PSE Questions - repair detached connector pins? Plug and Play part number compatibility? - Mercedes Benz SLK Forum
  • 1 Post By cliveski
#1 Old 03-24-2017
Vehicle: 1996 SLK 230 Non-Runner
Quoted: 11 Post(s)
Thumbs down PSE Questions - repair detached connector pins? Plug and Play part number compatibility?
The PSE on my recently acquired '98 SLK has suffered water damage.
The protective foam it sat in was damp - symptoms were interior light constantly on (so have it switched to the constantly off position) and the central locking not always unlocking passenger door / boot.
Today I removed it hopeful I could give it a clean and get it working again. Sadly there was corrosion in the white 18 pin connector socket. One of the pins had become detached (rusted off) and two more are wobbly. The board itself didn't seem too bad compared to some pictured on the internet.
I will post some pictures up but in the first instance are the rusted off pins something that could be repaired? anyone know of a place who repairs this kind of thing?
Assuming a repair is not possible or might be futile I will be looking for a replacement.
Mine is 1708000148 (06) and I have seen the following list of alternatives -
1708000548
1708000248
1708000348
1708000448
1708000648
1708000848
My question is - is the matching part number the only one that will be plug and play for my car? and others will need programming?
I will be clearing the drains and turning the repalcement PSE upside down.
Thank you, Clive
cliveski is offline
#2 Old 03-24-2017
Quoted: 913 Post(s)
If you have access to the EPC you can often find the pins. I've ordered a few of these direct from MB over the years.
efair is online now
#3 Old 03-24-2017
Quoted: 11 Post(s)
Done a google search and discovered another SLK owner had removed the white A37 connector from the board and hard-wired some connections to it instead. Apparently only 5 of the 18 pins are used.
PSE connector fix - Mercedes-Benz Forum
I doubt I will be lucky enough that my 3 missing/wobbly/barely standing up pins are not required.
Replacement PSE's of this type seem to be 200+
I have a lovely 'as new' PSE from the 96 car I am breaking but it is the 210 variant not the 170 version so is not compatible sadly.
cliveski is offline
#4 Old 03-24-2017
Quoted: 11 Post(s)
Well after cleaning and drying the PSE I plugged it back into the car and it's no worse than before despite being 3 pins short.
Central Locking may actually work better (too early to confirm for certain).
In other news and in an attempt to pass on some useful information earlier cars with '210' PSE's have different cables/connectors than cars with '170' PSE's.
The 1996 SLK I'm breaking has one fitted - 2108000648 - a 2005 replacement by Mercedes no less (I have the receipt). If anyone needs one it's in mint condition.
cliveski is offline
#5 Old 03-26-2017
1978L82's Avatar
Vehicle: 1998 MB SLK230
Quoted: 111 Post(s)
Not sure if it's much help because of your location, but the PSE from a crossfire should also work. I used one of a different number on my 98 and it worked just fine. I'm under the impression that PSE's from all r170s and Crossfires are the same. I'll look up my original number and the new number later today for reference. I found mine for $200 on eBay.
1978L82 is offline
The Following User Says Thank You to 1978L82 For This Useful Post:
#6 Old 04-20-2017
Quoted: 11 Post(s)
An update on this - got a replacement PSE via ebay for 120 - alas it arrived with some green corrosion amongst the pins in the white connector socket AND two missing pins grrr
Got a full refund and allowed to keep it - have since opened it up and it actually appears in really good condition - no sign of water damage or anything.
Does anyone know of somewhere that can de-solder the white connector and solder a new one in?
I have another white connector with all its pins intact on another board (alarm or something) I'm happy to sacrifice.
Regards, Clive
cliveski is offline
#7 Old 04-20-2017
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
Take a look at - https://www.atpelectronics.co.uk/pages/products.html
ixion is online now
#8 Old 04-20-2017
Vehicle: 1998 SLK230, 2000 SLK230, 2012 SLK250
Other Toys: Tennis Racquet
Quoted: 45 Post(s)
Hi Clive, the higher part numbers supersede the lower part numbers. They were introduced in different years, and maybe they had more functionality. You can safely order the highest number, I did.
You know, you can always just remove the big white plug, and wire in your own connector to the board. I forget how many are used, but most of those pins aren't. Maybe 6 of them?
mightycpa is offline
#9 Old 04-21-2017
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
Originally Posted by ixion View Post
Linky not working for me.....
Shalesy is offline
#10 Old 04-21-2017
ixion's Avatar
Quoted: 41 Post(s)
Remanufacturers
Sorry about that.
SORRY TRY THESE -
https://www.bba-reman.com/gb/catalogue/16/
BBA Reman is one of the worlds leading automotive Remanufacturers. ABS ECU modules, throttle bodies & instrument cluster repair Etc.The company was founded in 1998.Lifetime warranty offered.
http://www.actronics.eu/en
Remanufacture - ABS ECU modules, throttle bodies & instrument cluster repair
Electronic Remanufacturing Since 1988 ECU,Clusters, ABS,Etc
ixion is online now
The Following User Says Thank You to ixion For This Useful Post:
#11 Old 04-21-2017
Pictor's Avatar
Quoted: 219 Post(s)
Interchangeabilty
I got the same story as mightycpa when I enquired at a dealer, the replacement for my '98 230 which had part number ending in 148 was the '848 last issued part.
But if I could get a new one for 200 I would, dealers ask over $2000 here and almost all the USA suppliers will not ship internationally. I got a good one for the '230 from a wrecker for $100 but it is still an old one.
Pictor is offline
The Following User Says Thank You to Pictor For This Useful Post:
#12 Old 04-23-2017
1978L82's Avatar
Quoted: 111 Post(s)
My pins were a bit corroded too. I dipped them in a product called CLR. Let them sit in there an it pretty much dissolves. Then brush off terminals with toothbrush. Don't know how bad yours are though.
1978L82 is offline
#13 Old 04-24-2017
Quoted: 11 Post(s)
Thank you for the input people.
I had seen a post elsewhere where someone had hard-wired 5 connections to the board so it's certainly true not all 18 pins are required - a shame we don't know which of the 18 pins are actually used.
I have used Servisol Super 10 Switch Cleaning Lubricant (from Maplin) on the original PSE board and it cleaned things up nicely. Used it on the pins of the replacement PSE as well to good effect.
I will explore having the replacement PSE I bought repaired / checked as it owes me nothing. The original one does work in that it locks and unlocks the doors and boot but I do find after a drive the passenger door and boot will have locked and I have to lock then unlock the car to get these open - annoying.
Thanks again, Clive
cliveski is offline
#14 Old 05-17-2017
Quoted: 11 Post(s)
I have some useful information to pass on which I hope may be useful to others . . .
I now know it is only 5 of the 18 pins that are used and I now know which pins they are - see picture below - the five highlighted in pink are the ones that are used.
The numbering is my own system.
I discovered the above when I realised I could take the connector apart to clean it - the black 'tab' slides down and off allowing the connector block to slide out. I got good results from a quick clean of mine.
Sadly I don't know what each pin controls but considering on my car the PSE is missing pins 3,5 and 6 yet the central locking still works correctly* I can only assume pins 10 and 11 are connected to the central locking. My interior light is stuck permanently on so assume that is connected to pins 3,5 and 6.
* from reading another post by bazzle it is normal for the car to lock itself once you first start moving. I have found this anti-hijack (??) feature annoying as if I get out and go to open the boot or passenger door I find them locked - have to remember to press the unlock button on the dash to open passenger door and boot.
cliveski is offline
