limp mode suggestions - Mercedes Benz SLK Forum
#1 Old 11-15-2017
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
Any suggestions about limp mode. have checked the plug to find it dry. Unable to determine what scanner to buy for a 1999 SLK230 with 38 pin socket. At a loss to know were to go next. Any suggestions most welcome..about limp mode and scanner for early model, No warning/defect light on the dash panel is my only clue.
bryn is offline
#2 Old 11-15-2017
Without a code it could be anything, most of the time its a dirty MAF, clean it with crc maf cleaner and clear the code by disconecting the battery. Make sure you have a radio code first.
#3 Old 11-15-2017
Turdo2's Avatar
Quoted: 361 Post(s)
what gear is it stuck in?
Turdo2 is offline
#4 Old 11-16-2017
Quoted: 16 Post(s)
I have tried that without any luck. having the car scanned tomorrow so it migh show something, as you say clearing the code might be all it needs. Will keep you informed and thanks for the input
bryn is offline
#5 Old 11-16-2017
Quoted: 16 Post(s)
Not sure which gear, I thought first gear but could be second. And its a harsh take up when I put it in drive or reverse. having it scanned tomorrow so will keep you posted. Thanks
bryn is offline
#6 Old 11-16-2017
Turdo2's Avatar
Quoted: 361 Post(s)
I believe your problem is transmission related.. either with the control unit or conductor plate. let us know what comes up in the scan.
Turdo2 is offline
#7 Old 11-16-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Mine did that when the console got wet. No gear in the indicator in the dash, needed to use rod to get out of Park, harsh shifts and first gear only. Codes P0600 and P0705.
Padgett is offline
#8 Old 11-22-2017
Quoted: 16 Post(s)
Hi Turdo
Had my car back from the garage today. The code was P0715. All they did was clear it and the car drove ok for while. I had cleaned the multi pin plug previously. Its went back into limp mode after driving for a few K's. Im going to shop around now for a kit to renew the conductor plate and also replace the sensors.
bryn is offline
#9 Old 11-27-2017
dan2c1's Avatar
Vehicle: SLK 230 1998
Quoted: 14 Post(s)
when this happened to me, nothing worked until i changed the 2 ignition coils, i lost a lot of money while the mechanic was trying 123981239'0182 possible things.
dan2c1 is offline
#10 Old 11-27-2017
Turdo2's Avatar
Quoted: 361 Post(s)
Originally Posted by bryn View Post
Hi Turdo
The conductor plate is what is causing the P0715 code. that did the trick for mine. for piece of mind, make sure you get a new 13 pin connector just to make sure you have 100% solved the issue. the TCU code will need to be cleared once you are finished replacing the conductor plate.
Turdo2 is offline
Transmission stuck in Limp Home Mode after service slkbrrgrr SLK R170 General Discussion 4 02-21-2016 08:11 AM
Limp Mode Home, slk 350 riceball4u SLK R171 General Discussion 45 11-04-2015 08:51 PM
WHY ESP MALFUNCTION and went into LIMP MODE..on and off mrl0n3ly714 SLK R171 General Discussion 1 07-29-2011 12:56 PM
currently in limp home mode quikdraw SLK R170 General Discussion 7 09-30-2010 08:12 PM
