Passing gear issue - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By jbanks15
  • 1 Post By LeonardoDaBenz
  • 1 Post By Padgett
  • 1 Post By Turdo2
#1 Old 11-20-2017
Vehicle: 2001 Silver SLK320
Passing gear issue
Still trying to get my 2001 SLK320 transmission sorted out. Shifts great when placed in drive, both up and down, and touch shifter works the way it should up and down through gears. Only problem is when I step down to floor on accelerator pedal and engage passing gear, it stays in passing gear and will not shift up to next gear, no matter what. Pull over, shut off engine, remove and reinsert key and start car, and all is as it should be and shifts fine both automatically, and with touch shifter. Does this every time I step down to passing gear. I have searched and researched and have not found any info similar to my problem. Checked passing gear button under pedal and it clicks up and down without sticking, and lastly no codes shown. Transmission fluid is full and appears and smells fresh. Anyone experience anything like this, or know what possible possible problem is?
VeroWing58 is offline
#2 Old 11-20-2017
Quoted: 6551 Post(s)
Smells fresh? but when was it changed last? any idea?
VeroWing58 likes this.
#3 Old 11-20-2017
LeonardoDaBenz's Avatar
Quoted: 1063 Post(s)
Fluid change is more than just dumping/refilling (ie: "smells fresh" ) .
Found something similar to your problem (diff model) on the "other" site.
Also, have you tried the transmission reset as found here? It's worth a try even though you say it works normally otherwise.
Also, isn't there a solenoid (attached to engine block) that is involved with the actuator button under the pedal which might be faulty?
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#4 Old 11-20-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
My experience with such is to first add a can of Seafoam Transtune. Is a cheap fix. Second is a flush and fill including filter.
Padgett is offline
The Following User Says Thank You to Padgett For This Useful Post:
#5 Old 11-20-2017
Turdo2's Avatar
Quoted: 361 Post(s)
sounds like a conductor plate issue in the transmission. My SLK(430) wouldn't shift out of 2nd when the accelerator was past 3/4.
very common issue from what I've read.
basically, it sounds like it's going into soft limp-home mode due to a fault. and that usually causes it to be stuck in 3rd or 2nd. ("passing gears")
Turdo2 is offline
#6 Old 11-20-2017
Service records show dealer transmission service at 96,984. Car currently has 118,165, so only 20,000 since serviced. Because transmission shifts flawlessly when placed in Drive, or when using "touch" shifter up and down through gears, I'm thinking this is some sort of electrical issue instead of a mechanical one. While doing some research on this I came across a video showing a shift module located on outside of trans that person indicated can stop passing gear from activating, but didn't mention it causing trans from shifting out of passing gear. I'll research threads provided here, and not step down into passing gear for time being. Any further info will be greatly appreciated. Mike
10/23/2012
96,984 mi
Mercedes-Benz of Coconut Creek
Services Performed
Maintenance inspection completed
Air filter replaced
Brake fluid flushed/changed
Front brake pads replaced
Rear brake pads replaced
Fuel filter replaced
Driveshaft checked
Antifreeze/coolant flushed/changed
Brakes checked
Oil and filter changed
Spark plug(s) replaced
Tire condition and pressure checked
Transmission serviced
#7 Old 11-20-2017
Here's link to video showing a "kickdown solenoid" that causes passing gear shifting problems. guess I should get under car and test it for releasing after being engaged.
https://www.youtube.com/watch?time_c...&v=nzBBHwX41mY
Automatic rear gear bloqued rom65 SLK R170 General Discussion 9 06-27-2015 11:39 AM
Would Not Shift To 4th Gear SLK300MAINENIAC SLK R171 General Discussion 4 04-13-2015 08:38 PM
Transmission issue after coductor plate, electrical connector, and fluid change M2-Motoring SLK R170 General Discussion 5 01-05-2015 10:38 AM
SLK320 6 speed - 1st gear? RoboRob SLK R170 General Discussion 1 06-21-2013 04:18 PM
