Aircon Problems - Mercedes Benz SLK Forum
  • 1 Post By FiFiRichardson
#1 Old 11-21-2017
Vehicle: 1999 SLK 230
Aircon Problems
I have replaced my aircon compressor and had the system re-gassed, all fuses have been checked and are good, the EC light comes on but the compressor does not clutch and there is no volts to the compressor. Any suggestions?
FiFiRichardson is offline
#2 Old 11-28-2017
Other Toys: Areobatic Biplane (20+years and I'm still alive)
Mine is dead also. Same issue, compressor will not kick in. My searches found possible failures: the SAM module $$, cabin temp sensor, outside air temp sensor, temp sensor at aircon condensor under the dash. Guys...others that would prevent the compressor engaging? Aircon parts to rule out?
kapitand is offline
#3 Old 11-28-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Errrrr, the "EC" is backwards. Light comes on when compressor is off.
ps most common issue is the low pressure switch, either low on Freon or switch is bad. I'd try bridging contacts momentaily to see if compressor kicks in..
BTW on a GM car (dunno about Merc) once the AC latches off, you have to disconnect the battery for a while for it to reset.
Padgett is offline
#4 Old 11-28-2017
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
You need to scan the system for fault codes and reset them. When you replaced the compressor, you set off a fault code of some type. The compressor will be prevented from engaging until the code is cleared.
Don't worry about losing information. Clear all the fault codes that come up. If they aren't dormant, they'll come back. You'll need a good scanner; I use the Icarsoft MB II! Great unit!
SilverSLK2010 is offline
Lexus, Porsche rank as most-dependable brands, J.D. Power says Berliner Heckflosse Off Topic 0 02-22-2017 12:04 PM
Skoda overtakes BMW & Mercedes-Benz by shunning “tech gimmicks” Berliner Heckflosse Off Topic 0 07-14-2016 01:45 PM
Kia Ranks Highest in J.D. Power 2016 U.S. Initial Quality Study Berliner Heckflosse Off Topic 2 06-23-2016 04:03 PM
U.S. auto industry quality slips for first time in 16 years: survey jbanks15 Off Topic 0 02-12-2014 11:32 AM
