Roof seal replacement - help please - Mercedes Benz SLK Forum
 8Likes
  • 3 Post By mchild
  • 3 Post By RustyTheDog
  • 1 Post By mchild
  • 1 Post By M4rCu5
#1 Old 03-30-2017
Vehicle: 2001 R170 SLK 230k Auto
Hi all, I've searched high and low for a comprehensive guide but can only find part instructions, and no pictures.
I need to adjust (potentially replace) the the side roof seal that runs along the side of the roof panel that the door glass seals against. It leaks onto the driver seat. I understand that to remove/ adjust the seal I have to pull on the rubber strip somewhere in the centre of its length, and when it pops off the groove it's seated in then I should see where the 2 ends are screwed down (which can be adjusted).
Q: is the above description accurate?
Q: Also, there's a metal trim strip on the rubber seal, do I remove this (how?), or does this all come away with the seal when I pull it?
Any guidance gratefully received.
RJC
RustyTheDog is offline
#2 Old 03-30-2017
Quoted: 506 Post(s)
I think you are on the right track, but here is the procedure from WIS https://drive.google.com/file/d/0B1W...ew?usp=sharing
jbanks15, Avel Du and RustyTheDog like this.
mchild is offline
The Following 2 Users Say Thank You to mchild For This Useful Post:
#3 Old 03-30-2017
Fabulous! Many thanks indeed.
#4 Old 04-01-2017
Some pics to help others with R170 roof seal removal. Used a 2ft length of wood, drilled holes at the ends and used zip ties to hold the roof. The seal sits in a channel underneath the metal trim strip. Grab the seal in the middle below the metal trim and wiggle/pull it downwards to get it out of the channel. You can then see the 3 screws which hold the metal trim to the roof panel and traps the seal. When replacing the seal I found it easiest to put the full length of the lower (inner) edge back in the channel first and then used the blunt handle end of a spoon to push the outer edge back into the channel under the metal trim strip. Ta-da!
jbanks15, LetHerRyp and Avel Du like this.
#5 Old 04-09-2017
Vehicle: 2000 SLK230
Quoted: 14 Post(s)
What about the part of the upper door/window seal that runs along the windshield? Mine are torn up and I have already picked up new ones but haven't gotten around to figuring out how to do it.
MasterSprtn117 is offline
#6 Old 04-09-2017
Quoted: 506 Post(s)
Please review the attached parts view of the roof seals and specifically identify which seal you are asking about. Thanks
Edit - my mistake. These seals are for the rear of the roof not the front windshield area.
mchild is offline
#7 Old 04-09-2017
Quoted: 506 Post(s)
I think this must be the seal you are referring to. Hopefully, I have it right this time, but if not, let me know.
R170 Front seal replacement: https://drive.google.com/file/d/0B1W...ew?usp=sharing
mchild is offline
#8 Old 04-26-2017
Vehicle: slk320 2002
thanks for this instruction. Lately i have quite a wind noise coming from the passenger window and up on inspection, i found that the ruber trim window seal end is kind of bristle and broken. i would like to know if you know what is the part number for this item. car is 2002 slk 320. thanks
kalali is offline
#9 Old 04-26-2017
Quoted: 6537 Post(s)
you see the part?
#10 Old 04-26-2017
Quoted: 506 Post(s)
Maybe part #230 in the link? If so the part number for the right side is 170 790 02 98.
mchild is offline
#11 Old 04-27-2017
Angry
Yes. Part #230 is what i need. Thanks
Darn it. didn't expect that rubber part of 15 years old car still cost a bit more than $100 buck.
kalali is offline
#12 Old 08-27-2018
M4rCu5's Avatar
Quoted: 253 Post(s)
Resurrecting an old thread again, but thanks for this.
Both sides had started to leak water on my 200, which in turn managed to run down into the boot (trunk) and was dripping inside off of the boot (trunk) hinges.
Boot seal, rear quarter window seals, rear roof seal, all pulled off and inspected.
All put back on again and sealed with a thin layer of windscreen sealant.
No joy
Turned out to be these things, upon inspection the internal rubbers go flat with age and allow seepage.
Thin layer windscreen sealant, reattach to car ...
... Mother Nature performed her rain test a couple of times over the weekend and I still have a dry boot (trunk)
Yay!
Seems that I took the long route but got there eventually.
Feeling confident enough now to put the boot (trunk) carpet back in.
BTW. If anyone else feels the need to pull their rubber trims off, save yourselves some hassle and buy a set of trim removal tools, much better than a spoon and only about Ł7 on eBay
M4rCu5 is online now
Roof seal issue pjgraham86 SLK R171 General Discussion 15 12-10-2018 10:44 AM
Roof Seal Lubricant Muddy SLK R170 General Discussion 8 02-20-2016 09:58 AM
SLK230 Roof Hydraulic Pistion Replacement thunderstrike SLK R170 class DIY 19 09-18-2015 07:35 PM
SLK230 Roof Hydraulic Pistion Replacement thunderstrike SLK R170 class DIY 4 02-29-2012 01:04 PM
