1200rpm rattle......... - Mercedes Benz SLK Forum
 18Likes
  • 2 Post By Polo Pete
  • 3 Post By Avel Du
  • 3 Post By nigelb001
  • 2 Post By Turdo2
  • 3 Post By kapitand
  • 1 Post By efair
  • 1 Post By Terminal
  • 1 Post By savcom
  • 1 Post By Turdo2
  • 1 Post By kapitand
#1 Old 10-27-2017
Vehicle: 2003 SLK230
Hi, first post on this forum!
I have a 2003 SLK230 Kompressor. Whenever it touches 1200rpm either revving up or when the revs come down there is a fairly loud rattle from somewhere in the engine/gearbox.....this happens when driving and also when in P or N. Anyone else experienced this issue?
LIL DON SLK and Avel Du like this.
Polo Pete is offline
The Following User Says Thank You to Polo Pete For This Useful Post:
#2 Old 10-27-2017
Quoted: 2284 Post(s)
As it is happening in all gears are you absolutely sure that it is not due to the exhaust?
The system travels underneath the entire length of the car and will echo.
You get the rattle in all gears at the same revs.
Before getting into expense make sure it is not the exhaust.
Another favourite is if any work has been done prior to the rattle,
have any tools been left in the engine bay.
One more quickie for you.
Check the kit stored with the spare tyre. Loose kit often resonates into the cabin.
jbanks15, Polo Pete and ps33fount like this.
Avel Du is online now
#3 Old 10-27-2017
nigelb001's Avatar
Vehicle: SLK55 AMG R171 Yr2005 Black; SLK320 R170 Yr2000 Silver
Other Toys: BMW 428i M Sport Coupe
Quoted: 56 Post(s)
In my case on my SLK320 the rattling between 1200 and 1500rpm was down to the front catalytic converters so sounded like it was coming from near the engine. Changed them and now silent.
2005 SLK 55 AMG, Obsidian Black
Mods: G-Paddles / Mercedes OEM Wind Deflector / TAR.OX front rotors / Huge grin on my face
nigelb001 is offline
#4 Old 10-27-2017
Originally Posted by Turdo2 View Post
Sounds like the supercharger. it kicks in around 1200 RPM.
are you sure it's a "rattle"? can we get a video of the noise?
From your welcome thread.
#5 Old 10-27-2017
Turdo2's Avatar
Quoted: 361 Post(s)
yes. whoever gave that tip is really smart!
You could unplug the supercharger at the connector in front of the engine and see if the noise stops.
Polo Pete and Avel Du like this.
Turdo2 is offline
#6 Old 10-27-2017
Other Toys: Areobatic Biplane (20+years and I'm still alive)
Same here, but mine was a lose heat shield above the secondary cats. Clattered only at idle or just off idle.
LIL DON SLK, Idiot101 and Avel Du like this.
kapitand is offline
#7 Old 10-27-2017
Quoted: 913 Post(s)
I had one somewhat similar due to a broken exhaust hangar - it was hard to see the break, and because none of the other hangars was broken you couldn't really see it moving.
efair is offline
#8 Old 10-27-2017
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 540 Post(s)
Same with mine! Ł40 for a bit or welding - sorted!
Terminal is online now
#9 Old 10-28-2017
savcom's Avatar
Quoted: 609 Post(s)
I had an exhaust bracket break free on Silkie which was giving a rattle at idle - or just above idle. 30 minutes on the ramp and a spot of welding and no more rattle.
Which reminds me. I need to get some exhaust paint to cover up the bare metal used to earth the welder.
Polo Pete likes this.
Also
Previous :
savcom is offline
#10 Old 11-28-2017
Update...............garage disconnected cam magnet and rattle disappeared.....meaning it's the cam adjusters at fault. Expensive job, so may just leave it as it has got no worse over the past 3 years.....
#11 Old 11-28-2017
Turdo2's Avatar
Quoted: 361 Post(s)
it's not too expensive if you have a few tools and a "new" part. I've taken mine out, but It wasn't to replace - so I'm not sure on the part prices.
Turdo2 is offline
#12 Old 11-28-2017
Pelican parts has a good tech writeup with pics for DIY cam sensor replacement. There are also threads here where people have replaced theirs.
kapitand is offline
#13 Old 12-01-2017
The cam sensor is cheap, the cam adjusters however are Ł-hundreds!
New member with issue Polo Pete New Members Introduce Yourself Here 13 11-12-2017 02:47 PM
SLK 350 Exhaust Rattle - Different Fix WhiteRabbit SLK R172 General Discussion 2 03-13-2016 05:15 PM
Yet another solution to the roof/trunk rattle seanmacc SLK R171 General Discussion 3 10-29-2013 08:49 PM
AAAgghhh! I give up on this rattle.. nakulan7 SLK R171 General Discussion 2 09-11-2010 04:41 PM
