Help needed , roof problem after Cabrio module install - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Woolly
  • 1 Post By leapyfish
  • 1 Post By Aycee
  • 1 Post By curro101
  • 1 Post By Aycee
#1 Old 04-13-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Hi guys & gals , brain picking time !!
Last week I installed a set of modules from Cabrio module in a r170 facelift and everything worked fine !!!
Two or three days later , after using the car once or twice the owner calls me , saying that the windows , rear and front , won't raise on closing the roof !
The situation is :
On opening everything works fine and the front windows raise etc.
On closing the roof reaches the windscreen , the boot/trunk goes fully down , but no window movement , pump keeps going !
After checking the installation was ok , I removed the modules and returned everything to original , but the problem persists !
Modules or coincidence ??
After reading what seems like hundreds of posts without finding anything persifically like this , I come to you all !
As the roof opens correctly I'm inclined to feel the problem is with the top micro switches and not the one in the boot/trunk ???
I've removed the windscreen cover and the headliner , checked all the micro switches and they all seem to have continuity , could it be a severed cable from the the roof switches ?? How can I check this , anyone know where the two wires ( blue /brown ) from the micro switches that run back along the roof are connected too ??
Any ideas ???
curro101 is offline
#2 Old 04-13-2013
Quoted: 6543 Post(s)
r170 facelift? is the issue with a r170 or r171?
since this is not a diy, i will move to r170 general discussion until i hear otherwise
#3 Old 04-13-2013
curro101's Avatar
Quoted: 528 Post(s)
Ok cheers Jeff .
R170 , there is also a facelift 2001-2004 !!
curro101 is offline
#4 Old 04-13-2013
i was just confused because i know u have a r171 and u were putting it in a r170
#5 Old 04-13-2013
curro101's Avatar
Quoted: 528 Post(s)
One , who gets himself in trouble helping others !!
curro101 is offline
#6 Old 04-13-2013
that makes 2 of us. I don't mind blowing up my stuff, but don't like to blow up others
#7 Old 04-13-2013
curro101's Avatar
Quoted: 528 Post(s)
Tell me about it !!
curro101 is offline
#8 Old 04-13-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
There was a similar problem many moons ago. The cause was the cables breaking at the join between the roof and rear windscreen panel. It could be worth looking carefully there , and at the bottom of the rear screen - these two points being where the cable flexes the most.
curro101 likes this.
Woolly is offline
#9 Old 04-14-2013
leapyfish's Avatar
Have a look here.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#10 Old 04-14-2013
curro101's Avatar
Quoted: 528 Post(s)
This is what I thought , but wondered where the cables go too , so as to be able to check continuity ??
curro101 is offline
#11 Old 04-14-2013
curro101's Avatar
Quoted: 528 Post(s)
Bump , bump ...
curro101 is offline
#12 Old 04-14-2013
curro101's Avatar
Quoted: 528 Post(s)
I'll be checking out the wires tomorrow , but just in case , does anyone know if I can swap out the N10/3 module to test , or will another module need to be coded ??
curro101 is offline
#13 Old 04-14-2013
Aycee's Avatar
Vehicle: 2002 Blue SLK 320
Are you checking the micro switches with the roof closed or just pushing them manually? Although the switches may be ok could be that the roof is not latching down propery. Have you tried pushing down on the roof once its closed? I remember reading here somewhere there are two cables which latch the roof and these can stretch. Worth having a closer look under the headlining.
Aycee is offline
#14 Old 04-14-2013
curro101's Avatar
Quoted: 528 Post(s)
I have the liner removed , I can see the latches closing and the switches being pushed , until the red button is released , as the windows don't raise , then the latches relase slightly !
For lack of arms/hands ( cant push button and check continuity at the same time ) so I checked the switches by pushing them manually .
curro101 is offline
#15 Old 04-14-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
I swapped out my n10-3 without recoding, didn't fix my fault but it also worked exactly like the one I took out so pretty certain it doesn't need to be coded.
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
#16 Old 04-15-2013
curro101's Avatar
Quoted: 528 Post(s)
Culprit found , as I thought , it was one of the wires from the front roof micro switches , so coincidences do happen , nothing to do with the installation of the roof modules !!
Fixed and working , tomorrow , putting everything back together .....
Broken wire :
Connector , yellow , on the right side of the boot which the wires run down to , for futur reference :
Aycee likes this.
curro101 is offline
#17 Old 04-15-2013
Great job as usual!!
#18 Old 04-15-2013
Aycee's Avatar
That's not my car is it? Same colour and interior!
Glad you got it sorted.
Aycee is offline
Roof opening problem Mats T Sweden 3 10-10-2010 03:17 PM
XCar-Style Roof Module Andy Where to get R170 SLK Items 12 07-12-2009 03:03 PM
Zaino and Vario Roof module working in tandem mcat SLK R171 General Discussion 23 10-03-2006 02:10 PM
New SLK roof module supplier benz--man General Modifications R171 18 09-20-2006 12:39 AM
