How do I change interior dome bulb? - Mercedes Benz SLK Forum
 6Likes
  • 3 Post By JaysonM
  • 1 Post By JackD
  • 1 Post By jbanks15
  • 1 Post By tcrankwa
#1 Old 04-27-2013
Vehicle: R170 230
Hi all, I picked up my 2002 R170 230 today. The only thing amiss on the car (so far, fingers crossed), is the passenger side interior bulb is out. Have done a search and seen the dome unit out but can't find out how to get the dome unit out? Would any of you wonderful people be able to to tell me how?
Cheers Jack
JackD is offline
#2 Old 04-27-2013
Quoted: 6572 Post(s)
Jack, moving this to the r170 general discussion section.
the diy section is for already established diy procedures
have you tried a search top right for your query?
it might also be in your owner's manual
someone will respond shortly
#3 Old 04-27-2013
Look here in Leapy's sig block for some clues
https://www.slkworld.com/482817-post17.html
#4 Old 04-27-2013
Cheers Jack
Here you go:
https://www.slkworld.com/slk-r170-gen...tml#post195966
Basically you carefully pop the clear covering with smth like a flat head screwdriver. Then, use Philips screw driver to remove two screws. Then there are two metal pins towards the back of the car right on the base of the dome light assembly. You can see it on both sides from this picture:
These seem to be favorite to stuck up in there. Carefully jiggle wiggle it and again use a small flat head screw driver to sort of squeeze them so the dome light assembly comes out. From there it's easier to access both of the bulbs. You simply unscrew the plastic holder from the top (you can see one brown on the left and a hole on the right since it was removed from there), replace the bulb and screw it back in Put it back together! You're Done!
P.S. I put 2 LED ones in there. Or what a brightness change!!! You should see it! These are the ones I used. Picture taken from Ebay =)
jbanks15, Ohhshoot and slkninja like this.
#5 Old 04-27-2013
Vehicle: R170 230
Thanks Jayson I saw your post in my search but just wanted a bit more info before routing around with a screwdriver. Cheers mate.
JaysonM likes this.
JackD is offline
#6 Old 04-27-2013
but isn't this forum the best!!!
JaysonM likes this.
#7 Old 04-28-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
It's the people!
I know *I* certainly enjoy you folks.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#8 Old 04-28-2013
Ah I was just about to search for this, glad to find it right up top =)
For those needing the eBay link.. see below.
http://www.ebay.com/itm/380552738074...84.m1497.l2649
Ohhshoot is offline
Xenon bulb change!! MDS General Modifications R171 12 11-09-2017 09:47 AM
SLK55 Change headlight bulb help suren27 SLK R171 General Discussion 13 02-25-2013 05:15 AM
brake Bulb Replacement (Even if welded stuck) foreign freak SLK R170 class DIY 2 11-05-2011 02:11 PM
How to replace dome light bulb (2002) atebit SLK R170 class DIY 0 09-26-2010 01:48 PM
