Resolved - Help with air bag sensor part number - Mercedes Benz SLK Forum
  • 1 Post By Silverster
#1 Old 11-13-2017
Vehicle: 1998 Slk 230
Quoted: 7 Post(s)
My srs light has been on since I bought the car. Das says it's the drivers side sensor. I was waiting to replace it, until winter, when I was going to have the seat recovered. I found nice replacement seats cheaper than having to recover them so it was time to replace the sensor. The connector was slightly corroded so I cleaned it and cleared the codes before trying the replacement sensor, No joy. Went to try the replacement and found it was not a match.
EPC says it's part number 001 820 0726 09 so I ordered one off the fleabay. Mine is a three wire, and the replacement by that number was a two wire. It seems that number is generic for air bag sensor even though it has a bar code. There are three other numbers on the sensor, one of which also has a bar code.
003 97288 10 1579 3
with bar code KB4K97881579 770 and below that 0 285 001 164. I have seen other sensors on the fleabay which are similar in appearance and claimed to be for a 1998 230 but the numbers are slightly different.
The questions are
Which is the important number to identify the sensor and is there an updated number to the original sensor.
EPC has a note that the replacement sensor needs to be coded to the car. I guess just clearing the codes won't be sufficient.
Silverster is offline
#2 Old 11-13-2017
Quoted: 6580 Post(s)
Post your vin
we can see the part numbers for your car for that part
#3 Old 11-13-2017
I'm sure ebay does not mention facelift and prefacelift as they want your money
#4 Old 11-13-2017
per epc, yes a0018200726 is your airbag sensor
NOTE THERE IS NO 09 after your part number
you want your datacard also?
and the sensor must be programmed
#5 Old 11-13-2017
here is another airbag sensor for airbag and sidebag
5 A 001 820 08 26 SENSOR
BELT LOCKING RETRACTOR, AIRBAG AND
SIDEBAG
[008] IMPOTANT:FOLLOWING INSTALLATION,CONTROL UNIT MUST BE P...
001
8 A 001 820 07 26 SENSOR
SIDEBAG
002
#6 Old 11-14-2017
Quoted: 7 Post(s)
Thanks but the problem is the replacement was also a 001 820 0726 09. Even though EPC gives this number it's not the correct part. That is the puzzlement.
First picture original part in car three wire. Second picture incorrect replacement two wire. Both 001 820 0726 09
The 003 number appears to be the difference. I don't know how to search EPC for those numbers.
#7 Old 11-14-2017
In epc, at the top go to search 'part'
the A will be there and just put the number in
#8 Old 11-14-2017
or search
sensor
then country and model
#9 Old 11-14-2017
the vin you gave me produced the pdf with the parts above i posted
so i don't know where you got the 09 from
#10 Old 11-14-2017
let me put this
003 97288 10 1579 3
in epc for you
#11 Old 11-14-2017
A003972881015793 and other variations of it do not show up in epc
#12 Old 11-14-2017
Quoted: 7 Post(s)
From the actual part as can be seen in the attached pictures. 09 for both the original and incorrect replacement.
Will search the epc with the 003 numbers
#13 Old 11-14-2017
part 5 in this parts place
be aware
Replaces: 001-820-07-26-64
64 might have replaced 09
https://www.mbpartscenter.com/oem-pa...bC1sNC1nYXM%3D
https://www.mbpartscenter.com/auto-p...omponents-scat
#14 Old 11-14-2017
Quoted: 7 Post(s)
Thanks, I appreciate it.
I'm still confused that the EPC number is 001 820 0726
and there are different 001 820 0726 parts both with 09
#15 Old 11-14-2017
my only guess is they are 'counterfeit' possibly
#16 Old 11-14-2017
Quoted: 7 Post(s)
Must be a lot of them
images from fleabay
#17 Old 12-04-2017
Quoted: 7 Post(s)
You can call this one resolved. The part number that seems to matter for the 1998 slk 230 is the Bosch number.
0 285 001 164
Another twenty dollars from the flea bay and all is well.
Software, not Takata - GM recalls 4.3 million vehicles over air bag-related defect jbanks15 Off Topic 0 09-09-2016 03:41 PM
List of Mods/Bits & Pieces Phil1987uk General Modifications R171 274 08-20-2016 06:56 PM
Takata to announce recall of 35 million-40 million additionalU.S. air bag inflators: sources jbanks15 Off Topic 0 05-03-2016 08:19 PM
Cold Air Intake luc256 Performance MODS for the R170 8 11-06-2014 06:38 PM
