Misfire cylinder 1 - Mercedes Benz SLK Forum
 5Likes
  • 2 Post By Rhys Willson
  • 1 Post By jbanks15
  • 1 Post By i860
  • 1 Post By Rhys Willson
#1 Old 11-05-2017
Vehicle: 1999 slk 230 auto. 104k miles
Misfire cylinder 1
Been having trouble with the car running rough. Seemed worse at top revs. Struggle to get over 100mph. Cleaned maf and top end was better, could get up to top speed again, but still running rough. But after maf clean would start to stall at idle. Replaced mag with Bosch and runs much better. Top whack ok, no stall but still slightly rough. Starts fine, no lights. Runs smooth till you hit the gas hard. Ran the individual and got p0301 - misfire in cylinder 1. Guess I should start looking at the spark plugs. Can I swap the spark plugs around and see if the error code moves with the plug? Same goes for the coil if plug doesn't change anything. And if still no change should I go for the CPS? Or the 02 sensor. Any advice gratefully received
Rhys Willson is offline
#2 Old 11-05-2017
Quoted: 6190 Post(s)
When I had that error it was the cps crank position sensor
how many miles you got?
quick and cheap fix
Move plug from 1 to 2
move injector from 1 to 3
move ignition wire from 1 to 4
if still error, move coil from 1 to 2
if still error
replace cps
Wavetrac LSD thread here:
#3 Old 11-06-2017
104k miles. And I had it serviced a couple of years back and they changed all the plugs, so I don't think it'll be just the plug - unfortunately. CPS is what I'm erring towards. Good to know that I can swap all those elements around - that is exactly what I wanted to know. Much appreciated. Will report back.
#4 Old 11-06-2017
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 822 Post(s)
Try those on cylinder 1
-spark plug ( new or swap with cylinder 2)
-coil pack ( new or swap with cylinder 2)
If those fail then you have to check:
-injector
-compression test
i860 is online now
#5 Old 11-06-2017
Vehicle: 2001 SLK320, 145K miles
Other Toys: Boat, On/Off road bike, tractors, 07 Mustang GT
Quoted: 9 Post(s)
I had a misfire on cylinder 1, car ran rough. Turned out to be a fuel injector. Fairly easy job to replace, and it cured the rough running problem. 114,000 miles at the time.
Rocket Ray is offline
#6 Old 11-06-2017
Gonna swap things round at the weekend, as Mr Banks suggests. Narrow down or eliminate plugs, coil, and injector. And move on from there. The odd thing is if you reset the system, ie turn ignition off and on (even while moving, if enough momentum) the engine runs fine again. Thanks for all the responses. Very useful.
#7 Old 11-06-2017
after 3 engine restarts, cel goes away but stays stored because issue not currently happening until next time
#8 Old 11-06-2017
6007.us
Padgett's Avatar
Quoted: 546 Post(s)
Torque Pro shows Pending (yellow) and Current (red) faults. Carly Pro shows page after page after page... Both can clear them.
Padgett is offline
#9 Old 11-07-2017
Thanks for all the replies. First time using odb. What is the difference between logged and pending faults. I have p0301 logged. And notice there is a pending code p0700. But I don't have any cel on.
#10 Old 11-07-2017
Swedish Steven's Avatar
Vehicle: SLK 55 AMG 2005
Other Toys: Audi A4 Avant 3,0 TDI Q 200kW, Honda GB500
Quoted: 100 Post(s)
Google "OBD code p0301" and you get: https://www.obd-codes.com/p0301
and for the other: https://www.obd-codes.com/p0700
As I understand it, logged is a permanent error and the pending is - just pending. Might be wrong there (and stand to be corrected:-).
Swedish Steven is online now
#11 Old 11-07-2017
i860's Avatar
Quoted: 822 Post(s)
Clear all codes, drive your car and scan again see what code is stored.
i860 is online now
#12 Old 3 Weeks Ago
Vehicle: 2003 SLK 230. Speer pulley kit. Depo euro headlights with led. Led taillights
Quoted: 9 Post(s)
I am having the same problem. What was the fix?
Mantist is offline
#13 Old 3 Weeks Ago
Vehicle: 2009 CLK 350 cab
Quoted: 120 Post(s)
This is a two year old thread and the op hasn't been here since.
Mn car guy is online now
#14 Old 3 Weeks Ago
Quoted: 9 Post(s)
I know. Just hoped someone would chime in to help..
Mantist is offline
Closed Thread
P0304 code cylinder 4 misfire Joeb77 SLK R170 General Discussion 22 06-02-2016 12:41 PM
P0300 Multiple Cylinder Misfire tabspeed SLK R170 General Discussion 16 03-23-2016 05:45 PM
Cylinder 2 Misfire only when idling, please help wailok123hk SLK R171 General Discussion 15 01-28-2016 10:06 PM
Mysterious Misfire on Cylinder #2 silentperplexion SLK R170 General Discussion 3 11-29-2014 12:56 PM
