CEL Still On After Cleaning MAF - Mercedes Benz SLK Forum
#1 Old 11-21-2017
Vehicle: 2004 SLK 230
Quoted: 18 Post(s)
Got some CRC cleaner and had cleaned my MAF several times in the past 6 months. I notice an improvement after cleaning, but my CEL still is on no matter what. I am starting to think the MAF is toast.
I have read the threads on people replacing their MAF, but they never state which one they used. Most people have said that only OEM works, but a few people here and there have used non OEM and had fine results.
Do I have to clear to the code with a scanner or will it go away by itself?
And on a side note, what is the part number for the screws that hold the fender liner on? The one right by the jack mounds by the front wheels is starting to droop because the screw came out, or whoever had it before me forgot to put it back on.
I am also looking for 170-885-03-21-9999 in Magma Red, most sites only sell you a primed piece. It is the front left front bumper impact strip that holds the side marker light. Mine got hit and messed up.
Lepper is offline
#2 Old 11-21-2017
Quoted: 133 Post(s)
Yes, you have to clear the code with a scanner. As I recall, I did that to mine when I got it and it worked for awhile but then started throwing codes. I replaced it with an aftermarket and it's been fine for 40,000 miles. It's possible you may have different issues other than the maf. A code reader will tell the tale.
Mn car guy is offline
#3 Old 11-21-2017
Quoted: 18 Post(s)
I got the codes pulled and it was just the MAF code.
Lepper is offline
#4 Old 11-21-2017
6007.us
Padgett's Avatar
Quoted: 572 Post(s)
To read and clear codes on my 320, I use a $12 mini dongle and Torque Pro ($5.99) on my Samsung Galaxy.
For a MAF I would use only a correct Bosch since connector(s) and fitment will be right. For more expensive assemblies I prefer good/used/factory to cheap/new/aftermarket but then where I live, things essentially do not rust. If a MAF problem you will often see both P0170 and P0173. Together they indicate an intake issue.
This one was just over $100 all in from Amazon (their prices vary hourly). However would expect a 230 to need a different one and does not have two banks so YMMV.
Padgett is offline
MAF removal and cleaning video - R170 SLK bayshield SLK R170 class DIY 24 11-13-2018 05:49 PM
throttle body and MAF cleaning hugy SLK R171 General Discussion 2 09-27-2016 12:56 PM
CEL on; P0170 help needed Puck Hog SLK R170 General Discussion 4 07-30-2016 08:36 AM
Mercedes Benz SLK 230 MAF Removal and cleaning jbanks15 SLK R170 class DIY 0 12-11-2013 08:31 PM
MAF cleaning ecohen2 SLK R170 General Discussion 9 10-13-2010 06:06 AM
