-2017
Quoted: 2302 Post(s)
Might as well get you free datacard at the same time.
Vehicle Data Card - Mercedes Benz SLK Forum
Avel Du is online now
#6 Old 11-26-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
BTW the entire 1998-2004 SLK Parts Catalog is online (2.25 MB .pdf) is the link allowed to be shared ? (Moderators must approve such).
Padgett is offline
#7 Old 11-27-2017
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
well,..you could PM it to me Padg!
RLander is offline
#8 Old 11-28-2017
Quoted: 8 Post(s)
How do I get a copy? Can you share it via PM please?
Otherwise Moderators, can you let me know how I can get a copy please?
#9 Old 11-28-2017
unclet's Avatar
Vehicle: 2000 SLK230
Other Toys: '95 Corvette
I'd like to get a copy as well,or a link. Thanks
unclet is offline
#10 Old 11-28-2017
Other Toys: Areobatic Biplane (20+years and I'm still alive)
Hey, looks like mine last Spring.
I replaced about 3 ft, 5/16th of the high pressure line from the pump forward. Not too hard to do, but just a hard getting the section in and out to adjust the bends. Bent it by hand. Not perfect as the bends are more gentle than factory, but still well secured. I cut the pipe just above where the pipes climbs the vertical sheet metal section. If you unclamp part of the run along the bottom, you will create enough space to either saw or use a small pipe cutter (wheel). I sawed, repaired, ran, and then replaced the injectors, which I was planning to do anyway.
You could use high pressure flexible fuel line and make a set of larger clamps to replace to current ones, but I would worry about running flex pipe above the drive shaft.
dchantry007 likes this.
kapitand is offline
#11 Old 11-28-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Could just include the .pdf but need ok from moderators, have gotten in trouble before for posting things tightly held by MB (but on the I'net). Rules are a little strict for a forum.
ps Dchantry does not have enough posts to receive a PM. Need to catch up on your "Howdy Duty".
Padgett is offline
Higher Octane Fuel Coming to a Pump Near You & What That Means Berliner Heckflosse Off Topic 8 01-31-2018 09:03 AM
Help please - Fuel leak from hose where it meets fuel pump cliveski SLK R170 General Discussion 7 09-24-2017 09:10 AM
Strange Reading Fuel Guage LKNman SLK R171 General Discussion 3 03-30-2017 01:32 PM
R170 Fuel Filter replacement/change JaysonM SLK R170 class DIY 13 02-16-2017 02:02 AM
