slk r170 console 12v aux power - Mercedes Benz SLK Forum
  • 1 Post By curro101
#1 Old 04-28-2013
conleyjb's Avatar
Vehicle: 02 SLK 320 w/ AMG Sport package
Quoted: 8 Post(s)
Has anyone else had issue with the 12v aux power outlet in the center console going bad, or not working to provide power to devices like a phone charger?
When I bought my car I noticed that no matter what brand, or type of 12v accessory charger I used none would work. Today I disassembled my console to get the the outlet after checking the fuses, etc and found that by using a multimeter I am in fact getting 12v switched when the ignition is on, but none of my device chargers will activate via the jack.
I have tried three different phones (HTC Desire, IPhone 4 and Motorola Tundra) along with a GPS device(TomTom 700), none are getting power from this jack.
I removed the jack and cleaned it pretty well, including scraping the electrode and corrosion from the metal inside.
I suspect it is one or two things; either the jack itself is damaged, thus facilitating a replacement or; the 12v jack from the factory doesn't offer enough amperage to power any of the devices I am trying.
Understanding I am referring to the traditional cigarette lighter as the 12v aux power outlet, is there anything different on these cars I should be considering, or does my diagnoses sound about right?
If it is the jack, anyone have a part number for just that little peice without having to do something crazy light buy a new console?
conleyjb is offline
#2 Old 04-28-2013
Are you are getting 12 volts switched to the inside or outside of the outlet? A working cigarette lighter socket will give a lot more power than your devices need. If bad you can replace it with a generic 12 volt aux outlet or new lighter socket.
CarolinaBluetec is offline
#3 Old 04-28-2013
conleyjb's Avatar
Quoted: 8 Post(s)
I got 12v to the leads at the bottom of the socket, I wasn't sure where to place my leads on the actual socket itself. Thus I know I am getting 12V to the socket, I just am not sure and suspect the socket is bad, or a pin that I need is bent, etc.
conleyjb is offline
#4 Old 05-03-2013
jcw
Vehicle: 2005 SLK350
Other Toys: Diamond DA-40
Is it because charging requires 5V, not 12?
I'm looking inito this as well as I have the same problem and found an adaptor (link below)
Do you think this would help?
http://www.commandonline.co.uk/merce...g-adapter.html
jcw is offline
#5 Old 05-04-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
How are you testing 12v at the socket, what are you using as 0v/gnd reference for your meter?
It COULD be that you have a loose ground on the socket so 12v gets there but no 0v reference on the socket so nothing works!
If you connect 12v directly to a 5v device you will quickly discover that electronic devices run on smoke; because the smoke will escape and the device will stop working!
nimbusgb is offline
#6 Old 05-04-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
All the standard car chargers work on 12v , converting them to 5v for the appliances !
The problem sounds like a faulty socket in the case of having tried various dofferent chargers !
curro101 is offline
#7 Old 05-04-2013
curro101's Avatar
Quoted: 528 Post(s)
Do your chargers have a small led light that comes on , usually a good ( although not infalible ) way of telling if the socket is working ?
curro101 is offline
#8 Old 05-05-2013
Naffdave's Avatar
Vehicle: Looking used to own a 2005 SLK 280 and a 1999 230K
Other Toys: NSM Sattilite Jukebox
Quoted: 23 Post(s)
Send a message via Yahoo to Naffdave
I have some trouble with mine that I use a split usb outlet and sometimes there isn't enough power to charge two things.
Im sure I read in my handbook (R170) it states not to use the cigerette lighter socket for accessories Im sure someone will correct me if im wrong.
Dave
Naffdave is offline
#9 Old 05-05-2013
curro101's Avatar
Quoted: 528 Post(s)
That might be down to the split socket and depending on what you charge !
Often the split sockets have one with more amperage than the other and some appliances , especially iPads need higher amperage than a normal phone for instance !
Naffdave likes this.
curro101 is offline
#10 Old 05-06-2013
A typical 12 volt cigarette lighter will draw 10 amps @ 12 volts, which is plenty to charge IPads, laptops, and all sorts of stuff. I use mine for a 12v vacuum cleaner and tire compressor sometimes. I am sure that MB does not want you to use "accessories" because people will be plugging 12 volt fridges and other such stuff into it.
#11 Old 05-07-2013
conleyjb's Avatar
Quoted: 8 Post(s)
I have had little time to look further into my issue over the past week, but I can think of no reason any 12V outlet would not at least charge a single device or at least as someone mentioned activate the LED on said charging device.
I am getting 12V on the power leads leading into my outlet, but did not try and measure voltage on the actual jack since I was not sure if ground was center or positive was. I just assumed the outlet was bad due to not working with a number of devices.
I have not heard anyone say that the 12V jack in the R170 are anything but, or they can not be used to power typical 12V devices, so will assume mine is bad. I would assume that others at least have gotten radar detectors to work, which I can not on mine.
I did look up the part number for the R170 outlet assembly and it is $79 from most online sources. Looks like I will be hunting for an aftermarket solution.
conleyjb is offline
#12 Old 05-07-2013
curro101's Avatar
Quoted: 528 Post(s)
curro101 is offline
#13 Old 05-07-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by curro101 View Post
There is nothing mystical about the cigarette lighter socket/12V outlet on an MB. They are made to a standard spec. The one Curro listed will be fine.
The outer part of the socket is -ve, the inner central connector is +ve. If you are checking for voltage using a DMM, it won't matter if you measure the wrong way round - it will just show -12.7V(ish) instead of a positive reading.
You sometimes find that when you plug an adaptor into the socket, it does not work. Often you need to give the adaptor a good wiggle/twist to get continuity.
Woolly is offline
2004 SLK Special Editions hamrt SLK R170 General Discussion 18 06-30-2017 02:38 AM
Thinking of installing Tuning chip on SLK 230 R170 TimPonken Performance MODS for the R170 7 12-20-2013 02:05 AM
'97 230 SLK loss of power edhall General Discussion 5 03-17-2012 05:02 AM
