Rear water drainage pipes - Mercedes Benz SLK Forum
  • 2 Post By RustyTheDog
#1 Old 03-28-2017
Okkie's Avatar
Vehicle: 1999 SLK 230 Kompressor, 2005 C350
Other Toys: Lotus 7's
Hi, Can anyone explain to me how to access and remove the rear drainage pipes on the R170. The left pipe is so clogged that no matter what I do I cannot clear it. Can I access them through the boot, or through the rear wheel wells?
Thank for the advice in advance
Okkie is offline
#2 Old 03-28-2017
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
Does this thread help?...
https://www.slkworld.com/slk-r170-cla...-cleaning.html
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#3 Old 03-28-2017
Okkie's Avatar
Thanks. So it seems to run between the luggage compartment cover and the inner fender. Will have a look on the weekend. I am afraid that I will have to either remove and clean them, or replace them entirely.
Okkie is offline
#4 Old 03-28-2017
Pictor's Avatar
Quoted: 219 Post(s)
I had to clear these on both my cars when I bought them. accumulation of dust becomes mud and blocks them.
Easiest way I found was to remove the boot side interior trim. See Pelican Parts for a start.
Then you can reach the tube ends. The good thing about having these trims out is you can do a good inspection of the rear end for rust, damage and to be sure all the other drains in the lower corners are clear. Inspect for fluid leaks, water leaks and also lubricate the bootlid front locks. Clean out any dust and leaves.
I had tried blowing air and sliding a narrow tube down the drain tubes and flushing, blowing, jiggling, but to no effect.
The tube on my '98 was almost too short and crimped somewhat where it turns a tight corner to go through the side panel. On my '01 car the tube was maybe 15mm longer and a better fit but still had blocked.
I suspect some little spiders like these areas and some cobwebs and dust become the start of a blockage.
So it's worth checking these drains from time to time and flushing them. Also, I never park under trees, as the leaves and seeds
will find their way into the tube.
There is a thread somewhere about putting flywire from screen doors over the inlet grills. I tried this but it is fiddly and hard to make it look neat and harder to see the spiders webs afterwards.
Pictor is offline
#5 Old 03-28-2017
Okkie's Avatar
Good to know, thanks. Can the tubes be remove completely? I mean, to clean them outside the car or to replace.
Okkie is offline
#6 Old 03-28-2017
Quoted: 913 Post(s)
They're easy to remove, but you'd likely need to remove the bumper to re-install them correctly.
I suggest using a 1.5M length of nylon filament from a weed trimmer; fill your clogged tube with hot water, then push the filament all the way in, keep pushing and twisting and tapping until the water starts flowing.
efair is offline
#7 Old 03-28-2017
Vehicle: R170 230K 1999
Other Toys: Zodiac 550 RIB
Quoted: 14 Post(s)
Beware when filling with water to soften the crud and then trying to blow through with an airline.
Someone I know did this and ended up with a face full of muddy water, comes out at a hell of a rate but not in the direction you'd like it to . Silly fellow.
I took the advice on here then and filled the tubes with warm water and some detergent and reached into the wing from the boot squeezed the tube and she cleared no problem.
Not like the other guy I know with the muddy face
nigxls is offline
#8 Old 03-28-2017
Quoted: 913 Post(s)
nigxls,
I wasn't aware that anybody was watching!
efair is offline
#9 Old 03-29-2017
Okkie's Avatar
Thanks guys, will work on this during the weekend and report back
Okkie is offline
#10 Old 03-29-2017
Vehicle: slc 43 2016
Quoted: 83 Post(s)
I used a roll of plumbers solder , flexible but stiff enough
Paulwirral is offline
#11 Old 03-30-2017
Quoted: 14 Post(s)
Originally Posted by efair View Post
nigxls,
Has to be the first thing you do is look around to see who saw you
nigxls is offline
#12 Old 04-01-2017
Vehicle: 2001 R170 SLK 230k Auto
Mine were both completely blocked. I had success with ramming a length of pipe into the end of a water bottle, jamming the pipe down the drainage tube (after removing the grilles) then squeezing and releasing the bottle. Muddy gritty water just went in and out the bottle for a while until the drainage tube suddenly unblocked.
LetHerRyp and RLander like this.
RustyTheDog is offline
#13 Old 04-01-2017
And I had a tree growing in mine when I last looked.
#14 Old 04-03-2017
Okkie's Avatar
Removed the side panel in the trunk and pulled the rubber pipe from the exit hole. Massaged the stinking mud from the pipe and got it totally cleared. The water will never flow properly due to the way the pipe is squashed to fit through the exit hole. I found an elbow connector used in garden irrigation fits perfectly for the application. Water is now draining as it should with no obstructions. Needless to say, the SOP will still be to blow out the drains on a regular basis. A $1 elbow would have solved this problem form the beginning.
Okkie is offline
#15 Old 04-03-2017
Quoted: 913 Post(s)
Can you post a.link or photo to the elbow?
efair is offline
#16 Old 04-03-2017
Quoted: 133 Post(s)
I used fish tape on mine. In case you haven't heard of it or think I made it up: https://www.zoro.com/klein-tools-mar...Q&gclsrc=aw.ds
Mn car guy is offline
#17 Old 04-04-2017
Okkie's Avatar
Working in the construction industry, I am well aware of what a fish tape is. This did not help me as half the pipe was blocked with "mud" Only way I could clear it was my massaging the mud from the pipe. The main cause of blockages is the way the pipe is squashed to fit through the bodywork. My problem is forever solved by the plastic elbow, as the open end is now the same size as the drainage pipe.
Okkie is offline
#18 Old 04-04-2017
Okkie's Avatar
Did not take a photo, sorry. But any hardware store that sell DIY irrigation systems will have it on the shelf. 20mm by 1/2 inch - one side is threaded (1/2 inch) whilst the other is a push in. Hope that gives you a better idea.
Okkie is offline
#19 Old 04-04-2017
Quoted: 913 Post(s)
efair is offline
DIY Rear Differential Jack Pad for SLK55 AMG AMGPilot SLK R171 Class DIY 3 02-27-2018 12:06 PM
Water in the boot/trunk when opening the lid powers SLK R171 General Discussion 4 08-28-2015 05:28 AM
Water leak into boot and interior condensation [SOLVED] CraigHew SLK R171 General Discussion 2 11-18-2014 03:24 AM
Just replaced the rear cats in my wife's 2002 SLK 32 AMG wallew AMGs 16 09-15-2014 06:35 PM
Need Help - Trunk full of water mcat SLK R171 General Discussion 31 07-20-2006 08:11 PM
