Timing chain replacement - Mercedes Benz SLK Forum
 9Likes
  • 2 Post By Nellywelly
  • 1 Post By Nellywelly
  • 3 Post By Anders S SLK02
  • 3 Post By Padgett
#1 Old 11-03-2017
Vehicle: Black 2002 SLK200
Other Toys: Disco 3, Z4, BMW 3-Series estate
Question Timing chain replacement
Hi guys, I know I’ve only just joined but I have been lurk8ng for a few weeks
I need some help with my SLK200 the timing chain is broken and I cannot find out how to fit a new chain, everything says to link the new with the old and thread it round.
Mine is broken and off the bottom sprocket already how do I thread the new chain around the bottom sprocket without totally dismantling the front of the engine ?
Really appreciate the write up on the head gasket it’s great reference.
Nelly
LIL DON SLK and Idiot101 like this.
Nellywelly is offline
#2 Old 11-03-2017
6007.us
Padgett's Avatar
Quoted: 570 Post(s)
In your case will need to pull the front cover. A good chance to replace any worn sprockets while there. Any idea why the chain broke ? It is not common.
ps if happened when running, I'd want to pull the head and check for damage anyway.
Padgett is offline
#3 Old 11-03-2017
Quoted: 2261 Post(s)
As Padgett says, it may not be so simple as just the chain.
Get those valves checked.
#4 Old 11-03-2017
Gonna check the compression by lifting the cams, but how do I get the chain back round the bottom sprocket if the valves are ok ?
LIL DON SLK likes this.
#5 Old 11-03-2017
Quoted: 6511 Post(s)
Some threads in a search of our site
https://www.google.com/search?source....0.b6Wy9s6ZqEw
#6 Old 11-03-2017
Quoted: 52 Post(s)
You probably won't. That sort of luck is better used in the lotteries :-)
But there is a silver lining on every cloud: If the chain is worn, so are the sprockets and the tensioner (Oh, the tensioner!). These items go down with the chain, and (not well known) a worn chain takes their sprockets with them on the road to perdition. Chain wears by the rollers and link pins, the chain gets a little longer (each link) and beds in to each of the sprockets. A new chain will therefore not fit the worn sprockets perfectly and wear itself down fast.
Ususal remedy is to change the sprockets for new and overhaul the tensioner (new spring etc). All this is done from the front of the engine, and involves new seals and removing covers. Pass the coffee, please :-)
BUT, the Engine will be "as new" in this important aspect.
LIL DON SLK, Avel Du and Wangler like this.
Anders S SLK02 is offline
#7 Old 11-03-2017
6007.us
Padgett's Avatar
Quoted: 570 Post(s)
Also a complete front end service (chain, sprockets, tensioner, seals) on an engine with over 100,000 miles will often feel like you just gained 10hp. Stretched chain means retarded cams.
Avel Du, savcom and Anders S SLK02 like this.
Padgett is offline
#8 Old 12-03-2017
Update........
I took the plunge and pulled the engine.
All was well into installing replacement until I jammed the spigot bearing and the cage broke up.
Does anyone know the part number of a flywheel spigot bearing for a R170 2.0.
And just when it couldn’t get worse I had my garage burgled and the stole all my sockets boxed tools and power tools, not your normal through the door burglary but they knew what they wanted and broke through a reinforced concrete sectional wall.......
Preventive maintanence M271 engine, timing chain & camshaft adjuster sprockets. curro101 SLK R171 General Discussion 92 02-20-2019 11:43 AM
R171 200K Timing Chain Tensioner - Replacement and Releasing before starting -IMPORTANT den111s SLK R171 General Discussion 13 05-06-2018 04:40 AM
Engine Management Light and Timing Chain Fault Vickyb SLK R171 General Discussion 35 05-30-2016 07:05 PM
200 kompressor timing chain replacement M271 bigsteve SLK R171 General Discussion 2 11-04-2014 04:09 PM
