Resolved - Engine cut out wont restart - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By silverstrider
  • 2 Post By Padgett
  • 1 Post By beilts
  • 1 Post By Padgett
#1 Old 11-18-2017
Vehicle: SLK 230 1998
Hi all,
I have a 98 SLK which has done a fair few miles, but generally works well.
Yesterday driving locally - the engine suddenly cut out, and the starter wouldnt work - nothing at all.
Electrically all seems fine, the engine fan comes on when I turn the ignition and all warning lights display as normal. There are no warning lights staying on etc.
Nothing at all from the starter motor.
Looking round the forums suggestions point to the K40 relay and CPS - I can replace these - but wondered if the above sounded like it could be caused by either/both of these.
LIL DON SLK likes this.
silverstrider is offline
#2 Old 11-18-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
If the starter motor is never engaging it is probably not the CPS. Any warnings displaying or codes ? If nada the first thing I'd do is to pull the positive battery terminal for about a half hour and try again. If it is just confused this may work and is free. If that does not work we can go deeper.
Idiot101 and savcom like this.
Padgett is offline
#3 Old 11-18-2017
Thanks - I'll give that a try.
#4 Old 11-18-2017
Vehicle: 1999 SLK 230 101K.
Other Toys: Sold my Kawasaki Concours motocycle to get the car.
Quoted: 15 Post(s)
Originally Posted by silverstrider View Post
Hi all,
Sounds like when my K40 relay failed. Did the engine just die when driving, or would it not start? All electrics seem OK and no starter?
Australian likes this.
beilts is offline
#5 Old 11-19-2017
That's exacty it. Engine died while driving, and then wont restart. All other electrics are fine.
I've pulled the K40 board. There are MB relays on the board which all look OK, one has slightly burnt looking solder joints.
There is also a 'custom' relay soldered in position 1 on the board (furthest away from the orange 40Amp fuse). This looks OK but most of the K40 pictures I've seen only have 4 relays.
I'm going to refresh all the joints with solder and see if that helps. I'd like to test the relays - persume 12v is required plus identifying the correct terminals.
#6 Old 11-29-2017
Thought I'd update on my engine cut out.
So after looking through the forums, I removed the K40 relay module and resoldered all the joints. There was a slightly dodgy looking relay but testing it manually with a PSU, all seemed OK.
I put the module back in - and still no joy.
Tried replacing a couple of the relays with new ones - still no joy.
Finally - I purchased a new module from a Mercedes dealer and installed.
It now works!
No idea what the issue was with the old module, but glad the new one works OK.
FYI - my failure ocurred during driving. The engine just cut out and that was it. The engine never fired again with the old module despite numerous attempts. There were a couple of things I noticed after the failure - no fuel pump sound when you turn the ignition key, and the radiator fan on full speed.
#7 Old 11-29-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Might want to ask [email protected] - he rebuilds them for not much money.
Idiot101 likes this.
Padgett is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 56 08-28-2019 05:35 AM
DIY Oil Change and Lessons Learned geophysicist SLK R170 class DIY 37 10-29-2017 12:52 PM
30 years go, BMW built a 1350 hp engine for Formula 1 cars Berliner Heckflosse Motorsports 0 04-14-2017 11:21 PM
The History of BMW in F1 Berliner Heckflosse Motorsports 0 04-13-2015 01:29 PM
