Oil leak - Mercedes Benz SLK Forum
#1 Old 03-26-2017
Vehicle: R170 320 previously R171 350 and CLK
Other Toys: 4 grandchildren
Quoted: 31 Post(s)
Oil leak
I've got a 320 with 50k on it.
From the MoT I've been told there is a film of automatic transmission fluid on the bottom of the gearbox. They could not source it. I've had a look and it seems fairly uniform. Are there any probable sources I could check? It's a fine film and there's no drips on the garage floor (hence not realising the problem).
When I bought the car it had just been 'thoroughly' serviced by the dealer but after a couple of weeks I noted that there was oil coming from the power steering reservoir. It had been overfilled. (Very thorough!). Could this be the source of the leak?
I was going to get the autobox fluid changed at 60k so it's no big deal to do it now.
As an aside, I keep getting told off for not posting whenever I log on.
Harvey Yates is offline
#2 Old 03-26-2017
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
Well done for Posting.
Havent had this issue myself, hope it works out for you man.
Good luck,
RLander.
RLander is offline
#3 Old 03-26-2017
Quoted: 31 Post(s)
Good luck,
RLander.
I feel selfish because it makes it seem as if I only come on here to learn. Given the knowledge of most, I've got little to add.
#4 Old 03-26-2017
Quoted: 914 Post(s)
Have the transmission serviced and be sure they replace the pan gasket. This is not so much a paper gasket as a rubber seal, not tightened too tight.
efair is offline
#5 Old 03-26-2017
Quoted: 31 Post(s)
Thanks for that. Will do.
#6 Old 03-26-2017
Quoted: 133 Post(s)
I'd bet that it's the pilot bushing that is leaking. It's really a common issue on these trannys. Good news is it's inexpensive and fairly easy to replace. Google it when you get a moment and you'll see tons of 'how to' vids.
Mn car guy is offline
The Following User Says Thank You to Mn car guy For This Useful Post:
#7 Old 03-26-2017
Quoted: 31 Post(s)
Thanks for that. I'll go under and have a look.
Slow Oil leak 07 SLK280 koobie17 SLK R171 General Discussion 3 12-14-2016 03:21 PM
oil leak! a heads up story frogfoot SLK R171 General Discussion 13 10-10-2014 04:43 PM
bad oil leak slimsol SLK R170 General Discussion 9 02-19-2012 06:25 PM
