pulling to the left - Mercedes Benz SLK Forum
  • 1 Post By electo
#1 Old 03-28-2017
Vehicle: slk320 2001
pulling to the left
hi
i am after some advice
my slk 320 2001 uk has started pulling to the left after a new set of tyres have been fitted (now 12 months old)
the tracking has been checked and is ok
the tyres have been swapped over and its still pulling to the left
i do have kumo directional tyres on them would that be the problem
also passed the mot with no problems so i would say the ball joints and tie rod ends should be ok
any ideas ??
electo is offline
#2 Old 03-28-2017
Quoted: 2296 Post(s)
Two questions.
Is your drive smooth other than the pull?
If you have minor vibration, did you hit a deep pothole or mount a high kerb in the time since the change?
Any good tyre fitter would spot a buckled wheel, but if it happened since fitting....
Our 350 had a slight pull.
Switching to matching tyres all round helped but still a slight pull remained.
The fitter spotted a buckled wheel.
One new wheel later the ride is dead straight.
When you swapped the wheels over did the pull direction change?
You've already checked the obvious culprits.
Assuming that you trust your MOT garage.
Maybe it's time for a laser check wheel alignment.
Avel Du is online now
#3 Old 03-29-2017
hi
the problem has been there since the tyre change
i have 4 kumos on it
the are no buckled wheels nor have i hit a pot hole
i trust the MOT guy 100% so its not that
before i changed to all kumo tyre i had kumo on the back and bridgestones on the front and there was no pulling to the left
its just a slight pull and its more annoying than anything else
do anyone have any tyre recommendation for the front ?
electo is offline
#4 Old 03-29-2017
made no differance when they were changed over
had the tracking done 6 months ago a little out but not much (car has not been used much since the tracking has been done)
the drive is smooth
electo is offline
#5 Old 03-29-2017
Compare the wheel lugs left to right.
Do they have the same taper?
Some aftermarket lugs don't match the MB oem shape at the end of the lug.
#6 Old 03-30-2017
all the wheel bolts are standard merc ones no after market ones
looking at replacing the front tyre with ether
205/55R16 91V Kumho ecsta le sport OR Yokohama advan sports V105
just finding the best price and i think it will be the Yokohama advan sports V105
electo is offline
#7 Old 03-30-2017
Vehicle: SLK 230 2002
Other Toys: No toys...just other cars!
Quoted: 43 Post(s)
Hankooks for me Ventus prime 2 on the back and ventus prime 3 on the front. They stick like sticky thing that's really really sticky!
Biohazard is offline
Left License Plate Bulb Malfunction Message? rubenh SLK R171 General Discussion 47 05-11-2016 05:53 PM
How much fuel left in the tank? Oszy SLK R171 General Discussion 17 02-26-2015 10:50 PM
Left fog light staying on! Luckylooser SLK R170 General Discussion 1 02-18-2015 06:23 PM
Car pulling left and right longship SLK R170 General Discussion 5 09-03-2014 05:18 PM
Left right?? wynand53 SLK R171 General Discussion 16 02-19-2009 02:55 AM
