1998 SLK230 in limp mode - Mercedes Benz SLK Forum
 12Likes
#1 Old 11-21-2017
cbrbo's Avatar
Vehicle: 1998 SLK 230
Other Toys: Bike, Boats
Quoted: 15 Post(s)
I have a R170 stuck in limp mode had the codes pulled
013 Speed Sensor N3 Y3/611
09 Speed Sensor N3 Y3/611
65 Control Module N15 /3
161 Control Module N15 /3.
All the research I have done points to the plate and 13 pin connector, I have searched the forums and it seems to be the solution.
I was wondering where is a good place to get the parts from for a fair price.
I am looking at this one and also was wondering what others have used.
https://www.fcpeuro.com/products/mer...on-service-kit
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
Bob
1998 SLK 230
114k automatic
jbanks15, LIL DON SLK and Avel Du like this.
cbrbo is offline
#2 Old 11-21-2017
savcom's Avatar
Quoted: 610 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
Bob
1998 SLK 230
114k automatic
114K and no transmission fluid change? If your dipstick cover is black plastic then the odds are the fluid has not been changed at all. That kit looks fine. It's not worth getting a cheap kit - you'll end up having to do the job again in 20,000 miles or so. The kit you show is not a bad price and providing you can get the car on a ramp - or better still a full car lift - then it's not too difficult a job to do. Also, check the transmission fluid isn't wicking along the cable and interfering with the transmission control unit too. You can check this by looking behind the metal panel in the passenger footwell and making sure the cables to N15 are bone dry. If the fluid has got into the controller you can disconnect it, open it and clean it out. You should be ok, but these have been known to failas a result of fluid ingress. Don't use brake cleaner on the cable, TCU or plug if you do find it is wicking because brake cleaner will soften the insulation on the cables and could dissolve the case of the TCU. Use a proper electrical contact cleaner instead and drain the dirty fluid away thoroughly before re-assembling it.
You should also get a dipstick for the fluid so you know when you've added enough when you refill as overfilling the box will not help you!!
Hope this helps - and you get it all sorted.
jbanks15, Idiot101 and stu32 like this.
Also
Previous :
savcom is offline
#3 Old 11-21-2017
cbrbo's Avatar
Quoted: 15 Post(s)
That does help a lot, is there a part or list vendor you would recommend? I really only want to do this as few times as possible.
Bob
LIL DON SLK and savcom like this.
cbrbo is offline
#4 Old 11-21-2017
Quoted: 6560 Post(s)
fyi Savcom is in the UK
#5 Old 11-21-2017
savcom's Avatar
Quoted: 610 Post(s)
Bob
That kit has all you need - and the dipstick link I sent you is also from the same company. Providing the parts are OEM that should be good enough.
There's a walk-through of what you need to do on PelicanParts. You may need to look up how to change the plate in addition to this..
Also
Previous :
savcom is offline
#6 Old 11-21-2017
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Also have a look at this thread but I think confirms everything @savcom has already mentioned but with the addition of the K40 relay module?
https://www.slkworld.com/slk-r170-gen...tor-plate.html
stu32 is offline
The Following User Says Thank You to stu32 For This Useful Post:
#7 Old 11-21-2017
cbrbo's Avatar
Quoted: 15 Post(s)
I odered the kit, I am looking forward to learning all about this car. After tranny is fixed I will look at performance mods.
Bob
LIL DON SLK likes this.
cbrbo is offline
#8 Old 11-21-2017
Bob
not a lot of performance mods for your 230
pulley is probably the only one
#9 Old 11-21-2017
Quoted: 914 Post(s)
I buy a lot from FCP, they're good.
Right kit, but as noted a failed TCU might need replacement if it's spoiled by a wicking pilot bushing.
efair is online now
#10 Old 11-21-2017
Turdo2's Avatar
Quoted: 361 Post(s)
I just covered a bunch of transmission stuff on my last post in my SLK430 thread. I had limp-home mode issues as well.
https://www.slkworld.com/performance-...8-swap-11.html
If you are stuck in 2nd gear, you will need to get your TCU codes erased or it will still be stuck in Limp mode.
Turdo2 is offline
#11 Old 11-22-2017
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
Hi
I have the same issue with my car. I cleaned the connector a few days ago but it was not right. had the codes checked and cleared at the local garage today and the car was good for a short time. I think the codes have come back. One code I had which you dont mention is P0715. I think its telling my that the conductor plate has reached its end of life.
Im going to find a suitably priced kit to change the plate and change the sensors at the same time.
bryn is offline
#12 Old 11-22-2017
Turdo2's Avatar
Quoted: 361 Post(s)
Originally Posted by bryn View Post
Hi
P0715 was my issue. conductor plate was replaced, codes cleared and all has been well after about 100 miles.
Turdo2 is offline
#13 Old 11-22-2017
savcom's Avatar
Quoted: 610 Post(s)
Hi
It's not hard to put together a kit from different suppliers to be honest - just make sure the parts are OEM Cheap pilot bushings have a habit of failing before they're due and that's really a poor economy. I was lucky in that we had the use of a garage with a full car lift and proper cleaning facilities so we were able to get every part of the sump pan cleaned out. One other thing - you may find a magnet fitted in the sump. Clean that off if it has any swarf on it (if you've none then very happy days!!!)
Looks like you can ship the kit from eBay UK, so I see.
Also
Previous :
savcom is offline
#14 Old 11-29-2017
cbrbo's Avatar
Quoted: 15 Post(s)
I got the kit and now need to get the car in the air and drop the pan. After I pull the valve body is there a need to disassemble it and clean it thoroughly or just cleanup the solenoids and replace the controller board. I really only want to do this as few times as possible.
Getting excited about getting my baby on the road.
Bob
cbrbo is offline
#15 Old 11-29-2017
Quoted: 914 Post(s)
Just have a clean work table to work on... You can't really disassemble the valve body other than removing the CP.
efair is online now
#16 Old 01-03-2018
cbrbo's Avatar
Quoted: 15 Post(s)
SLK230 repair continues
I broke down and took the car to a local mechanic to have the conductor plate installed.
He called and said fluid was really dirty and that the TCU also should be replaced as the plate didn't fix the issue.
Lucky for me he happen to have a couple TCU units in his shop.
I am hoping this will fix the transmission limp mode issue and I can get to enjoy the car.
Bob
cbrbo is offline
#17 Old 01-03-2018
Then you can attend our next meet in April!
#18 Old 01-03-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Bob
did he happen to try those other ones to see if they fixed the problem???
Turdo2 is offline
#19 Old 01-03-2018
cbrbo's Avatar
Quoted: 15 Post(s)
#Turdo2 What other things are you referencing?
cbrbo is offline
#20 Old 01-03-2018
Turdo2's Avatar
Quoted: 361 Post(s)
If the mechanic had a couple more TCU's, why didn't he put them in your car and see if that solved the issue?
Turdo2 is offline
Selling my 1998 slk230 OEM headlights / OEM bumper park light / OEM side marker light (turn signals) afr00t SLK Parts For Sale 1 04-17-2012 03:23 PM
WHY ESP MALFUNCTION and went into LIMP MODE..on and off mrl0n3ly714 SLK R171 General Discussion 1 07-29-2011 12:56 PM
currently in limp home mode quikdraw SLK R170 General Discussion 7 09-30-2010 08:12 PM
