Heater Core? - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Windinmyhair
  • 3 Post By Mn car guy
  • 2 Post By Mn car guy
  • 1 Post By Shalesy
  • 1 Post By LagunaMB
#1 Old 11-17-2017
LagunaMB's Avatar
Vehicle: 2001 Laguna Green SLK 320. An Ebay purchase...Florida car
Other Toys: Jeeps
Quoted: 18 Post(s)
Heater Core?
Haven't been around the site for a while...Been traveling... Also have not gotten to drive the SLK for over a month because of it. One of the first things I did was to take the car out for a exercise ride. It was a cold enough morning here in the mountains that I needed the heater. All was well, then I turned heater on. Gradually as the car warmed up the windows fogged up and the defroster would not clear them. I'm thinking heater core! This must be a horrific job to do! I can't think of anything else that would fog the windows but a heater core. The car is garaged and is not wet nor does it go out in rain. Just thought I'd mention that.
Has anyone had the honor of replacing a heater core?
LagunaMB is offline
#2 Old 11-17-2017
Windinmyhair's Avatar
Other Toys: Lots of tools
When was the cabin filter last replaced?
Windinmyhair is offline
#3 Old 11-17-2017
Quoted: 52 Post(s)
Are you loosing coolant? Is the interior (passenger feet, driver feet) wet (damp) from coolant?
If not, excersise the heating and ventilation controls, check the ventilation fan, check under the intake plenum cover and check the "pollen filter" (AKA "cabin filter"). Is there a powerful air stream that can be directed as per controls? Is the internal/external air supply switch in "external" ?
Anders S SLK02 is offline
#4 Old 11-18-2017
LagunaMB's Avatar
Other Toys: Jeeps
Quoted: 18 Post(s)
Don't know when the cabin filter was replaced... what would that have to do with fogged windows? No signs of any leaks, no sweet smell or stains. HOT heat with good air volume, controls work fine. A/C has not been operated in several months. A plugged evaporator tray drain would have showed up during the summer and by now be bone dry if it were plugged. It's about a 1500.00 job at the dealer. We don't drive it much in the cold so after a real diagnosis I may by pass the heater core if that's what the problem is. I was hoping someone had done the Job...I've read for other models it's a 4-5 day job for a novice with no guarantee everything will work correctly afterwards. IF it's a heater core it sounds like my tax return is already spent
LagunaMB is offline
#5 Old 11-18-2017
Cabin filters become surprisingly clogged after a relatively short service life and, consequently air flow becomes restricted.
The SLK cabin is of relatively low volume so condensation can form quickly.
That being said, if aircon servo motors give out or flaps jam, then direction of warm/hot air becomes compromised.
Anyone know if the SLK has an aircon 'self diagnosis' that can be initiated?
My Toyota RAV4 does - it cycles through all the various settings and will throw a code via the aircon setting screen.
LagunaMB likes this.
#6 Old 11-18-2017
Quoted: 133 Post(s)
I had the same problem. Drove me batty till I figured it out. Took about 30 mins to fix.
Avel Du, savcom and LagunaMB like this.
Mn car guy is offline
The Following User Says Thank You to Mn car guy For This Useful Post:
#7 Old 11-18-2017
Quoted: 133 Post(s)
See post 6 for a likely solution.
#8 Old 11-19-2017
LagunaMB's Avatar
Other Toys: Jeeps
Quoted: 18 Post(s)
Originally Posted by Windinmyhair View Post
Cabin filters become surprisingly clogged after a relatively short service life and, consequently air flow becomes restricted.The SLK cabin is of relatively low volume so condensation can form quickly.
I'm not sure that air flow is the cause but I'm going to check it out this AM! You never know how a gremline works till you look.
LagunaMB is offline
#9 Old 11-19-2017
LagunaMB's Avatar
Other Toys: Jeeps
Quoted: 18 Post(s)
Originally Posted by Mn car guy View Post
I had the same problem. Drove me batty till I figured it out. Took about 30 mins to fix. https://www.youtube.com/watch?v=KbQhC5OjvL4&t=87s
Thanks for the video! I'll look into the flap being open. We do use the A/C & heat with the top down depending on the outside temp. If it's the same problem as your car I'm still looking at a major repair unless I make something to pull it shut and open.
LagunaMB is offline
#10 Old 11-19-2017
Quoted: 133 Post(s)
Not really, I'll try to explain it a bit more. The flap allows you to recirculate air in the cabin. This gives you maximum AC output. When it sticks in recirc mode, as mine did, humid air get recirculated in heating operation leaded to fogging of all windows. By leaving the flap on outside air, you eliminate fogginess during heating but technically diminish max ac operation. This past summer, we hit 98f a few times and my car was very cold despite not having functioning recirc.
I went through the same process you did. Cleared the drain tubes, checked for damp carpets, checked for low coolant and everything was fine.
Idiot101 and LagunaMB like this.
#11 Old 12-06-2017
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
Thanks for that. Misty windows and flap wide open on either setting.
Going to fix it now
Update: That sorted it.
Now, I like things to work. Is it possible to replace the actuator?
I can find a drawing but no part numbers on the EPC. Anyone know?
Shalesy is offline
#12 Old 12-06-2017
Quoted: 29 Post(s)
I did find this post from a few years ago. Fixing my car | Il blog di Mastro Gippo
Seems I need a spring as mine is just slammed wide open if the vac line is attached.
Going to wait for the weather to warm it a tad. 'kin freezin' out there
Shalesy is offline
#13 Old 12-06-2017
Turdo2's Avatar
Quoted: 361 Post(s)
wow, I cant believe I'm just now coming across this!
4.5 years I've had the car, and every winter it would fog up and freeze on the glass INSIDE the cabin... will definitely have to give this a shot!
Turdo2 is offline
#14 Old 12-07-2017
LagunaMB's Avatar
Other Toys: Jeeps
Quoted: 18 Post(s)
I still have not had the time to pull the glove box out to check on that flap. I did have my wife exercise the controls several times the last time she drove it. That seemed to make things work. No fogged windows!! So relieved it's not a heater core!
THANKS!!!!!!
Anders S SLK02 likes this.
LagunaMB is offline
#15 Old 12-07-2017
Quoted: 52 Post(s)
THANKS!!!!!!
I can relate to that effect.
Good for you!
#16 Old 12-19-2017
Quoted: 29 Post(s)
Today I went in search of the air flap return spring. I found it
Its not as big as I thought, said the actress to the bishop....
35mm by 5.5mm. Now searching for something similar.
Shalesy is offline
SLK230 Heater Box Clips JimSLK230 SLK Parts Wanted 0 09-11-2011 12:02 AM
Wow i used my seat heater today Berliner Heckflosse Off Topic 2 03-01-2011 04:44 PM
