Resolved: Slightly sticking roof when opening - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By jbanks15
  • 1 Post By borris1954
  • 1 Post By tsberkey
  • 2 Post By tsberkey
#1 Old 11-07-2017
Vehicle: 2001 SLK 320
Quoted: 16 Post(s)
So, we've had our 170 for four days now, and everything about her has been great. Today, when I went to put the top down, everything went well until it came time for the roof to separate from the windshield. The trunk opened to receive the top and you could hear the pump or motor running, trying to get the top to continue opening, but nothing. At that point, it would not allow me to reverse direction and close the top, so I started to get a little panicky.
I noticed when I would press the button to retry with opening, I could see the roof panel and the rear window panel budging just a tiny little bit. I reached up and (while I was still holding the button) gave it a little push and *pow* she continued on as though everything was good. I repeated this a couple of times through the day, and each time, it simply needed that tiny bit of help.
I know there are volumes of things about the vario roof on this and other forums. I've searched and discovered that. However, I've not found anything that specifically sounds like this issue. If it helps, this car had a hydraulic top motor replaced last week and the PSE pump replaced in July.
Any ideas ?
tsberkey is offline
#2 Old 11-07-2017
Quoted: 6538 Post(s)
Sounds like the roof switch at the windshield or needs some lithium grease on the latches
did the mechanics tell you what was repaired?
you should also only operate the roof in one direction until the operation is completed
otherwise it gets confused
so does it open or close completely at all now?
https://www.slkworld.com/general-disc...ts-hinges.html
#3 Old 11-07-2017
Quoted: 16 Post(s)
No, I just have the copy of the receipt that the PO gave to me. For the one last week, it simply says "used hydraulic top motor" and "top switch". For the July one, "pse pump" and "seal kit and fluid".
Once I get past the little sticky part (and, seriously, it takes a very gentle push at the spot where the roof meets the rear window) the rest of the operation is flawless and finishes properly. Putting it back up, there is no issue.
tsberkey is offline
#4 Old 11-07-2017
there are 2 top switches so maybe only one was replaced
anyway, have you gummied and greased all the joints in the link above? do it to start and pay attention to the location where u have to 'push'
#5 Old 11-07-2017
see the pdf for locations in trunk/roof greasing
even though it is for a r171, same would apply
also some of these locations for grease/lithium
http://www.benzworld.org/forums/3317640-post1.html
#6 Old 11-07-2017
Quoted: 16 Post(s)
No, I wasn't about to start into ANYTHING until I asked questions here. That will be my first thing to try.
tsberkey is offline
#7 Old 11-07-2017
do you have any lithium grease?
get thee to a walmart
#8 Old 11-07-2017
Quoted: 16 Post(s)
No, but there's one right across the street from my new place! Other than drips (and potential of staining the interior or getting some on the paint), I don't imagine I could do any harm by using a bit too much as opposed to not enough. (?)
Also, I see in the picture that there is a can of this stuff in spray form. Seems like that would be easiest to use for a novice. Agree?
tsberkey is offline
#9 Old 11-07-2017
i was referring to the one in the can. yes spray
if too much, just wipe it off
tsberkey likes this.
#10 Old 11-08-2017
Vehicle: 1997 SLK 230 (In H352 Linarite blue)
Quoted: 34 Post(s)
I would also check the cable that operates the locking catch at the joint between roof and rear window. These stretch over time and then the catch doesn't quite free without encouragement. Its easy to check and adjust once the roof liner is removed. I had this exact issue and was relieved it was a simple adjustment needed.
Good luck.
Sent from my SM-T710 using Tapatalk
borris1954 is offline
The Following User Says Thank You to borris1954 For This Useful Post:
#11 Old 11-12-2017
Quoted: 16 Post(s)
UPDATE:
So, I immediately applied the lithium grease to every place that looked safe to do so, starting with where the top panel meets the windshield. Still was sticking so I then did the joint right behind the driver's head where the top panel meets the rear window section. POOF, she opened on her own the next time and has ever since. Thankful (so far) that it is not a cable that I have to try to adjust.
Thanks again for all the help and suggestions!
tsberkey is offline
#12 Old 11-12-2017
Great! MaryKay Simplyslk will be relieved @simplyslk
#13 Old 11-12-2017
Quoted: 16 Post(s)
Don't tell her about the blown engine, and the doors falling off, then!
tsberkey is offline
#14 Old 11-12-2017
She'll read that herself when she gets here!
#15 Old 11-13-2017
Swedish Steven's Avatar
Vehicle: SLK 55 AMG 2005
Other Toys: MB C-class 300d 4matic, Honda GB500
Quoted: 111 Post(s)
Ahhhh, lithium treatment
Swedish Steven is offline
#16 Old 11-13-2017
Quoted: 16 Post(s)
I just inhaled the whole can. Now, I don't mind that the roof sticks!
jbanks15 and Swedish Steven like this.
tsberkey is offline
#17 Old 05-12-2018
Vehicle: 2001 red slk 320
thank you, had the same issue, one drop of oil on that hinge and it opens without issue now
boca1 is offline
manual opening vario roof ardo SLK R170 General Discussion 21 06-08-2019 09:41 PM
vario roof not opening roof latch microswitches Stubev SLK R170 General Discussion 4 04-05-2019 04:53 PM
Intermittent Roof jcjefferies SLK R170 General Discussion 4 08-08-2017 12:30 PM
Clunk from roof / trunk when opening Poppysdad SLK R171 General Discussion 8 07-27-2014 02:09 PM
Roof not opening Eddy3987 SLK R170 General Discussion 4 07-22-2014 03:32 PM
