SLK230 R170 Alternator Pulley Advice - Mercedes Benz SLK Forum
  • 1 Post By huskymanuk
  • 1 Post By Livefreeordie
#1 Old 03-24-2017
Vehicle: SLK 230 R170 1999 Auto
Dear All
I'm in the process of Fitting a Larger Bottom Crank Pulley, off with the original 185mm on with 192mm. Can any one please advise me on the size of the Alternator Pulley that I should use. As I do not want my Alternator to spin to fast when the engine is running at high speeds. I have the standard Bosch 90amp Alternator fitted but may be fitting a higher output Alternator due to an uprated sound system that is being fitted.
My car is a SLK230 R170 1999
Thanks as usual for all your help.
Kind regards
Husky
huskymanuk is offline
#2 Old 03-24-2017
Vehicle: 2000 SLK 320
Quoted: 55 Post(s)
Maths not my best subject but at a guess you need to work out the circumpherence of both the old and new crank pulleys, calculate the % increase and apply that percentage increase to your alternator pulley to get the circumpherence required then work back to get the diameter.
That should keep the alternater at the same speed, the voltage regulator in the back of the alternator should regulate the alternator output anyway so you may not need to alter the alternator pulley.
Regards Stuart.
t140v is offline
#3 Old 03-24-2017
I installed an ASP overdrive crank pulley on my 230 many years ago and to this day never had any issues with the alt.
Idiot101 likes this.
#4 Old 03-25-2017
Thanks a lot, I did look up the info but it was nearly mid night and after 18 hours in the workshop my brain just gave up the ghost. So the easy option was to post a note but thank you for your reply.
Stay cool.
Husky
#5 Old 03-25-2017
Hello across the Pond! Very interesting and your not the first to say I could be OK but really appreciate your input. The gear changing of 7mm is not that great and I would think I'm still just within safe limits?
Thanks for your experience that's always worth it's weight in gold.
Stay cool.
Husky
#6 Old 03-25-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I've never heard of anyone having alternator problems due to changing the crankshaft pulley....
Post #14 here should help you out with the maths if you really fell the need:
Explain how a smaller crank pulley makes more HP? - Ford Mustang Forums : Corral.net Mustang Forum
curro101 is offline
New Member with R170 SLK230 clintwade New Members Introduce Yourself Here 16 06-17-2015 10:39 PM
R170 SLK230 roof problems Tonyamos New Members Introduce Yourself Here 23 06-13-2015 03:23 PM
99 SLK230 Need Advice - Head Repair brookbr SLK R170 General Discussion 3 08-09-2014 03:34 PM
SLk230 R170 Black Halo projector headlights like new slkrider123 SLK Parts For Sale 12 07-09-2012 05:49 PM
Early SLK230 advice strangerover SLK R170 General Discussion 1 03-17-2007 12:24 PM
