Transmission issue after coductor plate, electrical connector, and fluid change - Mercedes Benz SLK Forum
#1 Old 04-15-2013
Vehicle: R170 with a few mods
Hi All,
I'm new on the forum. I have a 1998 slk230 auto transmission. Long story short the electrical connector on the transmission started leaking a little while ago, so i ordered the parts and fluid to get it done. I took the car to a local mechanic to have it all done and somehow from the factory according to the shop the screw for the electrical connector was stripped inside the transmission. They had to replace the conductor plate along with the connector and do the fluid flush.
The problem with the car is that the car doesn't shift too smooth like it use to, and that the car would stay stuck in gear at random times. sometimes 1st gear, sometimes 2nd gear, sometimes 4th or 5th. If i pull over and shut the car off for a minute or two and start the car again. All seems fine until the transmission sticks again.
does anyone know what might be the cause of this? I'm really scratching my head. Thanks to everyone in advance on helping with this.
again minus the very slight fluid leak the car drove perfect prior to this issue.
M2-Motoring is offline
#2 Old 04-15-2013
Post
The 1st thought that came to my mind is to reset the transmission memory:
http://www.benzworld.org/forums/r170...ml#post4198269
Or I also think if you disconnect the battery overnight 12 hours or so then it resets the memory too. I think You should give it a try.
#3 Old 04-15-2013
leapyfish's Avatar
Have a look at the engine & transmission mounts to see if they are collapsed.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 04-16-2013
Thanks for the advice guys. tried and looked at both. nothing. =(
for a 98 it only has 27k miles on it btw =) purely a garage queen
#5 Old 01-05-2015
Vehicle: mercedes benz SLK 200 (auto)
Chats: 2
Is it works? same problem with my SLK
red_merce_slk is offline
#6 Old 01-05-2015
Quoted: 1138 Post(s)
Dont know how good your garage guy is ??
But when you do this kind of repair everything has to be spotless .
Did he use original merc parts ?
Correct fluid ?
Right amount ?
Did he check the level of oil ?
Filter changed ?
Do a code read of gearbox and of course the engine .
Mounts wont have anything to do with gear changes that you describing as such.
Delucas is offline
