console light bulb replacement - Mercedes Benz SLK Forum
 4Likes
  • 4 Post By curro101
#1 Old 03-23-2017
Vehicle: 1999 230SLK - Manual
Other Toys: Honda's: 08 CBR1000rr, 05 CBR600rr, 1970 CB350 Boats: Fareast 23R, Laser Truck: 08 Chevy Colorado
Quoted: 19 Post(s)
Hi, me again...
the bulb on the right hand side of the console that backlights the heater controls on the passenger side (LHD) has burned out. does anyone know how to go about replacing that? a quick troll through Pelican doesn't show anything specific, and I infer from what I saw that you would have to take the entire center console out to get access to the area in question. If that's the fix then so be it, however I don't want to start removing my e-brake and shifter and whatnot to get the lower part of the center console out if there's some way of removing just the upper portion...
Thanks in advance!
overdraft is offline
#2 Old 03-23-2017
Quoted: 6554 Post(s)
not specific?
Mercedes-Benz SLK 230 Instrument Cluster Removal and Bulb Replacement | 1998-2004 | Pelican Parts DIY Maintenance Article
#3 Old 03-23-2017
Quoted: 19 Post(s)
sadly no. that tells you how to replace the lights behind the gauges... I need to replace the ones behind the upper central console.
#4 Old 03-23-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
If you're referring to the heater control knobs/dials, the bulb is changed by pulling off the knob and removing the bulb behind it with needle nosed pliers or similar...
curro101 is offline
#5 Old 03-23-2017
curro101's Avatar
Quoted: 528 Post(s)
https://www.slkworld.com/slk-r170-gen...le-lights.html
curro101 is offline
#6 Old 03-24-2017
Quoted: 19 Post(s)
awesome curro! THANKS!
#7 Old 06-16-2017
Erok's Avatar
Vehicle: 2003 SLK230 6-Speed Manual
Other Toys: 2013 ML350, 2007 SLK280
Quoted: 16 Post(s)
I just did this 3 days ago but I have a problem. I fan knob doesn't fully click in and I can now remove it by hand without any tools. When I first took it off, it required a little bit of strength and prying. The knob for the vents control will no longer attaches. The piece inside the dash that the knob attaches to seems to have moved backwards in the dash a little. I need to fix this before winter when I need my defrosters. Does anyone have an idea how to get the knobs back on tightly like they were before I replaced the light bulbs? I double checked and nothing broke or bent.
Erok is offline
#8 Old 06-16-2017
savcom's Avatar
Quoted: 609 Post(s)
You can fairly easily remove the whole central dash panel and this makes access to the heater controls much easier. You should be able to then see where your alignment problems are. If you have the keys to remove your head unit - and any necessary codes to re-enable it once you re-assemble it - then the job is a matter of 15 minutes or so to get access.
Good luck!
Also
Previous :
savcom is offline
#9 Old 06-26-2017
Erok's Avatar
Quoted: 16 Post(s)
So I find my issue, the back of the vent controller was not attached to the module. I'm trying to figure out how to put it back together the correct way.
Erok is offline
Instrument Cluster Removal and Light Bulb Replacement jbanks15 SLK R170 class DIY 3 11-27-2017 04:56 PM
Heater Control Dashboard Light Replacement 100garza SLK R170 General Discussion 4 01-05-2015 09:06 PM
AMG Fog light replacement, quick question! li174 Performance MODS for the R171 3 07-02-2012 05:35 PM
Center Console Light BrianS SLK R171 General Discussion 14 08-05-2009 12:08 AM
